 Post subject: st1000dm003 no spin
PostPosted: June 5th, 2025, 12:55
st1000dm003 no spin
fw: cc41
Hdd failed after power outage. Now hdd will not spin but the pcb seems electrically intact. zener diode and fusible resistors all tested fine ad 1.8volts at eeprom pin8
I have attached the eeprom dump if someone can examine the eeprom file and check for errors. Thank you
terra st1000dm003 eeprom W25Q80BW@SOIC8-150_20250605_184239.rar [347.39 KiB]
Downloaded 41 times
 Post subject: Re: st1000dm003 no spin
PostPosted: June 5th, 2025, 14:57
I don't have FW CC41 to be more precise... But you can try:
New_st1000dm003_CC41_20250605.zip [446.08 KiB]
Downloaded 36 times
PostPosted: June 5th, 2025, 15:26
I have repaired your original ROM. The flipped bit was in a compressed section (CPRS) of the first BOOTFW segment. Hopefully that's it.
repaired_6436.7z [339.25 KiB]
Downloaded 35 times
PostPosted: June 5th, 2025, 16:43
Will try this tommorow when im back at workshop and give feedback
PostPosted: June 5th, 2025, 16:45
Will also try this one when im back to workshop tomorrow. But if i may ask, what causes the flipped bits? There was just a power outage and no firmware update whatsoever.
PostPosted: June 5th, 2025, 16:58
At power-on, the ROM segments are unpacked into RAM, and the drive then transfers control to RAM. The MCU does not refer to the ROM again until the next power cycle. It could be that one of the bits leaked its charge while the drive was running. This did not affect the code in the RAM, so you would have been unaware of this problem until you tried to repower the drive. I doubt that the power outage had any effect on the ROM.
PostPosted: June 11th, 2025, 17:46
This firmware did not make the hdd spin. Thanks for the effort.
I can confirm that this repaired firmware works fine. Thank you
PostPosted: June 12th, 2025, 12:02
Thanks for the response. Now I'll know that the second copy of BOOTFW doesn't work.
And Frank is a wizard. :) Good luck.
Users browsing this forum: Majestic-12 [Bot] and 235 guests
