 Post subject: Deleted data on USB WD SMR drive with T2?
PostPosted: June 24th, 2025, 10:09
I have a WD Palmer USB drive from 2021 with deleted data. I've recovered a few formatted and deleted drives with T2 following this: https://blog.acelab.eu.com/western-digi ... ution.html
With USB drives when I get to the step in DE to restore the second level translator it goes through its process for a few minutes then nothing happens, no error. No virtual drive created.
I've unlocked the ROM and have converted the USB board to SATA using the original board.
Am I missing something or is it just not possible on the USB drives?
 Post subject: Re: Deleted data on USB WD SMR drive with T2?
PostPosted: June 24th, 2025, 12:56
It is my thought that it should work with the SATA conversion of the original USB board. But it is better to ask ACE TS and report back here with your findings.
PostPosted: June 24th, 2025, 14:56
It works fine with SATA conversion. Check if you've read the whole module 190. Maybe there were errors.
odzyskiwanie danych
Users browsing this forum: Google [Bot] and 47 guests
