 Post subject: DT01ACA AND DT01ABA CROSS COMP.
PostPosted: November 18th, 2024, 13:50
Hi guys,
I've seen references toshiba sheets about these two series. About hardware, rotational speed are different (respectively 7200 rpm the first and 5940 / 5700 rpm).
I was wondering if their headsets are cross comptible, and I would like to try this on a couple of these hdd (aca300 aba300)
So just to share opinion and experience, this is my question:
Has allready someone of you tryied if C.C. is possible among their headsets?
Thank you in advance for advices and opinions
 Post subject: Re: DT01ACA AND DT01ABA CROSS COMP.
PostPosted: November 18th, 2024, 15:04
I've heard that people have been able to use 7200RPM WD heads in 5400RPM WD drives and vice versa. Whilst I have no experience in head swaps, I would think that a head that was designed to fly at a particular height in a 7200RPM drive would fly lower in a 5400RPM drive, and vice versa.
PostPosted: November 18th, 2024, 16:26
Thank you for your answer.
I with examine carefully both headset and update this post
PostPosted: November 19th, 2024, 20:20
the tangential velocity difference between ID and OD is far more than between 5400 and 7200. And a lot of heads are interchangeable and even more if you know how to trick the fw.
PostPosted: November 19th, 2024, 21:11
A 5400RPM head will fly lower than a 7200RPM head at the same physical location, would it not? So, for a particular head, the lowest fly height at 5400 RPM will be lower than the lowest fly height at 7200 RPM.
PostPosted: December 12th, 2024, 7:28
Hi everybody and in particular those little who wanted to take part to this topic.
Just to give an update to this case.
So...
yes! it worked.
98% of fs data recovered with oneshot head swap.
Cross comp verifyied
Thanks to all and best regards
PostPosted: December 17th, 2024, 3:00
Frank ,
if heads are compatible then fw will adjust fly height wont it ? . in a 5400 rpm it will be different and in 7200 it will be different ,So FW will do this adjustment not the physical HSA ?
PostPosted: December 17th, 2024, 3:12
there can be slight differences. sliders look the same, but who bothered measuring spring force yet? Anyway, they usually work for recovery, however, HGST is picky about preamp type too, so that may be another culprit to work around...
PostPosted: December 17th, 2024, 3:22
Well,
i have never experienced hgst being picky about preamp .
PostPosted: December 17th, 2024, 16:30
tried to swap heads between families? like F9, G9, H9?
heads are basically the same but FW fails on preamp id...
can be tricked btw, but still...
well, right, other brands might be picky too, in that sense :)
PostPosted: December 18th, 2024, 2:36
Here we are taking about only " DT01ACA AND DT01ABA "
PostPosted: December 18th, 2024, 17:51
FYI: I have used 5K1000-XXX donor heads in 7K1000-XXX series 2.5" HGST drives many times without issues.
Users browsing this forum: jimmydata and 106 guests
