 Post subject: Regarding the scan menu in Victoria
PostPosted: September 23rd, 2025, 23:14
In the Test & Repair menu, there are two scan modes: Remap and Refresh. I would like to know whether these two modes are designed to repair bad sectors without affecting the data stored on the hard drive.
As I understand it, the Erase mode, as the name suggests, actually wipes the affected area, so I prefer not to use it.
If someone has precise knowledge of Victoria, could you kindly explain this?
 Post subject: Re: Regarding the scan menu in Victoria
PostPosted: September 24th, 2025, 4:50
On a working HDD, all these operations are unnecessary.
If the drive is faulty, immediately copy the data to a working one.
Remapping differs from erasing in the number of erased sectors.
Refreshing is also not safe if the write head is damaged.
And you need to check the SMART. If there are reallocated sectors, copy the data immediately.
PostPosted: October 6th, 2025, 22:29
In Victoria, both Remap and Refresh modes are generally non-destructive—they don’t erase user data.
Remap checks each sector, and if a sector is unreadable, it triggers the drive’s internal mechanism to reallocate (remap) it to a spare sector. This process doesn’t overwrite good data but may result in data loss only in already unreadable sectors.
Refresh simply reads and rewrites data to the same sectors to restore weak magnetic areas, improving reliability without data loss.
Only the Erase mode actually overwrites sectors and destroys data, so you’re right to avoid it unless you intend to wipe or fully restore the drive surface.
PostPosted: November 19th, 2025, 7:36
I'm trying to unlock a Toshiba drive which is password locked with several tools..
one is victoria which i've tried but no success ..
There are Messages i can't identify !..
Can someone help me to unlock this hdd ?
it is a PATA 2,5" HDD...
it is recognized in Victoria but if i try to unlock it with the known password zhe "security" option is disabled in API-Mode
how could i enable this or when will this be enabled in Api Mode ???
if i try to unlock in PIO Mode i got an error Message "[ATA Protocol] DRQ!!! press RESET or restart HDD"
Don't know what means "DRQ!!!" ????
can someone help me and give me hints ... Thank you
PostPosted: November 19th, 2025, 13:53
You could simply try ZU It can clear the password and keep the data intact. This utility is zu.betta.050911.rar located on this forum in the downloads section. There will be many posts on how to use it.
PostPosted: November 26th, 2025, 6:10
I'm not able to download any file there...
do i have to contact the admins there ??
i can't register in "Files" Zone as well ....
PostPosted: November 26th, 2025, 15:04
You can get ZU here:
https://www.hddoracle.com/viewtopic.php?f=95&t=166&p=334#p334
You need Firefox to access the site (because of ongoing DDOS attack mitigation).
PostPosted: November 30th, 2025, 11:11
I wonder what is up with the DDOS nonsense as hddoracle is not a major web property by any measure. I get HTTP 403 errors.
PostPosted: December 1st, 2025, 11:14
Interesting. What is the the ATA command please to reallocate an unreadable sector to a spare sector? This is beating around the bush when describing a simple write command to a defective sector.
Of course the process does overwrite good data! There is no "may". Unless not overwritten an unreadable sector might be read on the next read attempt. Overwriting makes the pending loss a permanent one.
Wrong. Replacing a pending sector by overwriting it means deletion of data.
Users browsing this forum: No registered users and 69 guests
