Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Seagate st16000ne000rom is damaged
PostPosted: August 17th, 2025, 9:55
E123 wrote:
fzabkar, Yes, I somehow ... all the same. You can restore the first container if you find something there.
And your "oracle" - read yourself. He says that I was born in the wrong country.
Something got lost in the translation. :-?
BTW, those two ROM RAID examples at the Oracle both have empty containers. One has an empty 0x22 container, the other has an empty 0x23 container. Your F3RomExplorer tool doesn't handle the 12TB ROM.
PostPosted: August 17th, 2025, 11:01
Damaged:
0x50000 - GFDIR
0x50100 - BootFW Container
Damaged or I can't see them because the first two are damaged:
0x50XXX - Boot FW
0x7A000 - IAP
0x7B000 - SFW
CAP, SAP, RAP, Shell - checksums are normal.
It remains to look for a working ROM from FW EN01...
PostPosted: August 17th, 2025, 15:35
I notice that current Seagate ROMs have a 32-byte section in the IAP segment. This looks like a digital code of some kind. Is this unique and critical?
PostPosted: August 18th, 2025, 5:38
We will find out if the author of the topic finds a working ROM and there will be a continuation...
PostPosted: August 20th, 2025, 2:16
Thank you all. I currently cannot find a properly working ROM for FW EN01, but I have many ROMs from the same family, including other FW versions and other models such as FW SC02 and SN03. They all belong to the EvansBP series and are shown as the c6 family on PC3000. Are these useful? If not, I will upload the properly working ROM for FW EN01 once I find it in the future.
PostPosted: August 20th, 2025, 3:44
The ROM stores only the boot code, traps, adaptives and SFW. The main code is in the service area of the disk. It will not work with another version of the FW, the overlay versions on the disk will not match the ROM.
PostPosted: August 21st, 2025, 7:33
You can try to assemble it from these two.
EN01 EV01.7z [541.89 KiB]
Downloaded 77 times
PostPosted: August 21st, 2025, 10:57
gold6565, Дякую!
ROM with donor boot container. IAP did not correct - I do not know the format. Maybe it will take off... Frank can disassemble it into two...
New_ROM_RAID0.zip [877.62 KiB]
Downloaded 72 times
PostPosted: August 21st, 2025, 11:53
SWM wrote:
gold6565, Дякую!
Sorry for bad English
I gave two ROMs
One has exactly the same SAP as the patient, which is very surprising.
There is a chance that it should fit.
PostPosted: August 21st, 2025, 15:41
@gold6565, there is no SAP in either of your two dumps. You have provided only the first ROM of each pair. Are you referring to the contents of the second ROM?
PostPosted: August 22nd, 2025, 5:01
SAP modules consisting of three ROMs.
Mine are different... :)
SAPs.7z [73.77 KiB]
Downloaded 68 times
PostPosted: August 22nd, 2025, 5:48
It's sad that there is no one to check the latest ROM... :(
PostPosted: August 22nd, 2025, 7:25
Yes, I was mistaken, I looked at the wrong thing.
PostPosted: August 26th, 2025, 9:05
Hello sir, I'm sorry for being late. I've been searching for a working ROM recently, and I'm lucky to have found it. I'm uploading it now and trying your latest ROM, the damaged drive successfully started, but it still doesn't work properly. PC3000 shows a missing fw. I can use PC3000 to extract a lod file from a working drive, but it seems like I can't write to the damaged drive
PostPosted: August 26th, 2025, 9:08
Normal working ROM and patient ROM
rom.zip [1.48 MiB]
Downloaded 72 times
PostPosted: August 26th, 2025, 9:16
File comment: This is the latest terminal prompt.
2025-08-26 21-16-08.pdf [1.44 MiB]
Downloaded 81 times
PostPosted: August 26th, 2025, 9:42
aggc123 wrote:
Or FW is not on the disk, or it was never there? Please take a photo of your disk from the sticker side
PostPosted: August 26th, 2025, 12:05
"Trans" - overlay from disk is loaded, but does not fit BFW (DiskFWfailed). Looks like an unsuccessful update (the FW version on the disk is no longer EN01). Or BFW has also become unique... :(
The patient's ROM with BFWContainer "normal operation".
Patient_ROM_BFWnormal_operation.zip [880.47 KiB]
Downloaded 69 times
PostPosted: August 26th, 2025, 16:36
What was the original problem with this drive, before the ROM was corrupted?
PostPosted: August 30th, 2025, 2:33
There are some alarms.
