 Post subject: PC3000 ProtableIII and PRO Dedicated NVME Adapter
PostPosted: May 14th, 2025, 22:22
Application Scenario 1: For disks with a lot of black spots in the image, heat them up to 80-100 degrees after mirroring and replenish the part of the black block that has not been read out (this is effective for most SSD disks).
2: For some Protable III unsupported host controller, disk that can't load LDR virtual compiler, long busy SSD disk, heat the disk to 100 degrees first, about 30-40 minutes to refresh the ID or power off to refresh the ID. About 30% of the disks can be mirrored.
3: For SSDs with bad core power supply, you can fly a 1.0v, 1.2v, 1.8v cable to the hard disk.
Contact me if you are interested
Telegram:@L02233adapter
 Post subject: Re: PC3000 ProtableIII and PRO Dedicated NVME Adapter
PostPosted: May 15th, 2025, 1:16
What's the temperature range of the device....Also what's the safe max temperature to avoid burning the peltier element?
www.datasave.ro
PostPosted: May 15th, 2025, 1:23
The maximum temperature of the adapter is 110 degrees Celsius. After testing, the best effect is found at 70-100 degrees Celsius.
PostPosted: June 5th, 2025, 4:23
For the full test video If interested please contact me on telegram(@L02233adapter)。
https://drive.google.com/file/d/1byqDNz-LxPHlpuv6bzJaS51SKM3hm9xn/view?usp=sharing
PostPosted: June 6th, 2025, 18:35
The funny thing is that this temperature control tool was probably developed by the MRT team, who are competitors of AceLab.
They have developed (or at least promote) a tool compatible with PC3000 from AceLab, the paradox is that MRT has not yet developed any data recovery tool for NVMe.
:lol:
It is interesting to know what does AceLab team think about this tool?
Do they agree? Coluld it cause some sort of damages to PC3000 Portable?
My firmware database:
PostPosted: July 5th, 2025, 5:53
Hello
Do you have an email address or a Teams account ?
Thank you.
PostPosted: September 3rd, 2025, 6:12
Hi
Does anyone know where I can find that extension cable/adapter? Aliexpress?
www.datasave.ro
PostPosted: September 3rd, 2025, 6:14
ccc wrote:
Hi
Hi! If you find it you can send me a pm? I need too
PostPosted: September 3rd, 2025, 6:28
Hi
I hope that Flashguys will come with an answer here....Or anyone else.....
www.datasave.ro
PostPosted: September 3rd, 2025, 7:12
ccc wrote:
Hi
https://a.aliexpress.com/_EvjatCS
PostPosted: September 4th, 2025, 8:39
I know about it....
I want an extension, I need to do exactly what he did in the picture. PC3000 on a shelf and the adapter away from it.
www.datasave.ro
PostPosted: October 16th, 2025, 5:15
Hi
I ordered one piece from him, package arrived, all is OK
Contact him 49335007@qq.com on Teams.
Rgds
www.datasave.ro
