 Post subject: Anyone have module 02 for WD40NDZM-11BCXS1?
PostPosted: May 12th, 2025, 9:49
I have the rest of SA backed up, module 02 cannot read. None of the donors I have seem to be compatible, only 11BCXS1 I have was from a 5TB model.
Thanks in advance
 Post subject: Re: Anyone have module 02 for WD40NDZM-11BCXS1?
PostPosted: May 12th, 2025, 12:18
You can edit the 5TB module to reduce the capacity to 4TB. I can do that for you, if that's all that is required.
PostPosted: May 13th, 2025, 17:49
I've tried that. I get "VSC ERR STATIC FILE INVALID" with that module 02.
I've recovered over 100 of these drives with no problem but this one is giving me a headache for sure.
Full SA reads no problem except for 02.
If I can get one that will upload to RAM without error I can just move where module 02 is and upload it to SA
PostPosted: May 13th, 2025, 18:02
does the size of the donor module match the patient?
PostPosted: May 14th, 2025, 14:52
good catch. Donor is 4kb while the patient says 8kb in dir. I don't have any donors with a 8kb module 02. I tried filling it with 0s to make it 8kb but obviously that didn't work. VSC STATIC FILE INVALID.
I just get DISK DAM ERROR trying to read 02 from the drive. I guess it needs heads swapped out.
PostPosted: May 14th, 2025, 15:15
Can you upload your directory module and your patient and donor 0x02 modules and your ROM?
Could there be a copy of these modules in other SA regions???
PostPosted: May 14th, 2025, 15:34
If the first 4KB of the patient 0x02 module reads OK, would it be possible to shrink its size in the DIR module? I could do that.
Users browsing this forum: No registered users and 316 guests
