 Post subject: SSD eraser question
PostPosted: December 8th, 2024, 8:13
Hi
I have got a work of secure eraser work of 100 odd ssd's
Unlike CMR hard disks there is no chances of remnant data recovery on defect lists with SSD.
I would like to know is it technically ok to single pass overwrite., so that I can quote for the same.
Thank you.
 Post subject: Re: SSD eraser question
PostPosted: December 8th, 2024, 8:43
Single pass overwrite potentially leaves you with overprovisioned space. Writing zeros potentially leaves you with lots of unaffected data due to advanced firmware detecting zeros and simply add place-holders in FTL. Zero filling overwriting virtually nothing due to firmware level compression. Why not use built-in secure erase, crypto erase etc.?
PostPosted: December 8th, 2024, 11:17
Thanks a lot Joep
Do I need third party tools or manufacturer utility
to initiate secure eraser.
Cusomer wants reports of each eraser like model, fw, sn, erasing date / time
Technique used and time required etc.
PostPosted: December 8th, 2024, 15:44
Maybe a tool like KillDisk will make your life easier but I personally believe your client wants to purchase peace of mind with that certificate.
PostPosted: December 12th, 2024, 1:06
Exactly ,even client suggested this.
Is there any universal secure /crypto erase tool irrespective of make of SSD ? For large volume of disks its not practical to check each ssd & erase it using manufacturer supplied tools (not all tools are self bootable as well)
PostPosted: December 12th, 2024, 1:33
IIRC, the ATA standard has sanitize and cryptoerase commands. These are universal, ie not vendor specific.
PostPosted: December 14th, 2024, 6:50
Thanks a lot fzabkar , I have used killdisk as I think its too clumsy to boot large (different types ) of laptops using linux & issue commands onsite.
There should be a readymade live bootable pen drive having interface , logging to perform the same. Besides that I read that not all models support secure erase.
PostPosted: December 17th, 2024, 2:53
Well,
Older versions of killdisk was able to work with several hard drives without a license
PostPosted: December 17th, 2024, 10:56
Well,
Thanks do you know any commercial software solution which implements secure eraser
PostPosted: December 17th, 2024, 11:49
Well,
Well,
i use only killdisk ver 10.2.7 and thats about it i also have a commercial Cyber forensic tool hardware that i use just for erasing
Users browsing this forum: No registered users and 21 guests
