Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: WDC WD20NMVW Ready but no data access
PostPosted: April 3rd, 2025, 17:15
gold6565 wrote:
Is the ROM original?
FWIW, I have regenerated the ROM from module 0x129.
It uses your ROM ?
PostPosted: April 3rd, 2025, 17:18
It uses your ROM ?
Sorry, I should have said that I have regenerated the ROM from @gameboybin's SA modules 0x109 and 0x129.
PostPosted: April 4th, 2025, 9:44
Error W: 1480 on every head
SA SPT.................................. : 2960
Is the ROM original?[/quote]
Yes i swapped the Rom my self. So its original. I did test the write of the heads so maybe i shouldn't. Maybe i should only test reads
PostPosted: April 4th, 2025, 10:05
Your ROM is damaged, it was reassembled for you, write it down, your disk's SPT is 1480, that's why there's error W1480. Return the original heads.
PostPosted: April 4th, 2025, 11:27
The regenerated ROM is essentially the same as the original. The only difference is that the original ROM contains uninitialised ROYL modules in the inactive directory whereas the regenerated ROM's active and inactive directories have both been populated with the same initialised ROYL modules that were extracted from 0x129.
PostPosted: April 4th, 2025, 14:31
Then something in SA is not from this disk. I can't think of anything else.
PostPosted: April 4th, 2025, 14:45
If @gameboybin can provide a full track dump, then it should be possible to infer the actual SPT value from that.
PostPosted: April 6th, 2025, 12:03
I have written a tool to check the integrity of the SA modules.
This is the result (legend at bottom):
  IDfil ROYL  IDhdr checksum  size(fil/hdr) filename
     1  ....  ....  ........    20   ....  01.rpm
     2  ....  ....  ........     5   ....  02.rpm
     3  ....  ....  ........   151   ....  03.rpm
     C  ....  ....  ........     C   ....  0C.rpm
    11  ....  ....  ........   561   ....  11.rpm
    1B  ....  ....  ........    7F   ....  1B.rpm
    21  ....  ....  ........    CA   ....  21.rpm
    23  ....  ....  ........    CA   ....  23.rpm
    24  ....  ....  ........    CA   ....  24.rpm
    25  ....  ....  ........   101   ....  25.rpm
    26  ....  ....  ........    81   ....  26.rpm
    28  ....  ....  ........    10   ....  28.rpm
    29  ....  ....  ........     B   ....  29.rpm
    2A  ....  ....  ........     B   ....  2A.rpm
    2D  ....  ....  ........   320 /  27E  2D.rpm
    2E  ....  ....  ........   320   ....  2E.rpm
    2F  ....  ....  ........     6   ....  2F.rpm
    31  ....  ....  ........   5A5   ....  31.rpm
    32  ....  ....  ........    3C   ....  32.rpm
    33  ....  ....  ........   4EC   ....  33.rpm
    34  ....  ....  ........    30   ....  34.rpm
    35  ....  ....  ........     A   ....  35.rpm
    36  ....  ....  ........    2C   ....  36.rpm
    37  ....  ....  ........     2   ....  37.rpm
    38  ....  ....  ........   101   ....  38.rpm
    39  ....  ....  ........    11   ....  39.rpm
    3A  ....  ....  ........     C   ....  3A.rpm
    3B  ....  ....  ........    10   ....  3B.rpm
    3C  ....  ....  ........    10   ....  3C.rpm
    3D  ....  ....  ........    10   ....  3D.rpm
    3E  ....  ....  ........    10   ....  3E.rpm
    3F  ....  ....  ........    10   ....  3F.rpm
    40  ....  ....  ........   226   ....  40.rpm
    41  ....  ....  ........   226   ....  41.rpm
    42  ....  ....  ........   226   ....  42.rpm
    43  ....  ....  ........   226   ....  43.rpm
    49  ....  ....  ........     E   ....  49.rpm
    4A  ....  ....  ........    21   ....  4A.rpm
    4D  ....  ....  ........     1   ....  4D.rpm
    4E  ....  ....  ........   526   ....  4E.rpm
    50  ....  ....  ........     5   ....  50.rpm
    51  ....  ....  ........     5   ....  51.rpm
    52  ....  ....  ........     5   ....  52.rpm
    53  ....  ....  ........     5   ....  53.rpm
    62  ....  ....  ........     1   ....  62.rpm
    63  ....  ....  ........    11   ....  63.rpm
    66  ****  ????  ????????   226   ????  66.ERR
    68  ....  ....  ........    CA   ....  68.rpm
    69  ....  ....  ........    CA   ....  69.rpm
    6A  ....  ....  ........    CA   ....  6A.rpm
    6B  ....  ....  ........     3   ....  6B.rpm
    6D  ....  ....  ........     1   ....  6D.rpm
    6E  ....  ....  ........     2   ....  6E.rpm
    6F  ....  ....  64B81779   F3D   ....  6F.rpm
    81  ....  ....  ........     9   ....  81.rpm
    9A  ****  ????  ????????    3C   ????  9A.ERR
    B1  ****  ????  ????????    1E   ????  B1.ERR
    B2  ****  ????  ????????    27   ????  B2.ERR
    B5  ****  ????  ????????   7FF   ????  B5.ERR
    B6  ****  ????  ????????   14D   ????  B6.ERR
    B7  ....  ....  ........    13   ....  B7.rpm
    B8  ****  ????  ????????     2   ????  B8.ERR
    B9  ****  ????  ????????   158   ????  B9.ERR
    BA  ****  ????  ????????   15C   ????  BA.ERR
    BB  ****  ????  ????????   106   ????  BB.ERR
    BC  ****  ????  ????????   14F   ????  BC.ERR
    BD  ****  ????  ????????   169   ????  BD.ERR
    BE  ****  ????  ????????    1B   ????  BE.ERR
    BF  ****  ????  ????????     8   ????  BF.ERR
    C5  ****  ????  ????????   364   ????  C5.ERR
    D0  ****  ????  ????????   102   ????  D0.ERR
    D1  ****  ????  ????????   174   ????  D1.ERR
    D3  ****  ????  ????????    D5   ????  D3.ERR
    D4  ****  ????  ????????    EA   ????  D4.ERR
    D5  ****  ????  ????????   15F   ????  D5.ERR
    D7  ****  ????  ????????   14C   ????  D7.ERR
    D8  ****  ????  ????????    DB   ????  D8.ERR
    D9  ****  ????  ????????   149   ????  D9.ERR
    DB  ****  ????  ????????   158   ????  DB.ERR
    DC  ****  ????  ????????   11A   ????  DC.ERR
    DD  ****  ????  ????????   149   ????  DD.ERR
    DE  ****  ????  ????????   159   ????  DE.ERR
    DF  ****  ????  ????????   170   ????  DF.ERR
    E0  ****  ????  ????????   7D0   ????  E0.ERR
    E1  ****  ????  ????????   7D0   ????  E1.ERR
    E2  ****  ????  ????????   7D0   ????  E2.ERR
    E3  ****  ????  ????????   7D0   ????  E3.ERR
    E4  ****  ????  ????????   7D0   ????  E4.ERR
    E5  ****  ????  ????????   7D0   ????  E5.ERR
    E6  ****  ????  ????????    BA   ????  E6.ERR
    E7  ....  ....  ........    20   ....  E7.rpm
    E8  ****  ????  ????????   322   ????  E8.ERR
    E9  ****  ????  ????????   322   ????  E9.ERR
    EA  ****  ????  ????????   322   ????  EA.ERR
    EB  ****  ????  ????????   322   ????  EB.ERR
    EC  ****  ????  ????????   322   ????  EC.ERR
    ED  ****  ????  ????????   322   ????  ED.ERR
    EE  ....  ....  ........     5   ....  EE.rpm
    F0  ****  ????  ????????   7D0   ????  F0.ERR
    F1  ****  ????  ????????   7D0   ????  F1.ERR
    F2  ****  ????  ????????   322   ????  F2.ERR
    F3  ****  ????  ????????   322   ????  F3.ERR
    F7  ****  ????  ????????   146   ????  F7.ERR
    FA  ....  ....  ........   100   ....  FA.rpm
    FC  ....  ....  ........     4   ....  FC.rpm
    FD  ....  ....  ........    40   ....  FD.rpm
    FE  ****  ????  ????????   7D0   ????  FE.ERR
   102  ....  ....  ........     1   ....  102.rpm
   103  ....  ....  ........     4   ....  103.rpm
   104  ....  ....  ........     1   ....  104.rpm
   105  ....  ....  ........     2   ....  105.rpm
   106  ....  ....  ........     2   ....  106.rpm
   108  ....  ....  ........    26   ....  108.rpm
   109  ....  ....  ........   201   ....  109.rpm
   115  ....  ....  ........    7B   ....  115.rpm
   116  ....  ....  ........     6   ....  116.rpm
   118  ....  ....  ........    29   ....  118.rpm
   119  ....  ....  ........     5   ....  119.rpm
   120  ....  ....  ........   4F7   ....  120.rpm
   121  ....  ....  ........  2001   ....  121.rpm
   122  ....  ....  ........     1   ....  122.rpm
   123  ....  ....  ........     1   ....  123.rpm
   124  ....  ....  ........     1   ....  124.rpm
   125  ....  ....  ........     1   ....  125.rpm
   126  ....  ....  ........     1   ....  126.rpm
   127  ....  ....  ........     1   ....  127.rpm
   128  ....  ....  ........    81   ....  128.rpm
   12A  ....  ....  ........     8   ....  12A.rpm
   12B  ....  ....  ........     4   ....  12B.rpm
   12D  ....  ....  ........   12C /   E8  12D.rpm
   12E  ....  ....  ........    2A   ....  12E.rpm
   131  ****  ????  ????????   226   ????  131.ERR
   132  ....  ....  ........    20   ....  132.rpm
   147  ....  ....  ........    22   ....  147.rpm
   149  ....  ....  ........    AA   ....  149.rpm
   14A  ....  ....  ........   118   ....  14A.rpm
   16F  ....  ....  ........     3   ....  16F.rpm
   191  ....  ....  ........     1   ....  191.rpm
   22D  ....  ....  ........    26 /    2  22D.rpm
   411  ....  ....  ........    E6   ....  411.rpm
  1000  ****  ????  ????????    1D   ????  1000.ERR
  1001  ****  ????  ????????    1A   ????  1001.ERR
  1002  ****  ????  ????????    24   ????  1002.ERR
  1003  ****  ????  ????????    2A   ????  1003.ERR
  1004  ****  ????  ????????    29   ????  1004.ERR
  1005  ****  ????  ????????    1F   ????  1005.ERR
  1007  ****  ????  ????????    19   ????  1007.ERR
  1008  ****  ????  ????????    23   ????  1008.ERR
  1009  ****  ????  ????????    21   ????  1009.ERR
  100A  ****  ????  ????????    27   ????  100A.ERR
  100B  ****  ????  ????????    17   ????  100B.ERR
  100C  ****  ????  ????????    16   ????  100C.ERR
  100E  ****  ????  ????????    17   ????  100E.ERR
  100F  ****  ????  ????????    1D   ????  100F.ERR
  1010  ****  ????  ????????    17   ????  1010.ERR
  1011  ****  ????  ????????    26   ????  1011.ERR
  1100  ....  ....  ........    10   ....  1100.rpm
  1101  ....  ....  ........    80   ....  1101.rpm
  1102  ****  ????  ????????    10   ????  1102.ERR
  1121  ....  ....  ........    80   ....  1121.rpm
  1205  ....  ....  ........    11   ....  1205.rpm
  120F  ****  ????  ????????    11   ????  120F.ERR
  13F1  ****  ????  ????????    F0   ????  13F1.ERR
  13F5  ....  ....  ........    1A   ....  13F5.rpm
  1400  ****  ????  ????????    11   ????  1400.ERR
  1410  ****  ????  ????????    11   ????  1410.ERR
  1500  ....  ....  ........    10   ....  1500.rpm
  1501  ....  ....  ........    50   ....  1501.rpm
  1502  ....  ....  ........    50   ....  1502.rpm
  1503  ....  ....  ........    50   ....  1503.rpm
  1504  ....  ....  ........    10   ....  1504.rpm
  1505  ....  ....  ........    50   ....  1505.rpm
  1506  ....  ....  ........    50   ....  1506.rpm
  1507  ....  ....  ........    50   ....  1507.rpm
  1508  ....  ....  ........    10   ....  1508.rpm
  1509  ....  ....  ........    50   ....  1509.rpm
  150A  ....  ....  ........    50   ....  150A.rpm
  150B  ....  ....  ........    50   ....  150B.rpm
  150C  ....  ....  ........    10   ....  150C.rpm
  150D  ....  ....  ........    50   ....  150D.rpm
  150E  ....  ....  ........    50   ....  150E.rpm
  150F  ....  ....  ........    50   ....  150F.rpm
  1800  ****  ????  ????????    15   ????  1800.ERR
  1801  ****  ????  ????????    15   ????  1801.ERR
  1802  ****  ????  ????????    15   ????  1802.ERR
  1803  ****  ????  ????????    15   ????  1803.ERR
  1804  ****  ????  ????????    15   ????  1804.ERR
  1810  ****  ????  ????????    15   ????  1810.ERR
  1811  ****  ????  ????????    15   ????  1811.ERR
  1812  ****  ????  ????????    15   ????  1812.ERR
  1813  ****  ????  ????????    15   ????  1813.ERR
  1814  ****  ????  ????????    15   ????  1814.ERR
  1902  ****  ????  ????????    20   ????  1902.ERR
  1903  ....  ....  ........    20   ....  1903.rpm
  2401  ****  ????  ????????   1FF   ????  2401.ERR
  2403  ****  ????  ????????   18F   ????  2403.ERR
  2404  ****  ????  ????????   159   ????  2404.ERR
  2407  ****  ????  ????????   1DD   ????  2407.ERR
  2408  ****  ????  ????????   178   ????  2408.ERR
  2409  ****  ????  ????????   209   ????  2409.ERR
  240A  ****  ????  ????????   148   ????  240A.ERR
  240B  ****  ????  ????????   131   ????  240B.ERR
  240C  ****  ????  ????????   174   ????  240C.ERR
  240E  ****  ????  ????????   17C   ????  240E.ERR
  2410  ****  ????  ????????    F7   ????  2410.ERR
  2413  ****  ????  ????????   112   ????  2413.ERR
  2414  ****  ????  ????????   18D   ????  2414.ERR
  2415  ****  ????  ????????   107   ????  2415.ERR
  241A  ****  ????  ????????   15A   ????  241A.ERR
  241D  ****  ????  ????????   153   ????  241D.ERR
  241E  ****  ????  ????????   163   ????  241E.ERR
  241F  ****  ????  ????????   16A   ????  241F.ERR
  2420  ****  ????  ????????   289   ????  2420.ERR
  2422  ****  ????  ????????   164   ????  2422.ERR
  2423  ****  ????  ????????    BA   ????  2423.ERR
  2424  ****  ????  ????????   161   ????  2424.ERR
  2425  ****  ????  ????????   1B3   ????  2425.ERR
  2427  ****  ????  ????????   109   ????  2427.ERR
  2428  ****  ????  ????????   11E   ????  2428.ERR
  2429  ****  ????  ????????   16B   ????  2429.ERR
  242A  ****  ????  ????????   182   ????  242A.ERR
  242B  ****  ????  ????????   119   ????  242B.ERR
  242C  ****  ????  ????????   179   ????  242C.ERR
  242D  ****  ????  ????????   182   ????  242D.ERR
  242E  ****  ????  ????????   168   ????  242E.ERR
  242F  ****  ????  ????????   129   ????  242F.ERR
  2432  ****  ????  ????????   16D   ????  2432.ERR
  2433  ****  ????  ????????   154   ????  2433.ERR
  2503  ****  ????  ????????   2F6   ????  2503.ERR
  2504  ....  ....  ........     6   ....  2504.rpm
  2507  ****  ????  ????????   269   ????  2507.ERR
  2509  ****  ????  ????????    27   ????  2509.ERR
  250A  ****  ????  ????????   12E   ????  250A.ERR
  250B  ****  ????  ????????   13C   ????  250B.ERR
  250C  ****  ????  ????????  1292   ????  250C.ERR
  250E  ****  ????  ????????   189   ????  250E.ERR
  2513  ....  ....  ........    BD   ....  2513.rpm
  2514  ****  ????  ????????   986   ????  2514.ERR
  251E  ....    E6  00005D00   34B /   BA  251E.ERR
  251F  ****  ????  ????????  1EDA   ????  251F.ERR
  2520  ****  ????  ????????  2260   ????  2520.ERR
  2522  ****  ????  ????????   24F   ????  2522.ERR
  2527  ****  ????  ????????    20   ????  2527.ERR
  2529  ****  ????  ????????   CBA   ????  2529.ERR
  252A  ****  ????  ????????   825   ????  252A.ERR
  252C  ****  ????  ????????   B8F   ????  252C.ERR
  252D  ****  ????  ????????   357   ????  252D.ERR
  2640  ....  ....  ........    23   ....  2640.rpm
  2641  ....  ....  ........    23   ....  2641.rpm
  2642  ....  ....  ........    23   ....  2642.rpm
  2643  ....  ....  ........    23   ....  2643.rpm
  2644  ....  ....  ........    23   ....  2644.rpm
  2645  ....  ....  ........    23   ....  2645.rpm
  2646  ....  ....  ........    23   ....  2646.rpm
  2647  ....  ....  ........    23   ....  2647.rpm
  2670  ****  ????  ????????   1A4   ????  2670.ERR
  2671  ****  ????  ????????   1A4   ????  2671.ERR
  2672  ****  ????  ????????   1A1   ????  2672.ERR
  2673  ****  ????  ????????   1A3   ????  2673.ERR
  2674  ****  ????  ????????   1A2   ????  2674.ERR
  2675  ****  ????  ????????   1A4   ????  2675.ERR
  2676  ****  ????  ????????   1A2   ????  2676.ERR
  2677  ****  ????  ????????   1A6   ????  2677.ERR
  2690  ****  ????  ????????    7A   ????  2690.ERR
  2691  ****  ????  ????????    7A   ????  2691.ERR
  2692  ****  ????  ????????    7A   ????  2692.ERR
  2693  ****  ????  ????????    7A   ????  2693.ERR
  2694  ****  ????  ????????    7A   ????  2694.ERR
  2695  ****  ????  ????????    7A   ????  2695.ERR
  2696  ****  ????  ????????    7A   ????  2696.ERR
  2697  ****  ????  ????????    7A   ????  2697.ERR
  26D0  ****  ????  ????????   2D0   ????  26D0.ERR
  26D1  ****  ????  ????????   2A2   ????  26D1.ERR
  26D2  ****  ????  ????????   2A0   ????  26D2.ERR
  26D3  ****  ????  ????????   277   ????  26D3.ERR
  26D4  ****  ????  ????????   2A4   ????  26D4.ERR
  26D5  ****  ????  ????????   24C   ????  26D5.ERR
  26D6  ****  ????  ????????   2B8   ????  26D6.ERR
  26D7  ****  ????  ????????   2BB   ????  26D7.ERR
  26E0  ....  ....  ........     3   ....  26E0.rpm
  26E1  ....  ....  ........     3   ....  26E1.rpm
  26E2  ....  ....  ........     3   ....  26E2.rpm
  26E3  ....  ....  ........     3   ....  26E3.rpm
  26E4  ....  ....  ........     3   ....  26E4.rpm
  26E5  ....  ....  ........     3   ....  26E5.rpm
  26E6  ....  ....  ........     3   ....  26E6.rpm
  26E7  ....  ....  ........     3   ....  26E7.rpm
  2D03  ****  ????  ????????   7D0   ????  2D03.ERR
  2D04  ****  ????  ????????   7D0   ????  2D04.ERR
  2D07  ****  ????  ????????   7D0   ????  2D07.ERR
  2D09  ****  ????  ????????   7D0   ????  2D09.ERR
  2D0A  ****  ????  ????????   7D0   ????  2D0A.ERR
  2D0B  ****  ????  ????????   7D0   ????  2D0B.ERR
  2D0C  ****  ????  ????????   7D0   ????  2D0C.ERR
  2D0E  ****  ????  ????????   7D0   ????  2D0E.ERR
  2D13  ....  ....  ........   7D0   ....  2D13.rpm
  2D14  ****  ????  ????????   7D0   ????  2D14.ERR
  2D1E  ****  ????  ????????   7D0   ????  2D1E.ERR
  2D1F  ****  ????  ????????   7D0   ????  2D1F.ERR
  2D20  ****  ????  ????????   7D0   ????  2D20.ERR
  2D22  ****  ????  ????????   7D0   ????  2D22.ERR
  2D27  ****  ????  ????????   7D0   ????  2D27.ERR
  2D29  ****  ????  ????????   7D0   ????  2D29.ERR
  2D2A  ****  ????  ????????   7D0   ????  2D2A.ERR
  2D2C  ****  ????  ????????   7D0   ????  2D2C.ERR
  2D2D  ****  ????  ????????   7D0   ????  2D2D.ERR
  2E00  ....  ....  ........     2   ....  2E00.rpm
  2FF0  ****  ????  ????????  17CF   ????  2FF0.ERR
  3300  ****  ????  ????????    F1   ????  3300.ERR
  3301  ****  ????  ????????   114   ????  3301.ERR
  3302  ****  ????  ????????   118   ????  3302.ERR
  3303  ****  ????  ????????    E0   ????  3303.ERR
  3304  ****  ????  ????????    F3   ????  3304.ERR
  3305  ****  ????  ????????    E8   ????  3305.ERR
  3307  ****  ????  ????????   11B   ????  3307.ERR
  3309  ****  ????  ????????    E4   ????  3309.ERR
  3310  ****  ????  ????????    E0   ????  3310.ERR
  3311  ****  ????  ????????    D8   ????  3311.ERR
  3312  ****  ????  ????????    D9   ????  3312.ERR
  3400  ****  ????  ????????   15D   ????  3400.ERR
  3401  ****  ????  ????????   14C   ????  3401.ERR
  3402  ****  ????  ????????   151   ????  3402.ERR
  3405  ****  ????  ????????   152   ????  3405.ERR
  3406  ****  ????  ????????   14E   ????  3406.ERR
  3407  ****  ????  ????????   14F   ????  3407.ERR
  3408  ****  ????  ????????   14D   ????  3408.ERR
  3411  ****  ????  ????????    D8   ????  3411.ERR
  3413  ****  ????  ????????   15A   ????  3413.ERR
  3414  ****  ????  ????????    DB   ????  3414.ERR
  3416  ****  ????  ????????    EB   ????  3416.ERR
  3417  ****  ????  ????????   154   ????  3417.ERR
  3421  ****  ????  ????????   152   ????  3421.ERR
  3422  ****  ????  ????????   108   ????  3422.ERR
  3423  ****  ????  ????????   101   ????  3423.ERR
  3424  ****  ????  ????????    FD   ????  3424.ERR
  3425  ****  ????  ????????   108   ????  3425.ERR
  3426  ****  ????  ????????   106   ????  3426.ERR
  3429  ****  ????  ????????    DA   ????  3429.ERR
  3430  ****  ????  ????????   15A   ????  3430.ERR
  3431  ****  ????  ????????   15D   ????  3431.ERR
  34D1  ****  ????  ????????   188   ????  34D1.ERR
  34D2  ****  ????  ????????   192   ????  34D2.ERR
  34D3  ****  ????  ????????   194   ????  34D3.ERR
  34D4  ****  ????  ????????   19D   ????  34D4.ERR
  34D5  ****  ????  ????????   16C   ????  34D5.ERR
  34D6  ****  ????  ????????   1A3   ????  34D6.ERR
  34D7  ****  ????  ????????   1A3   ????  34D7.ERR
  34D8  ****  ????  ????????    E8   ????  34D8.ERR
  34E7  ****  ????  ????????    20   ????  34E7.ERR
  3500  ****  ????  ????????   14E   ????  3500.ERR
  3501  ****  ????  ????????   158   ????  3501.ERR
  3502  ****  ????  ????????   14D   ????  3502.ERR
  3503  ****  ????  ????????   14F   ????  3503.ERR
  3504  ****  ????  ????????   159   ????  3504.ERR
  3511  ****  ????  ????????    D8   ????  3511.ERR
  3513  ****  ????  ????????   18B   ????  3513.ERR
  3514  ****  ????  ????????   198   ????  3514.ERR
  3551  ****  ????  ????????    EA   ????  3551.ERR
  3604  ....  ....  ........    10   ....  3604.rpm
  3605  ****  ????  ????????    D7   ????  3605.ERR
  3700  ....  ....  3EC9CBB6   14E /  14D  3700.ERR
  3703  ****  ????  ????????   103   ????  3703.ERR
  3801  ****  ????  ????????    23   ????  3801.ERR
  3802  ****  ????  ????????     2   ????  3802.ERR
  3803  ****  ????  ????????    30   ????  3803.ERR
  3C00  ....  ....  ........    20   ....  3C00.rpm
  3C10  ****  ????  ????????    45   ????  3C10.ERR
  3C11  ****  ????  ????????    45   ????  3C11.ERR
  3C12  ****  ????  ????????    45   ????  3C12.ERR
  3C13  ****  ????  ????????    45   ????  3C13.ERR
  3C14  ****  ????  ????????    45   ????  3C14.ERR
  3C15  ****  ????  ????????    45   ????  3C15.ERR
  3C16  ****  ????  ????????    45   ????  3C16.ERR
  3C17  ****  ????  ????????    45   ????  3C17.ERR
  3C20  ****  ????  ????????    45   ????  3C20.ERR
  3C21  ****  ????  ????????    45   ????  3C21.ERR
  3C22  ****  ????  ????????    45   ????  3C22.ERR
  3C23  ****  ????  ????????    45   ????  3C23.ERR
  3C24  ****  ????  ????????    45   ????  3C24.ERR
  3C25  ****  ????  ????????    45   ????  3C25.ERR
  3C26  ****  ????  ????????    45   ????  3C26.ERR
  3C27  ****  ????  ????????    45   ????  3C27.ERR
  3E00  ....  ....  ........     5   ....  3E00.rpm
  3E01  ****  ????  ????????   468   ????  3E01.ERR
  3F00  ****  ????  ????????     1   ????  3F00.ERR
  3F01  ****  ????  ????????     8   ????  3F01.ERR
  3F03  ****  ????  ????????    32   ????  3F03.ERR
  3F04  ****  ????  ????????    17   ????  3F04.ERR
  3FF0  ****  ????  ????????   4EC   ????  3FF0.ERR
  4002  ....  ....  ........     1   ....  4002.rpm
  8000  ****  ????  ????????     2   ????  8000.ERR
  8001  ****  ????  ????????     2   ????  8001.ERR
  8002  ****  ????  ????????     2   ????  8002.ERR
  8003  ****  ????  ????????     3   ????  8003.ERR
  8004  ****  ????  ????????     3   ????  8004.ERR
  8005  ****  ????  ????????     2   ????  8005.ERR
  8006  ****  ????  ????????     2   ????  8006.ERR
  8007  ****  ????  ????????     2   ????  8007.ERR
  8008  ****  ????  ????????     2   ????  8008.ERR
  8009  ****  ????  ????????     2   ????  8009.ERR
  800A  ****  ????  ????????     2   ????  800A.ERR
  800B  ****  ????  ????????     2   ????  800B.ERR
  800C  ****  ????  ????????     2   ????  800C.ERR
  800D  ****  ????  ????????     5   ????  800D.ERR
  800E  ....  8006  B22E5B88     5 /    2  800E.ERR
  800F  ****  ????  ????????     5   ????  800F.ERR
  8010  ****  ????  ????????     5   ????  8010.ERR
  8011  ****  ????  ????????     5   ????  8011.ERR
  8012  ****  ????  ????????     5   ????  8012.ERR
  8013  ****  ????  ????????     5   ????  8013.ERR
  8014  ****  ????  ????????     1   ????  8014.ERR
  8015  ****  ????  ????????     2   ????  8015.ERR
  8016  ****  ????  ????????     5   ????  8016.ERR
  8017  ****  ????  ????????     5   ????  8017.ERR
  8018  ****  ????  ????????     2   ????  8018.ERR
  8019  ****  ????  ????????     5   ????  8019.ERR
  801A  ****  ????  ????????     5   ????  801A.ERR
  801B  ****  ????  ????????    21   ????  801B.ERR
  801C  ****  ????  ????????     2   ????  801C.ERR
  801D  ****  ????  ????????    21   ????  801D.ERR
  801E  ****  ????  ????????    B4   ????  801E.ERR
  801F  ****  ????  ????????     2   ????  801F.ERR
  8020  ****  ????  ????????     4   ????  8020.ERR
  8021  ****  ????  ????????     3   ????  8021.ERR
  8022  ****  ????  ????????     5   ????  8022.ERR
  8023  ****  ????  ????????     3   ????  8023.ERR
  8024  ****  ????  ????????     2   ????  8024.ERR
  8025  ....  805D  ........     2 /    5  8025.ERR
  8026  ****  ????  ????????     D   ????  8026.ERR
  8027  ****  ????  ????????     2   ????  8027.ERR
  8028  ****  ????  ????????     3   ????  8028.ERR
  8029  ****  ????  ????????     2   ????  8029.ERR
  802A  ....  8049  ........     2 /    D  802A.ERR
  802B  ****  ????  ????????     5   ????  802B.ERR
  802C  ****  ????  ????????     3   ????  802C.ERR
  802D  ****  ????  ????????    41   ????  802D.ERR
  802E  ****  ????  ????????     8   ????  802E.ERR
  802F  ****  ????  ????????     8   ????  802F.ERR
  8030  ****  ????  ????????     2   ????  8030.ERR
  8031  ****  ????  ????????     4   ????  8031.ERR
  8032  ****  ????  ????????     8   ????  8032.ERR
  8033  ****  ????  ????????     D   ????  8033.ERR
  8034  ****  ????  ????????     D   ????  8034.ERR
  8035  ****  ????  ????????    10   ????  8035.ERR
  8036  ****  ????  ????????    10   ????  8036.ERR
  8037  ****  ????  ????????     2   ????  8037.ERR
  8038  ****  ????  ????????     2   ????  8038.ERR
  8039  ****  ????  ????????     2   ????  8039.ERR
  803A  ****  ????  ????????     2   ????  803A.ERR
  803B  ****  ????  ????????     2   ????  803B.ERR
  803C  ****  ????  ????????     2   ????  803C.ERR
  803D  ****  ????  ????????     2   ????  803D.ERR
  803E  ****  ????  ????????     2   ????  803E.ERR
  803F  ****  ????  ????????     2   ????  803F.ERR
  8040  ****  ????  ????????     2   ????  8040.ERR
  8041  ....  8009  ........     2   ....  8041.ERR
  8042  ....  800C  ........     2   ....  8042.ERR
  8043  ****  ????  ????????     2   ????  8043.ERR
  8044  ****  ????  ????????     2   ????  8044.ERR
  8045  ****  ????  ????????     2   ????  8045.ERR
  8046  ****  ????  ????????     2   ????  8046.ERR
  8047  ****  ????  ????????    21   ????  8047.ERR
  8048  ****  ????  ????????     D   ????  8048.ERR
  8049  ****  ????  ????????     D   ????  8049.ERR
  804A  ****  ????  ????????     5   ????  804A.ERR
  804B  ****  ????  ????????     D   ????  804B.ERR
  804C  ****  ????  ????????     5   ????  804C.ERR
  804D  ****  ????  ????????     D   ????  804D.ERR
  804E  ****  ????  ????????    64   ????  804E.ERR
  804F  ****  ????  ????????     3   ????  804F.ERR
  8050  ****  ????  ????????     5   ????  8050.ERR
  8051  ****  ????  ????????     D   ????  8051.ERR
  8052  ****  ????  ????????    10   ????  8052.ERR
  8053  ****  ????  ????????     5   ????  8053.ERR
  8054  ****  ????  ????????     D   ????  8054.ERR
  8055  ****  ????  ????????     5   ????  8055.ERR
  8056  ****  ????  ????????     D   ????  8056.ERR
  8057  ****  ????  ????????     5   ????  8057.ERR
  8058  ****  ????  ????????     D   ????  8058.ERR
  8059  ****  ????  ????????     5   ????  8059.ERR
  805A  ****  ????  ????????     D   ????  805A.ERR
  805B  ****  ????  ????????    10   ????  805B.ERR
  805C  ****  ????  ????????     2   ????  805C.ERR
  805D  ....  8003  8022129C     5 /    3  805D.ERR
  805E  ****  ????  ????????    3D   ????  805E.ERR
  805F  ****  ????  ????????    10   ????  805F.ERR
  8060  ....  804E  ........     2 /   64  8060.ERR
  8061  ****  ????  ????????     2   ????  8061.ERR
  8062  ****  ????  ????????     D   ????  8062.ERR
  8063  ....  8037  ........     D /    2  8063.ERR
  8064  ****  ????  ????????     5   ????  8064.ERR
  8065  ****  ????  ????????    21   ????  8065.ERR
  8066  ****  ????  ????????     2   ????  8066.ERR
  8067  ****  ????  ????????     5   ????  8067.ERR
  8068  ****  ????  ????????     D   ????  8068.ERR
  8069  ****  ????  ????????     F   ????  8069.ERR
  806A  ****  ????  ????????     3   ????  806A.ERR
  806B  ....  ....  ........    15   ....  806B.rpm
  806C  ****  ????  ????????     4   ????  806C.ERR
  806D  ****  ????  ????????     B   ????  806D.ERR
  806E  ****  ????  ????????    21   ????  806E.ERR
  806F  ....  ....  ........     A   ....  806F.rpm
  8074  ****  ????  ????????     5   ????  8074.ERR
  80FC  ....  ....  ........     2   ....  80FC.rpm
  80FE  ....  ....  ........    20   ....  80FE.rpm
  80FF  ....  ....  ........    32   ....  80FF.rpm
  8108  ....  ....  ........     4   ....  8108.rpm
  8FFC  ****  ????  ????????     1   ????  8FFC.ERR
  8FFD  ****  ????  ????????     8   ????  8FFD.ERR
  8FFE  ****  ????  ????????    10   ????  8FFE.ERR
  AC55  ....  ....  ........     1   ....  AC55.rpm
  ADDD  ****  ????  ????????   151   ????  ADDD.ERR
  D000  ....  ....  ........     1   ....  D000.rpm
  D001  ....  ....  ........     1   ....  D001.rpm
  D002  ....  ....  ........     1   ....  D002.rpm
  D003  ....  ....  ........     1   ....  D003.rpm
  D004  ....  ....  ........     1   ....  D004.rpm
  D005  ....  ....  ........     1   ....  D005.rpm
  D006  ....  ....  ........     1   ....  D006.rpm
  IDfil    -- ID of module as reported in its file name (should be the same as ID in SA module 0x01)
  IDhdr    -- ID of module as reported in module's header, or .... if same as IDfil
  checksum -- actual checksum of module if not 0x00000000, or ........ if 0x00000000
  size     -- size of file in sectors / size as reported in module's header if different, or .... if same
  ****     -- "ROYL" signature was not found in header, or .... if "ROYL" found
  xxxx     -- size of file is not a sector multiple
  !!!!     -- IDfil cannot be inferred from filename, or filespec not supported
  ??????   -- the parameter is not applicable for this case
  ......   -- the parameter's value is as expected
ModulesLog_sorted.7z [2.96 KiB]
Downloaded 317 times
Users browsing this forum: No registered users and 218 guests
