 Post subject: ST9750422AS
PostPosted: November 27th, 2025, 7:40
Drive in topic clicks 3 times the continue spinning.
Terminal output:
EarlySpinup Enabled
Rst 0x10M
ASCII Diag mode
ExecuteSpinRequest
LED:00000067 FAddr:00380338
Tried to short read channel no luck
Booting from H1 no luck
Heads replaced no luck
Any suggestions ?
Thanks in advance
 Post subject: Re: ST9750422AS
PostPosted: November 28th, 2025, 7:56
I'm not a DR guru. But while the gurus are silent... The error indicates that there's garbage in memory instead of the overlay.
I don't know if MRT or PC3K can load the loader from boot mode. The loader itself is here in the files. Or hot swapping... but, that's dangerous.
https://files.hddguru.com/download/PC-3 ... S049MW.rar
PostPosted: November 29th, 2025, 7:32
I appreciate your reply, SWM.
Here's the patient and donor rom copies :
Donor_ROM.rar [428.73 KiB]
Downloaded 130 times
Patient_ROM.rar [428.72 KiB]
Downloaded 264 times
PostPosted: November 29th, 2025, 9:35
The ROMs are identical, except for the adaptive modules, of course. They were released in January-February 2011. The adaptive module checksums are normal.
Unfortunately, the ROMs in this resource (https://files.hddguru.com/download/PC-3 ... S049MW.rar) are not compatible.
PostPosted: November 29th, 2025, 9:39
Thanks for confirming that.
I can reach terminal after shorting read channel but it clicks and gives LED error again if I try to issue any command.
PostPosted: November 29th, 2025, 9:51
Well, I already wrote that you don't have a diagnostic overlay loaded into memory. A limited number of commands are available in this mode.
I don't know if your tools allow you to load overlays into memory and create a loader. It can be created from the donor's resources.
Is the patient's ROM native? Part Number 6WS08VS3A match the label?
PostPosted: November 29th, 2025, 10:00
Only via termial. (MRT)
Yeah, matched.
PostPosted: November 29th, 2025, 11:01
Donor drive is dead? SA not reading?
PostPosted: November 29th, 2025, 11:19
Donor working normally after swapping heads between the two drives.
Both SA and UA are reading fine in donor drive.
PostPosted: November 29th, 2025, 11:55
Is it possible to create a loader on a donor in MRT and look at it?
PostPosted: November 30th, 2025, 7:31
The customer decieded to take the drive as I exceeded the time for recovery.
Thanks a lot, SWM.
I do really appreciate your kind help.
PostPosted: November 30th, 2025, 13:32
You're welcome. I'm glad. It would be too much trouble to insert the patient's adaptive modules into the donor's loader. :)
And then to see the patient’s SA not working (especially the translator).
Users browsing this forum: Google [Bot] and 58 guests
