 Post subject: ST1000LM014-SSHD-8GB FW:LVD5 Rom needed
PostPosted: January 15th, 2025, 5:19
I need rom for
Pm me plz
 Post subject: Re: ST1000LM014-SSHD-8GB FW:LVD5 Rom needed
PostPosted: January 15th, 2025, 8:37
ROM HDD Seagate is unique for each disk. Someone else's ROM will not help you.
PostPosted: January 15th, 2025, 8:46
SWM, original rom is corrupted i need working rom to rebuild
PostPosted: January 15th, 2025, 9:11
What are these conclusions from? It would be a good idea to look at what was read from the ROM.
If you physically damaged the ROM chip, you can crack nuts with the disk...
Or into a green bucket... 8)
PostPosted: January 15th, 2025, 9:40
SWM, did you know the failure conditions for this model of hard drive ?
Nand failure ... Famular
Rom failure ... Unique
Since i dosent have rom with same FW i cannot rebuild working rom because of mismatched overlay
I hope that repaly make it clear for you :)
PostPosted: January 15th, 2025, 11:20
KiTHardWare,
Now yes.
Well, you could have written it like this: I have the extracted original CAP, RAP, SAP. I need everything else.
PostPosted: January 15th, 2025, 13:00
SWM wrote:
KiTHardWare,
Now yes.
Ok..
PostPosted: January 15th, 2025, 14:57
Can you upload your corrupt ROM? Sometimes there are redundant copies.
PostPosted: January 16th, 2025, 2:16
It doesn't exist in this universe...
PostPosted: January 16th, 2025, 3:33
Sorry, I should have said that "sometimes there are redundant copies of the damaged segment (s)".
For example, some ROMs are comprised of two halves, with the same code segments in each half. In other cases, the extra space at the end of the ROM sometimes contains full or partial copies of certain segments.
PostPosted: January 16th, 2025, 14:17
I wanted to say that the native ROM was probably destroyed before this topic started...
That's my opinion. Sorry.
PostPosted: January 20th, 2025, 18:03
thx my bro i already solve this case i pm you with the original rom for research purposes
PostPosted: January 21st, 2025, 2:53
it was an easy repair
Users browsing this forum: Google [Bot], Hardcore Games and 89 guests
