Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: SEAGATE ST3500320AS
PostPosted: January 16th, 2025, 21:48
It looks like this early firmware doesn't support the r/w commands.
If you proceed with DIY, then the "F" commands are your best bet. The SMART dump shows 100% for the Reallocated Sector Count and Current Pending Count, so perhaps head #0 might still be able to be cloned.
PostPosted: January 17th, 2025, 6:22
There are no r and w commands on ST3500320AS.
and, even if you could back them up, that's just one step, this alone doesn't get you closer to your data. Without tools and knowledge it is a real pain to recover a drive with such problem.
On the contrary, with tools and knowledge it should be relatively easy to do it with confidence. In the current state. Before it gets worse.
edit: sorry i missed to see the last post...
PostPosted: January 17th, 2025, 14:19
Small update
Today I've connected my drive to an old motherboard from year 2007 and asus BIOS recognized drive with correct size right away. That got a smile on my face.
Although when starting HDDLiveCD I got a lot of complaining about bad sectors. Pretty much it is complaining all the time about a bunch of same sectors
    63
    64
    257
    515
    2050
    4096
    976773104
    976772992
    976773152
    976773160
After a lot of complaining, Ubuntu starts and I can even start HDDSuperClone.
I did not execute the F commands yet.
Small question, if I execute F commands is this reversible (maybe through DR company) or is it irreversible forever?
Thank you very much for your selfless help.
PostPosted: January 17th, 2025, 18:43
Your prospects don't look good. Those sectors are where the partition and file system metadata are usually located.
As for the "F" commands, expensive professional tools such as PC3000 issue those same commands, or directly modify the corresponding sys file. Each command can be reversed by flipping the respective bit.
PostPosted: January 18th, 2025, 12:45
That makes sense.
After running HDDSuperClone for several minutes, I checked the destination drive and found that it was intact with old partitions when they should be new.
Clone11.log [19.15 KiB]
Downloaded 213 times
Do you vote for running F commands, or should I send the drive to the DR specialist?
PostPosted: January 18th, 2025, 15:20
At the current rate you will torture your drive to death with HDDSC. If you wish to persist with DIY, at least for a short time, then the "F" commands are your only option. If the speed improves after doing this, then you will need to make a decision. I'm not a data recovery professional, so I don't want your business.
PostPosted: January 18th, 2025, 16:29
You mean if the speed improves after F commands, I have to make a decision if I want to gamble and proceed with HDDSC risking dead hard drive or stop it and take the bastard to the pro?
He, he, from my point of view, your knowledge and your willing to help is beyond any professional. :good:
I will make some more testing with another drive and after that I will make a decision.
What bothers me the most is the fact that I only need a couple of Megs from that 500 Gigs.
But as they say no risk, no fun. :D
PostPosted: January 18th, 2025, 17:33
If you are willing to accept the risk, run the "F" commands at level T, then continue with HDDSC. If the speed improves, then you will need to decide if you want to keep going with HDDSC. If the speed doesn't improve, then a pro may be your only option. I think there is a Slovenian member who goes by the name of "jerovsek".
I have written a ZOC script which automates the sending of those commands. There is a thread on this subject at hddoracle.com.
PostPosted: January 18th, 2025, 17:37
Thank you.
PostPosted: January 18th, 2025, 18:39
wondering why ignoring any realistic diagnosis/help from professionals and hyping the not experienced-in-the-field advice is a wise decision here.
the log file from HDDSC clearly testifies what i and SWM wrote days ago. Perfect example of ppl hear what they wanna hear.
PostPosted: January 18th, 2025, 19:51
ISTM that the error rate is 1 in 9,000. Shouldn't that give the OP some hope for a DIY solution?
Finished     453630
Non-tried    976313392
Non-trimmed  6096
Non-divided  0
Non-scraped  0
Bad          50
PostPosted: January 19th, 2025, 6:46
Stop playing sulking cat :D . Your help is very much appreciated too. You already helped me much more than you think.
It appears that you have enough information about my dodgy drive.
Could you send me an offer on PM, how much will DR cost me, and where are you located?
PostPosted: January 19th, 2025, 10:04
@fzabkar:
HDDSC log is full of 51/40 errors and skips,(if i read it correctly). the drive can't read from H0. No F command will change that.
The clone drive contains the original data, nothing cloned.
@Piper: licking my wounds for a few more days... :)
my contact is in signature. But this is not an insanely difficult case, i am sure you can find a local dr service, you could ask Jerovsek as Franc advised.
PostPosted: January 20th, 2025, 7:01
Could you please let me know if the drive requires head replacement or the data can still be retrieved with some magic PC3K commands?
PostPosted: January 20th, 2025, 14:41
The pros are saying that you probably won't clone more than 75% (your drive has 4 heads, I think).
PostPosted: January 21st, 2025, 3:03
@Piper: As Franc says, if i interpret logs correctly, drive likely needs new heads, at least for H0. The others might clone well, but in any case, they need to be inspected for contamination or other damage to minimize the risk of further damage.
PostPosted: January 21st, 2025, 7:53
Thank you for the info.
That's a completely different thing in terms of $$ than if the drive does not need to be opened.
PostPosted: January 21st, 2025, 10:49
OK, here is how the things stands.
@Pepe was right.
I did download F commands to the drive and gave HDDSC a try.
HDDSC has stopped by itself, saying that there are too many skipped files.
I was not able to retrieve any data, destination drive is empty.
No more DIY, a specialist in DR is needed :( .
# Disk progress log file created by HDDSuperClone version 2.3.3_20220430
# 2025-01-21_15.04.13.309557
# command= hddsuperclone
# Current/Recent/Longest 0 ms / 19048 ms / 19048 ms
# Logfile: /media/xubuntu/PATRIOT/Ubuntu/Clone11
# 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
#      Source:   /dev/sda (ST3500320AS, 9QM07BVR)
# #Destination:   /dev/sdb (ST2000NM0033-9ZM175, Z1X47BHZ)
#   Total LBA:  976773168        LBA to read:  976773168
#    Run time: 0:00:14:08        Remaining:  28:08:01:00
#        Rate:          0 B/s    Recent: 199 KB/s  Total: 357 KB/s
#   Skip size:       4096  Skips: 136  Slow: 69  Runs: 7  Resets: 1  Run size: 31950694
#    Position:   33815531        Status:    Phase 1
#    Finished:     591848 (149 areas 0.060592%)
#   Non-tried:  976171000 (167 areas 99.938354%)
# Non-trimmed:      10256 (101 areas 0.001050%)
# Non-divided:          0 (0 areas 0.000000%)
# Non-scraped:          0 (0 areas 0.000000%)
#         Bad:         64 (64 areas 0.000007%)
################ START CONFIGURATION DATA ################
# startconfig
# logfile     /media/xubuntu/PATRIOT/Ubuntu/Clone11
# source     /dev/sda
# destination     /dev/sdb
# verbose     0x0
# debug     0x0
# forcemounted     0
# forcedangerous     0
# importdd     0
# exportdd     0
# dodomain     0
# domaindd     0
# domainfile     /media/xubuntu/PATRIOT/Ubuntu/Clone11.domain
# repairlog     0
# nologbackup     0
# phaselogs     0
# softtimer     8000000
# hardtimer     800000
# busytimer     20000000
# initbusytimer     8000000
# resettimer     8000000
# generaltimer     60000000
# phasetimers     0
# p12softtimer     250000
# p3softtimer     350000
# p4softtimer     500000
# tdsofttimer     800000
# d2softtimer     800000
# scsofttimer     800000
# rtsofttimer     8000000
# alwayswaitresettime     0
# usbbulkreset     1
# usbsoftreset     0
# usbhardreset     0
# usbportreset     1
# imagesource     0
# genericsource     0
# atapass     1
# scsipass     0
# skipfast     0
# skiptimer     1000000
# direct     0
# ahci     0
# usb     0
# nophase1     0
# nophase2     0
# nophase3     0
# nophase4     0
# notrim     0
# nodivide1     0
# dodivide2     0
# notrim     0
# noscrape     0
# markbadhead     0
# readbadhead     1
# rebuildassist     1
# clustersize     128
# blocksize     1
# sectorsize     512
# blockoffset     0
# maxreadrate     0
# retries     0
# retried     0
# inputoffset     0
# outputoffset     -1
# size     976773168
# rateskip     50000
# exitonslow     -1000
# exitonslowtime     -1000
# minskip     4096
# maxskip     9767731
# reverse    0
# fillmode     0
# fillmark     0
# findserial
# quiet     0
# forcestupid     0
# model     ST3500320AS
# serial     9QM07BVR
# skipsize     4096
# skips     136
# slowskips     69
# skipruns     7
# skipresets     1
# stoponerror     0
# callcommand     0
# commandtocall
# primaryrelayonerror     0
# callpowercommand     0
# powercommandtocall
# primaryrelaypowercycle     0
# writebufferdisable     0
# writebufferenable     0
# driverreturnerror     0
# driverreturnzeros     0
# driverreturnmarked     0
# driverdiskname     sdv
# driverminclustersize     1
# disableidentify     0
# piomode     0
# enablerebuildassist     0
# enableprocesschunk     1
# enablereadtwice     0
# enableretryconnecting    0
# enablescsiwrite     0
# sectorsizeadjust     0
# ioscsionly     0
# usephysicalsectorsize     0
# colorstatusbar     0
# primerelayactivatetime     3
# primerelaydelaytime     15
# primerelaysettings     0xff00
# endconfig
################ END CONFIGURATION DATA ################
################ START ANALYZE DATA ################
# startanyalyze
# Good = 0.000000%
# Bad = 100.000000%
# Slow = 0.000000%
# Slow Responding Firmware Issue = 0.000000%
# Partial Access Issue = 100.000000%
# Bad Or Weak Head = 100.000000%
# (1504) Variance read times low/high:
#     30/32  30/35  28/32  28/32  29/32  30/32  30/32  30/32
#     30/32  30/32  30/32  28/49  29/32  31/34  29/35  30/32
#     31/35  31/32  29/32  29/34  31/33  29/32  31/34  31/35
#     31/32  31/88  31/34  29/34  31/36  29/32  31/32  28/34
# Zones   Total 32    Good 0    Bad 32 (0)    Slow 0    Low 4551    High 6336    Average 4826
# Zone 0    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 6336    High 6336    Average 6336
# Zone 1    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4686    High 4686    Average 4686
# Zone 2    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4869    High 4869    Average 4869
# Zone 3    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4676    High 4676    Average 4676
# Zone 4    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4995    High 4995    Average 4995
# Zone 5    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4745    High 4745    Average 4745
# Zone 6    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4964    High 4964    Average 4964
# Zone 7    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4839    High 4839    Average 4839
# Zone 8    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4662    High 4662    Average 4662
# Zone 9    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4563    High 4563    Average 4563
# Zone 10    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4978    High 4978    Average 4978
# Zone 11    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4849    High 4849    Average 4849
# Zone 12    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4781    High 4781    Average 4781
# Zone 13    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4708    High 4708    Average 4708
# Zone 14    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 5001    High 5001    Average 5001
# Zone 15    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 5180    High 5180    Average 5180
# Zone 16    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 5007    High 5007    Average 5007
# Zone 17    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4762    High 4762    Average 4762
# Zone 18    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4622    High 4622    Average 4622
# Zone 19    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4616    High 4616    Average 4616
# Zone 20    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4760    High 4760    Average 4760
# Zone 21    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4761    High 4761    Average 4761
# Zone 22    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4767    High 4767    Average 4767
# Zone 23    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4782    High 4782    Average 4782
# Zone 24    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4813    High 4813    Average 4813
# Zone 25    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4675    High 4675    Average 4675
# Zone 26    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4598    High 4598    Average 4598
# Zone 27    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4680    High 4680    Average 4680
# Zone 28    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4685    High 4685    Average 4685
# Zone 29    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4551    High 4551    Average 4551
# Zone 30    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4940    High 4940    Average 4940
# Zone 31    Total 1    Good 0    Bad 1 (0)    Slow 0    Low 4581    High 4581    Average 4581
# endanalyze
################ END ANALYZE DATA ################
################ START SMART DATA ################
# startsmart
# SMART data structure version 10
# ID       Flags     Current     Worst     Threshold     Raw data         Attribute name
# 001     0x000f      100     100     006     0x0000000007552a       Read Error Rate
# 003     0x0003      093     093     000     0x00000000000000       Spin-Up Time
# 004     0x0032      100     100     020     0x00000000000030       Start/Stop Count
# 005     0x0033      100     100     036     0x0000000000019c       Reallocated Sectors Count
# *** WARNING *** Reallocated Sectors Count = 412
# 007     0x000f      100     253     030     0x000018000009b5       Seek Error Rate
# 009     0x0032      035     035     000     0x0000000000df95       Power-On Hours Count
# 010     0x0013      100     100     097     0x00000000000000       Spin Retry Count
# 012     0x0032      100     044     020     0x00000000000034       Power Cycle Count
# 184     0x0032      100     100     099     0x00000000000000       End-to-End error
# 187     0x0032      001     001     000     0x00000000000543       Reported Uncorrectable Errors
# 188     0x0032      100     091     000     0x000000000b000e       Command Timeout
# 189     0x003a      001     001     000     0x00000000000b04       High Fly Writes
# 190     0x0022      073     069     045     0x0000001b16001b       Temperature
# 194     0x0022      027     040     000     0x00000d0000001b       Temperature
# 195     0x001a      100     100     000     0x0000000007552a       Hardware ECC Recovered
# 197     0x0012      100     100     000     0x0000000000021a       Current Pending Sectors
# *** WARNING *** Current Pending Sectors = 538
# 198     0x0010      100     100     000     0x0000000000021a       Off-line Uncorrectable
# 199     0x003e      200     200     000     0x00000000000000       UDMA CRC Error Rate
# endsmart
################ END SMART DATA ################
################ START IDENTIFY DEVICE INFO ################
# 0: 5a 0c ff 3f 37 c8 10 00 00 00 00 00 3f 00 00 00 Z..?7.......?...
# 10: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20 ....
# 20: 51 39 30 4d 42 37 52 56 00 00 00 00 04 00 44 53 Q90MB7RV......DS
# 30: 34 30 20 20 20 20 54 53 35 33 30 30 32 33 41 30 40    TS530023A0
# 40: 20 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20  S
# 50: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80               ..
# 60: 00 00 00 2f 00 40 00 02 00 02 07 00 ff 3f 10 00 .../.@.......?..
# 70: 3f 00 10 fc fb 00 10 01 ff ff ff 0f 00 00 07 00 ?...............
# 80: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 ..x.x.x.x.......
# 90: 00 00 00 00 00 00 1f 00 06 05 00 00 40 00 40 00 ............@.@.
# a0: f0 00 00 00 6b 34 01 7d 23 41 29 34 01 bc 03 41 ....k4.}#A)4...A
# b0: 7f 40 00 00 00 00 fe fe fe ff 00 00 00 fe 00 00 .@..............
# c0: 00 00 00 00 00 00 00 00 30 60 38 3a 00 00 00 00 ........0`8:....
# d0: 00 00 00 00 00 00 00 00 00 50 00 c5 a2 09 50 35 .........P....P5
# e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 40 ...............@
# f0: 06 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
# 100: 29 00 30 60 38 3a 30 60 38 3a 00 00 02 00 40 01 ).0`8:0`8:....@.
# 110: 00 01 00 50 06 3c 0a 3c 00 00 3c 00 00 00 08 00 ...P.<.<..<.....
# 120: 00 00 00 00 0f 00 80 02 00 00 00 00 08 00 00 00 ................
# 130: 00 00 00 00 00 00 00 00 00 00 00 00 00 27 00 80 .............'..
# 140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 190: 00 00 00 00 00 00 00 00 00 00 00 00 3b 00 00 00 ............;...
# 1a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1b0: 00 00 20 1c 00 00 00 00 00 00 00 00 00 00 00 00 .. .............
# 1c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 1f ................
# lba supported = yes
# 48 bit supported = yes
# smart supported = yes
# smart enabled = yes
# security locked = no
# rebuild assist supported = no
################ END IDENTIFY DEVICE INFO ################
# current position         status
0x203fbeb               0x0
# position    size        status    info    err/status/time
0x000000    0x000080    0x10    0x0    0x405105
0x000080    0x000080    0x10    0x0    0x405106
0x000100    0x000023    0x7f    0x0    0x0
0x000123    0x000001    0x40    0x80    0x405106
0x000124    0x00005c    0x10    0x80    0x405106
0x000180    0x001000    0x0    0x0    0x0
0x001180    0x000001    0x40    0x81    0x405104
0x001181    0x00007f    0x10    0x81    0x405104
0x001200    0x001c01    0x0    0x0    0x0
0x002e01    0x00000e    0x7f    0x0    0x7
0x002e0f    0x000001    0x40    0x82    0x405108
0x002e10    0x000071    0x10    0x82    0x405108
0x002e81    0x0027ff    0x0    0x0    0x0
0x005680    0x000080    0x7f    0x83    0x5002
0x005700    0x0031c4    0x0    0x0    0x0
0x0088c4    0x00002b    0x7f    0x0    0x1
0x0088ef    0x000001    0x40    0x84    0x405106
0x0088f0    0x000054    0x10    0x84    0x405106
0x008944    0x003931    0x0    0x0    0x0
0x00c275    0x000080    0x10    0x85    0x405107
0x00c2f5    0x003e4c    0x0    0x0    0x0
0x010141    0x000001    0x40    0x86    0x405104
0x010142    0x00007f    0x10    0x86    0x405104
0x0101c1    0x0041be    0x0    0x0    0x0
0x01437f    0x000001    0x40    0x87    0x405105
0x014380    0x00007f    0x10    0x87    0x405105
0x0143ff    0x004411    0x0    0x0    0x0
0x018810    0x000002    0x7f    0x0    0x1
0x018812    0x000001    0x40    0x88    0x405106
0x018813    0x00007d    0x10    0x88    0x405106
0x018890    0x004668    0x0    0x0    0x0
0x01cef8    0x016680    0x7f    0x0    0x0
0x033578    0x000080    0x7f    0x80    0x5001
0x0335f8    0x001000    0x0    0x0    0x0
0x0345f8    0x000400    0x7f    0x0    0x0
0x0349f8    0x000080    0x7f    0x81    0x5001
0x034a78    0x001c01    0x0    0x0    0x0
0x036679    0x000080    0x7f    0x82    0x5001
0x0366f9    0x0027ff    0x0    0x0    0x0
0x038ef8    0x0002f4    0x7f    0x0    0x0
0x0391ec    0x000001    0x40    0x83    0x405105
0x0391ed    0x00000b    0x10    0x83    0x405105
0x0391f8    0x0031c4    0x0    0x0    0x0
0x03c3bc    0x000080    0x7f    0x84    0x5004
0x03c43c    0x003931    0x0    0x0    0x0
0x03fd6d    0x000100    0x7f    0x0    0x0
0x03fe6d    0x00006f    0x7f    0x0    0x1
0x03fedc    0x000001    0x40    0x85    0x405105
0x03fedd    0x000010    0x10    0x85    0x405105
0x03feed    0x003e4c    0x0    0x0    0x0
0x043d39    0x000200    0x7f    0x0    0x0
0x043f39    0x000080    0x7f    0x86    0x5001
0x043fb9    0x0041be    0x0    0x0    0x0
0x048177    0x000080    0x7f    0x87    0x5002
0x0481f7    0x004411    0x0    0x0    0x0
0x04c608    0x000080    0x7f    0x88    0x5001
0x04c688    0x004668    0x0    0x0    0x0
0x050cf0    0x02b400    0x7f    0x0    0x0
0x07c0f0    0x000080    0x7f    0x80    0x5001
0x07c170    0x001000    0x0    0x0    0x0
0x07d170    0x000b00    0x7f    0x0    0x0
0x07dc70    0x000080    0x7f    0x81    0x5002
0x07dcf0    0x001c01    0x0    0x0    0x0
0x07f8f1    0x000080    0x7f    0x82    0x5001
0x07f971    0x0027ff    0x0    0x0    0x0
0x082170    0x000400    0x7f    0x0    0x0
0x082570    0x000080    0x7f    0x83    0x5002
0x0825f0    0x0031c4    0x0    0x0    0x0
0x0857b4    0x000080    0x7f    0x84    0x5001
0x085834    0x003931    0x0    0x0    0x0
0x089165    0x00008b    0x7f    0x0    0x0
0x0891f0    0x000001    0x40    0x85    0x405104
0x0891f1    0x000074    0x10    0x85    0x405104
0x089265    0x003e4c    0x0    0x0    0x0
0x08d0b1    0x0001e9    0x7f    0x0    0x0
0x08d29a    0x000001    0x40    0x86    0x405104
0x08d29b    0x000016    0x10    0x86    0x405104
0x08d2b1    0x0041be    0x0    0x0    0x0
0x09146f    0x000600    0x7f    0x0    0x0
0x091a6f    0x000080    0x7f    0x87    0x5001
0x091aef    0x004411    0x0    0x0    0x0
0x095f00    0x019200    0x7f    0x0    0x0
0x0af100    0x000080    0x7f    0x80    0x5001
0x0af180    0x001104    0x0    0x0    0x0
0x0b0284    0x000080    0x7f    0x81    0x5002
0x0b0304    0x001dc8    0x0    0x0    0x0
0x0b20cc    0x000080    0x7f    0x82    0x500d
0x0b214c    0x002a89    0x0    0x0    0x0
0x0b4bd5    0x000080    0x7f    0x83    0x5010
0x0b4c55    0x0034ec    0x0    0x0    0x0
0x0b8141    0x000080    0x7f    0x84    0x500c
0x0b81c1    0x003cd2    0x0    0x0    0x0
0x0bbe93    0x000080    0x7f    0x85    0x5007
0x0bbf13    0x004240    0x0    0x0    0x0
0x0c0153    0x000080    0x7f    0x86    0x5009
0x0c01d3    0x0045ea    0x0    0x0    0x0
0x0c47bd    0x000080    0x7f    0x87    0x5007
0x0c483d    0x004862    0x0    0x0    0x0
0x0c909f    0x000080    0x7f    0x88    0x5008
0x0c911f    0x004adf    0x0    0x0    0x0
0x0cdbfe    0x000080    0x7f    0x89    0x5002
0x0cdc7e    0x004cff    0x0    0x0    0x0
0x0d297d    0x000080    0x7f    0x8a    0x5005
0x0d29fd    0x004ee1    0x0    0x0    0x0
0x0d78de    0x000080    0x7f    0x8b    0x5008
0x0d795e    0x0050a6    0x0    0x0    0x0
0x0dca04    0x000001    0x40    0x8c    0x405106
0x0dca05    0x00007f    0x10    0x8c    0x405106
0x0dca84    0x005330    0x0    0x0    0x0
0x0e1db4    0x000001    0x40    0x8d    0x405113
0x0e1db5    0x00007f    0x10    0x8d    0x405113
0x0e1e34    0x0055b9    0x0    0x0    0x0
0x0e73ed    0x000080    0x7f    0x0    0x0
0x0e746d    0x000074    0x7f    0x0    0x6
0x0e74e1    0x000001    0x40    0x8e    0x405112
0x0e74e2    0x00000b    0x10    0x8e    0x405112
0x0e74ed    0x005858    0x0    0x0    0x0
0x0ecd45    0x00fc00    0x7f    0x0    0x0
0x0fc945    0x000080    0x7f    0x80    0x5001
0x0fc9c5    0x0016ae    0x0    0x0    0x0
0x0fe073    0x000680    0x7f    0x0    0x0
0x0fe6f3    0x000080    0x7f    0x81    0x5001
0x0fe773    0x0027b1    0x0    0x0    0x0
0x100f24    0x0002f6    0x7f    0x0    0x0
0x10121a    0x000001    0x40    0x82    0x405104
0x10121b    0x000009    0x10    0x82    0x405104
0x101224    0x0038af    0x0    0x0    0x0
0x104ad3    0x000280    0x7f    0x0    0x0
0x104d53    0x000080    0x7f    0x83    0x5001
0x104dd3    0x004686    0x0    0x0    0x0
0x109459    0x000100    0x7f    0x0    0x0
0x109559    0x000080    0x7f    0x84    0x5001
0x1095d9    0x00510b    0x0    0x0    0x0
0x10e6e4    0x000b80    0x7f    0x0    0x0
0x10f264    0x000080    0x7f    0x85    0x5001
0x10f2e4    0x005846    0x0    0x0    0x0
0x114b2a    0x000e58    0x7f    0x0    0x0
0x115982    0x000001    0x40    0x86    0x405105
0x115983    0x000027    0x10    0x86    0x405105
0x1159aa    0x005d25    0x0    0x0    0x0
0x11b6cf    0x000380    0x7f    0x0    0x0
0x11ba4f    0x000080    0x10    0x87    0x405105
0x11bacf    0x00606e    0x0    0x0    0x0
0x121b3d    0x000015    0x7f    0x0    0x2
0x121b52    0x000001    0x40    0x88    0x405108
0x121b53    0x00006a    0x10    0x88    0x405108
0x121bbd    0x0063bb    0x0    0x0    0x0
0x127f78    0x000080    0x7f    0x89    0x5001
0x127ff8    0x00668e    0x0    0x0    0x0
0x12e686    0x000080    0x7f    0x8a    0x5002
0x12e706    0x00690d    0x0    0x0    0x0
0x135013    0x000080    0x7f    0x8b    0x5001
0x135093    0x006b65    0x0    0x0    0x0
0x13bbf8    0x000326    0x7f    0x0    0x0
0x13bf1e    0x000001    0x40    0x8c    0x405104
0x13bf1f    0x000059    0x10    0x8c    0x405104
0x13bf78    0x006ec2    0x0    0x0    0x0
0x142e3a    0x000331    0x7f    0x0    0x0
0x14316b    0x000001    0x40    0x8d    0x405105
0x14316c    0x00004e    0x10    0x8d    0x405105
0x1431ba    0x007220    0x0    0x0    0x0
0x14a3da    0x003480    0x7f    0x0    0x0
0x14d85a    0x000080    0x7f    0x80    0x5001
0x14d8da    0x001b0d    0x0    0x0    0x0
0x14f3e7    0x000f80    0x7f    0x0    0x0
0x150367    0x000080    0x7f    0x81    0x5001
0x1503e7    0x002f57    0x0    0x0    0x0
0x15333e    0x000a00    0x7f    0x0    0x0
0x153d3e    0x000080    0x7f    0x82    0x5001
0x153dbe    0x00439b    0x0    0x0    0x0
0x158159    0x000380    0x7f    0x0    0x0
0x1584d9    0x000080    0x7f    0x83    0x5001
0x158559    0x00541c    0x0    0x0    0x0
0x15d975    0x000080    0x7f    0x84    0x5001
0x15d9f5    0x0060a7    0x0    0x0    0x0
0x163a9c    0x0001ba    0x7f    0x0    0x0
0x163c56    0x000001    0x40    0x85    0x405104
0x163c57    0x000045    0x10    0x85    0x405104
0x163c9c    0x006945    0x0    0x0    0x0
0x16a5e1    0x0002c3    0x7f    0x0    0x0
0x16a8a4    0x000001    0x40    0x86    0x405104
0x16a8a5    0x00003c    0x10    0x86    0x405104
0x16a8e1    0x006f14    0x0    0x0    0x0
0x1717f5    0x000400    0x7f    0x0    0x0
0x171bf5    0x00000e    0x7f    0x0    0x1
0x171c03    0x000001    0x40    0x87    0x405105
0x171c04    0x000071    0x10    0x87    0x405105
0x171c75    0x0072fd    0x0    0x0    0x0
0x178f72    0x000080    0x7f    0x88    0x5002
0x178ff2    0x0076ed    0x0    0x0    0x0
0x1806df    0x000080    0x7f    0x89    0x5004
0x18075f    0x007a49    0x0    0x0    0x0
0x1881a8    0x000001    0x40    0x8a    0x405105
0x1881a9    0x00007f    0x10    0x8a    0x405105
0x188228    0x007d42    0x0    0x0    0x0
0x18ff6a    0x000001    0x40    0x8b    0x405104
0x18ff6b    0x00007f    0x10    0x8b    0x405104
0x18ffea    0x00800d    0x0    0x0    0x0
0x197ff7    0x000001    0x40    0x8c    0x405104
0x197ff8    0x00007f    0x10    0x8c    0x405104
0x198077    0x00840e    0x0    0x0    0x0
0x1a0485    0x000080    0x7f    0x8d    0x5012
0x1a0505    0x008811    0x0    0x0    0x0
0x1a8d16    0x000080    0x7f    0x8e    0x500d
0x1a8d96    0x008c33    0x0    0x0    0x0
0x1b19c9    0x000080    0x7f    0x8f    0x5001
0x1b1a49    0x009074    0x0    0x0    0x0
0x1baabd    0x000172    0x7f    0x0    0x0
0x1bac2f    0x000001    0x40    0x90    0x405104
0x1bac30    0x00000d    0x10    0x90    0x405104
0x1bac3d    0x009648    0x0    0x0    0x0
0x1c4285    0x003200    0x7f    0x0    0x0
0x1c7485    0x000080    0x7f    0x80    0x5001
0x1c7505    0x002346    0x0    0x0    0x0
0x1c984b    0x000800    0x7f    0x0    0x0
0x1ca04b    0x000080    0x7f    0x81    0x5001
0x1ca0cb    0x003dbb    0x0    0x0    0x0
0x1cde86    0x000980    0x7f    0x0    0x0
0x1ce806    0x000080    0x7f    0x82    0x5001
0x1ce886    0x005828    0x0    0x0    0x0
0x1d40ae    0x000580    0x7f    0x0    0x0
0x1d462e    0x000080    0x7f    0x83    0x5001
0x1d46ae    0x006dad    0x0    0x0    0x0
0x1db45b    0x000600    0x7f    0x0    0x0
0x1dba5b    0x000080    0x7f    0x84    0x5001
0x1dbadb    0x007e07    0x0    0x0    0x0
0x1e38e2    0x00006b    0x7f    0x0    0x0
0x1e394d    0x000001    0x40    0x85    0x405106
0x1e394e    0x000014    0x10    0x85    0x405106
0x1e3962    0x008942    0x0    0x0    0x0
0x1ec2a4    0x000143    0x7f    0x0    0x0
0x1ec3e7    0x000001    0x40    0x86    0x405105
0x1ec3e8    0x00003c    0x10    0x86    0x405105
0x1ec424    0x0090d4    0x0    0x0    0x0
0x1f54f8    0x00004e    0x7f    0x0    0x1
0x1f5546    0x000001    0x40    0x87    0x405106
0x1f5547    0x000031    0x10    0x87    0x405106
0x1f5578    0x0095eb    0x0    0x0    0x0
0x1feb63    0x000080    0x7f    0x0    0x0
0x1febe3    0x000010    0x7f    0x0    0x1
0x1febf3    0x000001    0x40    0x88    0x405105
0x1febf4    0x00006f    0x10    0x88    0x405105
0x1fec63    0x009b0a    0x0    0x0    0x0
0x20876d    0x00007f    0x7f    0x0    0x0
0x2087ec    0x000001    0x40    0x89    0x405107
0x2087ed    0x009f68    0x0    0x0    0x0
0x212755    0x000580    0x7f    0x0    0x0
0x212cd5    0x000080    0x7f    0x8a    0x5001
0x212d55    0x00a345    0x0    0x0    0x0
0x21d09a    0x000080    0x7f    0x8b    0x5001
0x21d11a    0x00a6e5    0x0    0x0    0x0
0x2277ff    0x000207    0x7f    0x0    0x0
0x227a06    0x000001    0x40    0x8c    0x405104
0x227a07    0x000078    0x10    0x8c    0x405104
0x227a7f    0x00ac1c    0x0    0x0    0x0
0x23269b    0x000083    0x7f    0x0    0x0
0x23271e    0x000001    0x40    0x8d    0x405104
0x23271f    0x00007c    0x10    0x8d    0x405104
0x23279b    0x00b151    0x0    0x0    0x0
0x23d8ec    0x0000a4    0x7f    0x0    0x0
0x23d990    0x000001    0x40    0x8e    0x405104
0x23d991    0x00005b    0x10    0x8e    0x405104
0x23d9ec    0x00b6ae    0x0    0x0    0x0
0x24909a    0x000004    0x7f    0x0    0x2
0x24909e    0x000001    0x40    0x8f    0x405108
0x24909f    0x00007b    0x10    0x8f    0x405108
0x24911a    0x00bc36    0x0    0x0    0x0
0x254d50    0x000007    0x7f    0x0    0x4
0x254d57    0x000001    0x40    0x90    0x405108
0x254d58    0x000078    0x10    0x90    0x405108
0x254dd0    0x00c3ca    0x0    0x0    0x0
0x26119a    0x000001    0x40    0x91    0x405105
0x26119b    0x00007f    0x10    0x91    0x405105
0x26121a    0x00cbaf    0x0    0x0    0x0
0x26ddc9    0x000001    0x40    0x92    0x405105
0x26ddca    0x00007f    0x10    0x92    0x405105
0x26de49    0x00d3e5    0x0    0x0    0x0
0x27b22e    0x0003d2    0x7f    0x0    0x0
0x27b600    0x000001    0x40    0x93    0x405104
0x27b601    0x00002d    0x10    0x93    0x405104
0x27b62e    0x00dc70    0x0    0x0    0x0
0x28929e    0x0002e9    0x7f    0x0    0x0
0x289587    0x000001    0x40    0x94    0x405104
0x289588    0x000016    0x10    0x94    0x405104
0x28959e    0x00e788    0x0    0x0    0x0
0x297d26    0x000100    0x7f    0x0    0x0
0x297e26    0x000080    0x7f    0x95    0x5001
0x297ea6    0x00f32d    0x0    0x0    0x0
0x2a71d3    0x000080    0x7f    0x96    0x5001
0x2a7253    0x00ff69    0x0    0x0    0x0
0x2b71bc    0x0001ab    0x7f    0x0    0x0
0x2b7367    0x000001    0x40    0x97    0x405105
0x2b7368    0x000054    0x10    0x97    0x405105
0x2b73bc    0x010c41    0x0    0x0    0x0
0x2c7ffd    0x000532    0x7f    0x0    0x0
0x2c852f    0x000001    0x40    0x98    0x405104
0x2c8530    0x00004d    0x10    0x98    0x405104
0x2c857d    0x011c6d    0x0    0x0    0x0
0x2da1ea    0x000300    0x7f    0x0    0x0
0x2da4ea    0x000080    0x7f    0x99    0x5001
0x2da56a    0x012d96    0x0    0x0    0x0
0x2ed300    0x000880    0x7f    0x0    0x0
0x2edb80    0x000080    0x7f    0x9a    0x5002
0x2edc00    0x013fc8    0x0    0x0    0x0
0x301bc8    0x000080    0x7f    0x9b    0x5001
0x301c48    0x01530f    0x0    0x0    0x0
0x316f57    0x000001    0x40    0x9c    0x405104
0x316f58    0x00007f    0x10    0x9c    0x405104
0x316fd7    0x016ae0    0x0    0x0    0x0
0x32dab7    0x000001    0x40    0x9d    0x405104
0x32dab8    0x00007f    0x10    0x9d    0x405104
0x32db37    0x01845d    0x0    0x0    0x0
0x345f94    0x00018c    0x7f    0x0    0x0
0x346120    0x000001    0x40    0x9e    0x405104
0x346121    0x000073    0x10    0x9e    0x405104
0x346194    0x019fa9    0x0    0x0    0x0
0x36013d    0x002780    0x7f    0x0    0x0
0x3628bd    0x000080    0x7f    0x9f    0x5001
0x36293d    0x01bce0    0x0    0x0    0x0
0x37e61d    0x0003d5    0x7f    0x0    0x0
0x37e9f2    0x000001    0x40    0xa0    0x405104
0x37e9f3    0x00002a    0x10    0xa0    0x405104
0x37ea1d    0x01e090    0x0    0x0    0x0
0x39caad    0x0002f8    0x7f    0x0    0x0
0x39cda5    0x000001    0x40    0xa1    0x405104
0x39cda6    0x000007    0x10    0xa1    0x405104
0x39cdad    0x020721    0x0    0x0    0x0
0x3bd4ce    0x000091    0x7f    0x0    0x0
0x3bd55f    0x000001    0x40    0xa2    0x405104
0x3bd560    0x00006e    0x10    0xa2    0x405104
0x3bd5ce    0x0230c3    0x0    0x0    0x0
0x3e0691    0x000001    0x40    0xa3    0x405104
0x3e0692    0x00007f    0x10    0xa3    0x405104
0x3e0711    0x025dbe    0x0    0x0    0x0
0x4064cf    0x000845    0x7f    0x0    0x0
0x406d14    0x000001    0x40    0xa4    0x405104
0x406d15    0x00003a    0x10    0xa4    0x405104
0x406d4f    0x029460    0x0    0x0    0x0
0x4301af    0x005b80    0x7f    0x0    0x0
0x435d2f    0x000080    0x7f    0xa5    0x5001
0x435daf    0x02cfef    0x0    0x0    0x0
0x462d9e    0x000380    0x7f    0x0    0x0
0x46311e    0x000080    0x10    0xa6    0x405104
0x46319e    0x0310e0    0x0    0x0    0x0
0x49427e    0x000026    0x7f    0x0    0x0
0x4942a4    0x000001    0x40    0xa7    0x405104
0x4942a5    0x000059    0x10    0xa7    0x405104
0x4942fe    0x0357a8    0x0    0x0    0x0
0x4c9aa6    0x000001    0x40    0xa8    0x405105
0x4c9aa7    0x00007f    0x10    0xa8    0x405105
0x4c9b26    0x03ad5c    0x0    0x0    0x0
0x504882    0x000398    0x7f    0x0    0x0
0x504c1a    0x000001    0x40    0xa9    0x405104
0x504c1b    0x000067    0x10    0xa9    0x405104
0x504c82    0x040b9f    0x0    0x0    0x0
0x545821    0x0039b9    0x7f    0x0    0x0
0x5491da    0x000001    0x40    0xaa    0x405104
0x5491db    0x000046    0x10    0xaa    0x405104
0x549221    0x047357    0x0    0x0    0x0
0x590578    0x000100    0x7f    0x0    0x0
0x590678    0x000080    0x7f    0xab    0x5001
0x5906f8    0x04e56a    0x0    0x0    0x0
0x5dec62    0x000048    0x7f    0x0    0x0
0x5decaa    0x000001    0x40    0xac    0x405104
0x5decab    0x000037    0x10    0xac    0x405104
0x5dece2    0x056f6e    0x0    0x0    0x0
0x635c50    0x000080    0x7f    0xad    0x500f
0x635cd0    0x0608a9    0x0    0x0    0x0
0x696579    0x000080    0x7f    0xae    0x5001
0x6965f9    0x06b2bd    0x0    0x0    0x0
0x7018b6    0x000080    0x7f    0xaf    0x500a
0x701936    0x076f83    0x0    0x0    0x0
0x7788b9    0x000080    0x7f    0xb0    0x5001
0x778939    0x085413    0x0    0x0    0x0
0x7fdd4c    0x0001f1    0x7f    0x0    0x0
0x7fdf3d    0x000001    0x40    0xb1    0x405104
0x7fdf3e    0x00000e    0x10    0xb1    0x405104
0x7fdf4c    0x09541c    0x0    0x0    0x0
0x893368    0x000080    0x7f    0xb2    0x500f
0x8933e8    0x0a72da    0x0    0x0    0x0
0x93a6c2    0x000048    0x7f    0x0    0x0
0x93a70a    0x000001    0x40    0xb3    0x405106
0x93a70b    0x000037    0x10    0xb3    0x405106
0x93a742    0x0bb401    0x0    0x0    0x0
0x9f5b43    0x003b80    0x7f    0x0    0x0
0x9f96c3    0x000080    0x7f    0xb4    0x5001
0x9f9743    0x0d39a6    0x0    0x0    0x0
0xacd0e9    0x000485    0x7f    0x0    0x0
0xacd56e    0x000001    0x40    0xb5    0x405104
0xacd56f    0x00007a    0x10    0xb5    0x405104
0xacd5e9    0x0ef1fa    0x0    0x0    0x0
0xbbc7e3    0x000080    0x7f    0xb6    0x5004
0xbbc863    0x10e38a    0x0    0x0    0x0
0xccabed    0x000080    0x7f    0xb7    0x5001
0xccac6d    0x1315cd    0x0    0x0    0x0
0xdfc23a    0x000080    0x7f    0xb8    0x5001
0xdfc2ba    0x15c1ff    0x0    0x0    0x0
0xf584b9    0x000080    0x7f    0xb9    0x5004
0xf58539    0x18ce02    0x0    0x0    0x0
0x10e533b    0x000001    0x40    0xba    0x405106
0x10e533c    0x00007f    0x10    0xba    0x405106
0x10e53bb    0x1c473c    0x0    0x0    0x0
0x12a9af7    0x000001    0x40    0xbb    0x405109
0x12a9af8    0x00007f    0x10    0xbb    0x405109
0x12a9b77    0x203cef    0x0    0x0    0x0
0x14ad866    0x000001    0x40    0xbc    0x405104
0x14ad867    0x00007f    0x10    0xbc    0x405104
0x14ad8e6    0x251314    0x0    0x0    0x0
0x16febfa    0x000001    0x40    0xbd    0x405104
0x16febfb    0x00007f    0x10    0xbd    0x405104
0x16fec7a    0x2aa2f8    0x0    0x0    0x0
0x19a8f72    0x000001    0x40    0xbe    0x405104
0x19a8f73    0x00007f    0x10    0xbe    0x405104
0x19a8ff2    0x310870    0x0    0x0    0x0
0x1cb9862    0x000001    0x40    0xbf    0x405104
0x1cb9863    0x00007f    0x10    0xbf    0x405104
0x1cb98e2    0x062a1f    0x0    0x0    0x0
0x1d1c301    0x000080    0x10    0x0    0x405104
0x1d1c381    0x1d1c281    0x0    0x0    0x0
0x3a38602    0x000080    0x10    0x0    0x405104
0x3a38682    0x1d1c281    0x0    0x0    0x0
0x5754903    0x000080    0x10    0x0    0x405104
0x5754983    0x1d1c281    0x0    0x0    0x0
0x7470c04    0x000082    0x10    0x0    0x405104
0x7470c86    0x1d1c27f    0x0    0x0    0x0
0x918cf05    0x000080    0x10    0x0    0x405104
0x918cf85    0x1d1c281    0x0    0x0    0x0
0xaea9206    0x000080    0x10    0x0    0x405104
0xaea9286    0x1d1c281    0x0    0x0    0x0
0xcbc5507    0x000080    0x10    0x0    0x405104
0xcbc5587    0x1d1c281    0x0    0x0    0x0
0xe8e1808    0x000084    0x10    0x0    0x405104
0xe8e188c    0x1d1c27d    0x0    0x0    0x0
0x105fdb09    0x000080    0x10    0x0    0x405104
0x105fdb89    0x1d1c281    0x0    0x0    0x0
0x12319e0a    0x000080    0x10    0x0    0x405104
0x12319e8a    0x1d1c281    0x0    0x0    0x0
0x1403610b    0x000080    0x10    0x0    0x405104
0x1403618b    0x1d1c281    0x0    0x0    0x0
0x15d5240c    0x000086    0x10    0x0    0x405104
0x15d52492    0x1d1c27b    0x0    0x0    0x0
0x17a6e70d    0x000080    0x10    0x0    0x405104
0x17a6e78d    0x1d1c281    0x0    0x0    0x0
0x1978aa0e    0x000080    0x10    0x0    0x405105
0x1978aa8e    0x1d1c281    0x0    0x0    0x0
0x1b4a6d0f    0x000080    0x10    0x0    0x405105
0x1b4a6d8f    0x1d1c281    0x0    0x0    0x0
0x1d1c3010    0x000008    0x10    0x0    0x405105
0x1d1c3018    0x000080    0x10    0x0    0x405104
0x1d1c3098    0x1d1c279    0x0    0x0    0x0
0x1eedf311    0x000080    0x10    0x0    0x405104
0x1eedf391    0x1d1c281    0x0    0x0    0x0
0x20bfb612    0x000080    0x10    0x0    0x405104
0x20bfb692    0x1d1c281    0x0    0x0    0x0
0x22917913    0x000080    0x10    0x0    0x405104
0x22917993    0x1d1c281    0x0    0x0    0x0
0x24633c14    0x00008a    0x10    0x0    0x405104
0x24633c9e    0x1d1c277    0x0    0x0    0x0
0x2634ff15    0x000080    0x10    0x0    0x405104
0x2634ff95    0x1d1c281    0x0    0x0    0x0
0x2806c216    0x000080    0x10    0x0    0x405104
0x2806c296    0x1d1c281    0x0    0x0    0x0
0x29d88517    0x000080    0x10    0x0    0x405104
0x29d88597    0x1d1c281    0x0    0x0    0x0
0x2baa4818    0x00008c    0x10    0x0    0x405104
0x2baa48a4    0x1d1c275    0x0    0x0    0x0
0x2d7c0b19    0x000080    0x10    0x0    0x405104
0x2d7c0b99    0x1d1c281    0x0    0x0    0x0
0x2f4dce1a    0x000080    0x10    0x0    0x405104
0x2f4dce9a    0x1d1c281    0x0    0x0    0x0
0x311f911b    0x000080    0x10    0x0    0x405104
0x311f919b    0x1d1c281    0x0    0x0    0x0
0x32f1541c    0x00000e    0x10    0x0    0x405104
0x32f1542a    0x000080    0x10    0x0    0x405106
0x32f154aa    0x1d1c273    0x0    0x0    0x0
0x34c3171d    0x000080    0x10    0x0    0x405104
0x34c3179d    0x1d1c281    0x0    0x0    0x0
0x3694da1e    0x000080    0x10    0x0    0x405104
0x3694da9e    0x1d1c281    0x0    0x0    0x0
0x38669d1f    0x000080    0x10    0x0    0x405104
0x38669d9f    0x1d1c291    0x0    0x0    0x0
PostPosted: January 21st, 2025, 11:55
well, this is strange, drive gives 51/40 errors all over the surface, if only H0 was bad it should be able to read at least from other surfaces. Here and there.
still not sure i interpret the log correctly.
