 Post subject: FBLite 2 USB to SATA conversion help
PostPosted: April 8th, 2025, 11:26
I have this FBLite2 with board 810085. Does anyone know the pinout for the sata connection? I've found where it is but not sure how to determine which pins are A+ A-, etc. The controller is Marvell 88i1053T
 Post subject: Re: FBLite 2 USB to SATA conversion help
PostPosted: April 8th, 2025, 11:49
Same MCU? If so, then follow the SATA Tx/Rx differential pairs between MCU and SATA connector.
https://img01.obyava.ua/classified/0/2537/5413/law7cirkiybuajtt.jpg
PostPosted: April 8th, 2025, 12:45
Perfect! Thank you. I could not find a picture of a board with that MCU anywhere
PostPosted: April 8th, 2025, 16:46
Here is the pinout in case anyone else needs it for this board
PostPosted: April 9th, 2025, 3:11
By the way, don't forget to remove four bypass capacitors close to the USB bridge, it's important.
PostPosted: April 9th, 2025, 3:42
yes. but they are called coupling cap(acitor)s. Bypass (decoupling) caps are used to filter supply lines.
cron
