 Post subject: 0MB
PostPosted: November 5th, 2024, 8:28
can anyone helps me solve this problem i have WD 500G and the log as follows:
Family:................................. : FBLite 2.5"
Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM:
System controller (SoC)................. : 88i9446C0 0x(A5C0)
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 157 987
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA SPT.................................. : 1437
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 16.7CG
Module 4F F/W version................... : 0016007C
Overlay F/W version..................... : 16.7CG
Servo F/W version....................... : N0.41
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Relocations............................. : 0 (0)
Read ROM DCM............................ : Ok
Power up log reading.................... : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : No
Power up load CFG data.................. : No
NN | Step | Time | Flags | Info | Description
19 | 105 | 21.84 s | 3F | 514051AD | EXEC_POWERUP_LOAD_DIR_DATA(DISK ECC ERROR LDPC ITR UNCORR ERR)
Service area:
SA dir reading (ID)..................... : Module ID 01 reading error: Drive readiness timeout 10000 ms.
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 157 987 C:1(1) reading error Device Error Detected: "VSC ERR UNSUP ACTION CODE"
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Module ID 02 reading error Device Error Detected: "FM ERR NOT FOUND IN DIR"
DCM in module 47........................ : ZY
DCM in module 0A........................ : |Q|HZYN1H6
DCM in module 02........................ :
 Post subject: Re: 0MB
PostPosted: November 5th, 2024, 12:09
weak heads, wrong pcb, shifted sa (not probable)?
PostPosted: November 6th, 2024, 2:15
Thanks for the reply pepe
I Swamped the rom to other working PCB and it spins fine, So should i change the heads or is there any way to work without opening the drive? Please advise me.
Thanks.
PostPosted: November 6th, 2024, 14:23
have you confirmed rom is native?
PostPosted: November 8th, 2024, 21:59
To check is ROM original or not compare WWN in ROM module 0x0D with WWN on the disk label.
Users browsing this forum: No registered users and 104 guests
