 Post subject: HTS545032B9A300 2.5" SATA HDD Hitachi, spin down
PostPosted: April 3rd, 2025, 23:25
I got HTS545032B9A300 2.5" SATA HDD Hitachi, spin down. It spin in the first time and spindle down.
I can't access to SA. Anyway to short pins? Any short pins information?
Or it may other way.
Thank you.
 Post subject: Re: HTS545032B9A300 2.5" SATA HDD Hitachi, spin down
PostPosted: April 3rd, 2025, 23:28
Sorry, wrong model, it is HTS543225L9A300
PostPosted: April 4th, 2025, 4:14
Yep, you can try to short VCC and GND test pins, it really may help. Enjoy! :lol:
PostPosted: April 4th, 2025, 4:21
It's opened.
Did you change heads?
PostPosted: April 4th, 2025, 5:27
Hi Northwind,
Yes, head replaced with same donor.
Currently no more spin down, it is READY, but having error when access to SA.
No ID detection yet.
PostPosted: April 4th, 2025, 5:53
As you wrote above, I thought the spindle motor does not spinning. So does it rotating or not?
If heads are changed, spindle motor continues to spinning, and no clicking sound, then I would check the NV-RAM version first. It may be an alien PCB & ROM. Check the NV-RAM version in the ROM and version at the HDA label.
PostPosted: April 4th, 2025, 6:33
Hi aekhv,
Spindle is spinning and keep spinning after head replacement.
Head is moving, I heard one click, no clicking.
When selecting ID, drive READY with ERROR and ABR.
Let me check the NV-RAM version in the ROM... compare to the label.
Who knows wrong PCB.
Thank you.
PostPosted: April 4th, 2025, 6:37
According to shield warranty stickers on HDD and PCB, it is originally unopened.
Anyway I will check ROM.
PostPosted: April 4th, 2025, 6:38
This is Hitachi IBM, not ARM
PostPosted: April 4th, 2025, 6:48
Actually yes, you're absolutely right.
Users browsing this forum: No registered users and 34 guests
