 Post subject: Recover Formatted Sandisk Flash
PostPosted: January 9th, 2025, 16:16
I got old formatted sandisk micro cruzer usb.
chip-off and found ECC but it is encrypted.
If I soldering back to the device with new data(ECC made), is there some chance to recover original data?
The device was working well but could not recover without chip-off.
I never tried this way and I have totally no idea if it is possible or not.
If there is another way to recover or any advices, please let me know.
 Post subject: Re: Recover Formatted Sandisk Flash
PostPosted: January 9th, 2025, 17:45
https://forum.hddguru.com/viewtopic.php ... write+back
PostPosted: January 10th, 2025, 12:10
Thanks a lot Arvika
PostPosted: January 10th, 2025, 18:04
Because?
PostPosted: January 11th, 2025, 10:27
It was formatted
Hex shows all zeros
Is there any recover process to try?
PostPosted: January 11th, 2025, 11:57
Hex shows all zeros
Well, that is a problem and if you did actually mention that I missed it.
An old flash drive? How was encryption determined then?
PostPosted: January 12th, 2025, 5:01
Checked from FE library
Told it was light formatted so I tried chip-off
The controller is encrypt
Sandisk U3 without password
PostPosted: January 13th, 2025, 9:31
What controller? Could you link to the FE library entry?
A quick formatted USB flash drive is what we're talking about, right? And you went straight to chip-off? I don't see the logic in that.
