 Post subject: ST3500312CS PROCESS DEFECT LIST ERROR
PostPosted: May 21st, 2025, 9:16
Hello Friends,
I recieve below image hdd which has process defect list error in terminal. Hdd show correct ID and Correct space in device manager. when scanning in DR software all sector bad. I can't access sector. Googling about process defect list error, i found it is releated to sys file 1B problem. i need data. Can someone repair or rebuild 1B file. I attach important sys file as attachment.
Thank You.
Original Files.rar [19.19 KiB]
Downloaded 59 times
 Post subject: Re: ST3500312CS PROCESS DEFECT LIST ERROR
PostPosted: May 21st, 2025, 9:47
"repair or rebuild 1B file"
It is impossible to fix. In both copies the beginning is erased with zeros.
And the most important thing is 512 bytes of the beginning of the factory P-list.
This is assuming that the T-list was empty at the beginning from the factory.
PostPosted: May 21st, 2025, 9:50
Any hope to retrive the data?
it is erased with zeros automatically or by someone?
PostPosted: May 21st, 2025, 9:52
"by someone"
"Any hope to retrive the data?"
I don't have any. Maybe someone does.
PostPosted: May 21st, 2025, 9:53
SWM wrote:
"by someone"
thnx sir
PostPosted: May 21st, 2025, 10:37
how about 028? were you able to read it, even partially?
why do you want to regen the translator at all?
PostPosted: May 21st, 2025, 10:40
i read 28 fully
PostPosted: May 21st, 2025, 10:41
028 file.rar [8.91 KiB]
Downloaded 53 times
PostPosted: May 21st, 2025, 10:43
you were faster than me... i added the line: 'why do you want to regen the translator?' to my prev post while you replied...
PostPosted: May 21st, 2025, 10:46
all sector is bad. i can't access sector. someone work befor me. i contacted him but it has nothing backup of sys files and work directly with sys file without backup.
PostPosted: May 21st, 2025, 10:47
can you sir rebuild 1B file ?
PostPosted: May 21st, 2025, 10:51
can you rebuild 1B file wuth the help of 1F file?
I read 1F file also completely without error.
PostPosted: May 21st, 2025, 10:54
it is perfectly unnecessary if that 28 is native. do not regen.
what tools do you have?
PostPosted: May 21st, 2025, 10:56
i haven't any expensive tools.
PostPosted: May 21st, 2025, 10:59
pepe sir did you download my original files.rar? are you found any problem in 1B file?
if not, why error message come when regenerate the translator?
PostPosted: May 21st, 2025, 11:09
i checked your files after my first msg, then i saw there is 028 in perfect condition, that's why i can't get why you want to regen it.
as SWM said, 01B is corrupt, first part seems to be erased, it cannot be repaired but it is not necessary.
With tools and knowhow this thing should be easy. without tools it is a bit though, without knowhow you better outsource it... :s
PostPosted: May 21st, 2025, 12:08
Pepe sir basically hdd have partial access problem so, how I solve this problem? Is 1B File is not essential for data recovery?
PostPosted: May 21st, 2025, 12:25
I don't know how easy it will be... Of the tools, only the terminal is visible - it is visible by the file format.
In 35 there are only three entries at the end of the LBA. How "native" 28 is - one can only guess.
Apparently, everything that was found on the Internet (A>P and even 6F) has been done with the disk.
PostPosted: May 21st, 2025, 13:20
Dear SWM sir,
Can you guide further me regarding A>P and 6F
PostPosted: May 21st, 2025, 13:52
Dear kagzizaid80 sir,
These commands only do harm. Especially to data recovery.
As well as recalculating the translator without a backup of system files.
And it is impossible to restore erased P-list records. They are unique for each disk.
For your level of knowledge - listen to the pepe:
"without knowhow you better outsource it..."
Users browsing this forum: No registered users and 53 guests
