 Post subject: SSD Porwe failure. Need Electronic Schemas
PostPosted: October 17th, 2024, 5:05
I have an ADATA SSD that has a power failure. When I power it in PC3000, the BSY light remains OFF.
I want to test the diodes/transistors and see if I need to replace one of them.
Is there a website where we can find SSD electronic Schemas?
I really appreciate any help you can provide.
Lamine
 Post subject: Re: SSD Porwe failure. Need Electronic Schemas
PostPosted: October 17th, 2024, 5:23
I've not seen one, most drives power delivery system is pretty much the same. Just work your way down the rails manually.
PostPosted: October 17th, 2024, 6:25
Sometimes you will find a Silicon Motion reference circuit. I have a collection of them at the HDD Oracle.
PostPosted: October 22nd, 2024, 3:32
Hi @fzabkar
Could you please share the link. I'm very interested.
Thank you in advance for your help
Lamine
PostPosted: October 22nd, 2024, 3:50
Search here:
https://www.hddoracle.com/
PostPosted: October 22nd, 2024, 12:16
Website blocked?
PostPosted: October 23rd, 2024, 1:17
Use a VPN?
