 Post subject: File Recovery Challenge - Drives not shown on system
PostPosted: December 18th, 2024, 14:08
Hello forum,
I have at least 5 or 6 USB failed PenDrives/Memory Cards (flash drives) that happened to become faulty a few years ago. Let me explain in detail what happened:
1. Everything began with the acquisition of a brand new 128 Gb PNY conventional USB flash drive bought in BestBuy because this means I assume it was in perfect reliable condition, without any falsifying or otherwise misusing attempts on its original package from supplier and vendor.
2. The USB drive at first appeared to be just like any other ordinary USB flash drive and to work properly back in 2016
3. I had another SanDisk USB flash drive without problems either - but then I made the worst mistake possible:
4. I copied the original SanDisk files and folders to this new 128 Gb PNY USB flash drive in order to encrypt this new 128 Gb PNY flash drive with the Sandisk SecureAccess encrypting program. I executed and encrypted the SanDisk program in this new 128 Gb PNY USB flash drive because I didn't want it to be readable by other people at my work, where it was supposed to be used as my backup unit.
5. The program didn't seem to have worked as expected and this new PNY 128 Gb USB flash drive started to present weird behaviors on an unreliable basis, sometimes being recognized by the computer and sometimes not. Everytime the flash drive was recognized it was readable and writable without encryption neither requiring the password typed by the encryption process.
6. Since then this USB flash drive became unrecognized by any PC, remaining unreadable and unwriteable. It is seldom recognized by the PC when plugged in and it was never used again ever since, despite being full of files I'd like to recover.
7. To make matters even worse (if this is possible) it seems that my CPU at work got infected with a version of the autorun.inf virus and the HDD failed one day in 2018, causing its replacement with everything implied with it: Windows 10 reinstallation with all drivers determining USB communication specificities. Recently I was wondering if this HDD could have been damaged by the virus as well and rendered completely useless just like the flash drives in my possession, which are the focus of the article.
8. I received the CPU back from my work's maintenance department (which no longer exists) with a new 2Tb HDD which is still working fine since then, but the unreliable USB behavior of these flash drives became progressively worse and worse until all of them seem to have been rendered useless, to the point of not being recognized by Windows either on Windows' Disk Management tool.
9. Today I'm already resigned myself to have lost these expensive USB flash drives. Now I have 5 or 6 old USB flash drives, some of them which were used in my personal portable devices and are now completely useless.
10. In an attempt to rescue these faulty USB flash drives I've downloaded dozens of programs which promised to repair them, including TestDisk, Recuva portable, ChipGenius, HDDScan, HPUSBDisk, RmPrep and other not-so-known software, all of them without success. All of the USB flash drives now are seldom recognized neither by Windows Explorer nor by Windows Disk Management Tool nor by TestDisk nor by (for now) any other programs, except those aimed to retrieve firmware information or other identification details of these devices, and show a drive empty space of 0b. Sometimes I'm lucky enough one or other program(s) is able to recognize the drive's presence, but always as a ghost drive with 0 bytes inaccessible for them or either for Windows 10 itself. In fact, it seems they become more and more unresponsive for windows and equally for other diagnostic software the more frequently they are plugged in and out of the USB port(s), as to be deducted from the attached screenshots.
The ideal scenario is the ability to be able to use them again like if they never presented any problems. Because of all these problems, however, I have already given up this hope, and simply rescuing their files would be enough for me.
Any help is greatly appreciated.
Leonardo.
 Post subject: Re: File Recovery Challenge - Drives not shown on system
PostPosted: December 18th, 2024, 19:58
NAND bleeds data so they haven't got any better since. For the rest this is TL;DR and I have the feeling I have seen the exact same post before (Reddit perhaps?). If it's not about the data you can try MPtools if you have nothing better to do. This will require some study on your part. The whole project is basically a waste of time.
Users browsing this forum: No registered users and 29 guests
