 Post subject: LDPC SD Recovery
PostPosted: July 18th, 2025, 7:07
Warmest wishes!
I have an SD card which uses LDPC ECC. It just stopped working whilst inside my Sony camera and I've been told that the controller seems to have failed. A friend in Canada said that HDDGuru is the only one who knows how to do a recovery (because of the LDPC). Might you be able to advise on what might be possible (and possible cost)? Thank you so much for considering!
 Post subject: Re: LDPC SD Recovery
PostPosted: July 18th, 2025, 14:07
I have seen Michal (Arvika) say that even if you "cracked" LDPC there's a good chance you'd be dealing with an encrypting controller.
