 Post subject: ST500LM000
PostPosted: September 2nd, 2025, 14:31
Hi, my disk broke, until it happened I didn't even know that there was such a thing as SSHD. I called a company that could repair it and then they told me how much it cost, I started looking. Fortunately, I have some experience with programming and electronics. According to what I read on the forums, the terminal output indicates a damaged NAND. I bought a second PCB with the same S/N on eBay. I read the contents of the patient's and donor's EEPROMs and using F3 Rom explorer moved CAP RAP and SAP from the patient's EEPROM and later also IAP. Of course I have no idea what I'm doing :) It didn't help, the disk spins up, but the terminal says FAIL servo op=0100 Resp=0007 and other things. Can anyone please help me? Thank you.
st500.zip [1.94 MiB]
Downloaded 62 times
 Post subject: Re: ST500LM000
PostPosted: September 2nd, 2025, 14:50
Full terminal log when turned on?
"says FAIL servo op=0100 Resp=0007" - this applies to the heads, not to the PCB.
PostPosted: September 2nd, 2025, 15:17
I am attaching the logs...
patient_pcb.txt [686 Bytes]
Downloaded 56 times
donor_pcb.txt [1.08 KiB]
Downloaded 53 times
PostPosted: September 2nd, 2025, 21:12
Either drive is not spinning or heads are bad.
PostPosted: September 3rd, 2025, 3:13
more probably adaptives are still read from nand
PostPosted: September 3rd, 2025, 10:32
so no chance of home rescue? any eeprom modification?
PostPosted: September 3rd, 2025, 16:48
+1
Do you have terminal access after PCB swap?
Users browsing this forum: Google [Bot] and 269 guests
