Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: AMA: MultiDrive - free app to clone, backup, erase drives
PostPosted: May 30th, 2025, 6:51
Hi everyone,
I’m Vitaliy Mokosiy, CTO at Atola Technology and one of the creators of MultiDrive, a 100% free tool for backing up, cloning, and erasing drives on Windows.
Why MultiDrive? At one point, a friend asked me how to quickly upgrade from an HDD to an SSD, and I realized there wasn’t an easy and free solution—nothing simple enough. I kept running into similar situations, like needing to back up a USB drive or securely erase it, and saw the same problem each time. And it was really hard to find a quick solution every time. Most other tools are either paid-only, less capable, or feature-limited.
So our new tool is super easy to use. Without annoying pop-up banners or upsells, and no feature limitations.
Keeping it simple as 1-2-3, we added decent value for advanced tech people like you:
  • Run multiple drive operations simultaneously
  • Pause and resume any task without losing data
  • Process parts of disks instead of entire disk spaces
  • Performance-optimized drive backup directly to ZIP, and restore from ZIP
  • Well-thought-out command-line interface (CLI) for automation and scripting
Check it out: multidrive.io
Ask me anything about technical decisions, use cases, comparisons to existing tools, CLI examples, whatever you're curious about!
Vitaliy Mokosiy
CTO, Atola Technology
Maker of MultiDrive
 Post subject: Re: AMA: MultiDrive - free app to clone, backup, erase drive
PostPosted: May 30th, 2025, 7:26
Very nice. I tried a simple backup from a folder to a zip file and it works like a charm.
Great work, thank you!
PostPosted: May 30th, 2025, 8:53
Looks cool.
One suggested feature that you might want to consider it the ability for the user to specify drives as read-only so they don't ever show up on the target list, except as a location to save a backup file.
PostPosted: May 30th, 2025, 8:55
May I suggest an option to erase with a specific pattern, defined by user?
Thank You
ACELab partner
PostPosted: May 30th, 2025, 17:00
Gave it a little test for wiping multiple drives of unknown condition.
And to answer @pclab's question, there is a spot to put in a custom HEX pattern to write when wiping
Not too bad. Another feature idea is to simply show a drive that has failed SMART properties in the Drives list.
PostPosted: May 31st, 2025, 1:32
lcoughey wrote:
Looks cool.
Thanks!
The feature is a bit hidden yet it's there. When selecting Target drive for your task, right-click one of the target drives you want to protect > Click Restrict for selection. The Drive will remain greyed out if you reboot the app.
Funnily enough, I was the one who requested in the early stage of development to protect myself from accidental writing to my work drives :)
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: May 31st, 2025, 1:34
Thank You
Yeah, it is possible in both GUI and CLI versions of the app. In GUI, you click Erase > then Options button. The pattern option is there.
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: May 31st, 2025, 1:41
Luke, please pay attention MultiDrive is not designed as a data recovery tool.
Thus, it stops any running task in the event of an I/O error. Perhaps in the future, we will add the ability to skip read/write errors; however, it will not be effective in standard Windows that cannot handle even slightly damaged drives :)
It's a good idea, as is the SMART. In theory, at least. In practice, there are CrystalDiskInfo and HDSentinel, which track the SMART table. I don't see how we could do anything better.
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: June 1st, 2025, 16:16
Great! I will use it for sure.
I will also test the clone feature.
Another request, if possible: when cloning, maintain the percentage of each partition. For instance: if the original drive is 256GB with one partition, when cloning to a 1TB drive, do the same percentage.
If the drive has 2 partitions, for instance 40/60, do the same on the destination.
Do you think it's possible?
ACELab partner
PostPosted: June 1st, 2025, 20:08
Yeah, I'm not thinking as a data recovery tool and was only looking from the perspective of erasing drives of unknown condition. For me, a failed to erase drive gets crushed and a drive with SMART errors get labeled as such for parts only.
PostPosted: June 2nd, 2025, 2:47
It's possible, but I'm not sure if we're ready to spend months implementing partition resizing and scaling. It's an advanced feature that takes time. I would stick to MiniTool Partition Wizard or Paragon Hard Disk Manager for that purpose.
Thank you for your feedback anyway. Noted!
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: June 2nd, 2025, 2:50
By the way, my team is working on an app update that will introduce a retry mechanism with resets during failed read/write commands. It will make MultiDrive more robust against loose cable connections and some instabilities.
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: June 2nd, 2025, 7:45
Got it. That's what I use here, so no issues.
ACELab partner
PostPosted: June 2nd, 2025, 9:22
For resizing partitions while cloning, I use smart partition copy with R-Studio.
PostPosted: July 10th, 2025, 2:48
We released MultiDrive 1.1 update with improved data recovery and error resistance, building on lots of received feedback:
1. Support of drives with bad sectors:
- If Windows does not crash into BSOD, MultiDrive will clone or backup such a damaged drive.
2. Resilience against cable connection losses. For instance, when you accidentally touch a USB cable during read/write operations.
3. Ability to resume task that failed after several hours of work.
4. Better error reporting.
I would love to hear any new feedback you might have!
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: July 10th, 2025, 4:21
Hi Vitality
Thanks for developing & releasing free , such daily useful tool. Appreciate your time & expertise. Most of the memebers must be having there own tools for disk inwards or inventory management or these operations but new startups or smaller individuals will find this useful.
I have a suggestion. Dashboard & interface should be simple ,clutter free showing more technical details of the disk with log creation option.
If disk details like model /type /sn/fw & smart health status could be logged & exported in txt /html that will make this more useful.
One can select source & target or cloning /imaging .A log of operation with source /target details , time taken ,list of bad sectors etc must be logged.
Thanks :good:
PostPosted: July 11th, 2025, 1:26
terminator2 wrote:
Hi Vitality
Thanks :good:
Thank you trying MultiDrive and sharing your feedback! It's great to hear from someone who understands the value of such free tools.
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: July 11th, 2025, 6:10
terminator2 wrote:
Hi Vitality
Thanks :good:
Since its release , I am using this tool everyday. It's very handy & is saving my time.
Thanks. Keep it Up. Wishing all the Best :-D :good:
PostPosted: November 17th, 2025, 6:00
. .. >> great to hear from someone who understands the value of such free tools
hey, not fair: there are hundreds, if not already thousands of us out here who feel the same about multidrive - just to lazy to write, or simply not finding this forum to do so.
have now used it for some 12-15 clones, for myself, wife and friends - almost never a problem.
only one recently balked: cloning an ssd to an ssd stick - comes back with NO BOOTDEVICE FOUND - on the very same make of stick it has worked before. since cloning a 2TB ssd to a stick takes a long long time (8hrs - stick also overheats, needs constant cooling), one cannot make one test after another.
and: a link to a help file or even a handbook from within the prog would help. not just simple people like me ...
and and: sorry, i keep editing this again and again - a clear indication which version one is using (1.1, 1.4 ???), and an update option right there too, would be very useful.
many greetings - henry
PostPosted: November 18th, 2025, 2:04
Thank you so much for sharing the feedback! I am always happy to learn from specific and detailed experience like yours. We will certainly discuss every point you mentioned.
I've got a few questions about the USB stick that was overheating.
- What is the model of the USB stick drive?
- What was your effective method of cooling it?
Vitaliy Mokosiy
Maker of MultiDrive
