 Post subject: Hitachi HGST Scratched surface drive!
PostPosted: March 11th, 2025, 3:25
Hi everyone!
I need some guidance or someone willing to help me on this case!
I am currently working on a Hitachi HGST Z7K500-500 HTS725050A7E630 drive
It has a very badly scratched 01 (top) surface
My question is. Can i anyhow physically cut the 01 heads of so that i can read head 0 platter 0?? If yes, what is the procedure and can anyone guide me through it?!
- I am a long time PC3000 User, have clean bench etc...
- I already turned off Head 01 in RAM HEAD MAP
- I already physically cut the 01 Head
But when i start the drive the drive still came up clicking
- I have tried swapping good pair of heads. Which did survive 12GB of data recovery
Many Thanks
482659006_1338632360811800_4468375132150662361_n.jpg [ 149.39 KiB | Viewed 4706 times ]
 Post subject: Re: Hitachi HGST Scratched surface drive!
PostPosted: March 11th, 2025, 3:44
You need to clean the platter first. Then cut/bent head 01, change head map in nv-ram and try to recover more sectors. But i think surface 00 will have damage too.
Such cases should not be guided via forum but checked by someone who knows how to deal with them.
odzyskiwanie danych
PostPosted: March 11th, 2025, 4:14
I have cleaned both platters. Platters 00 is in good condition. I cut head 01, changed head map in NV-RAM however the drive starts clicking when the head 01 is missing
i don't know what step i am missing is the point. Or is there any steps in between??
PostPosted: March 11th, 2025, 4:30
Maybe SA is damaged, i don't know. Give the drive to someone who has experience with such cases. Get a donor and try to run it with one head. Learn how to handle it and then proceed with client's data.
odzyskiwanie danych
PostPosted: March 11th, 2025, 4:40
Ok thanks for the help. Yeah sadly i work in gov environment. So any kind of outsourcing is prohibited. I will try my best then
I mean i know the gist of it. Just lack of experience. Thanks Melvin!
PostPosted: March 12th, 2025, 4:31
Sorry, need to bother for some time
So i cut head 01, Disabled head 01 In NV-RAM. The Drive gets Ready. spinning, no clicking. But It cannot read SA. The drive shows 0mb
Can you help me out!
PostPosted: March 12th, 2025, 6:26
It looks like it was able to read ID once, then it failed, probably ovls are not loaded, so that's the first thing you should sort out.
btw, it is not a very good idea to start the drive like this, it can easily damage the SA copy 0 when writing copy 1 of modules...
PostPosted: March 12th, 2025, 13:18
So any suggestions on how should I proceed pepe??
Users browsing this forum: Google [Bot] and 53 guests
