 Post subject: PS3117-S17 help me find the shorted component
PostPosted: December 8th, 2025, 22:04
I have this SSD with Phison PS3117-S17 Controller that tested on PC3000 gives all lights like a crhistmas tree. Which I believe the SSD is shorted. However i cannot seem to find where the short is.
Can you guys help me out! Many thanks!
SSD
z7307173613688_d72a0c1394680bdc85f70c6682b987d5.jpg [ 877.82 KiB | Viewed 2995 times ]
z7307178271863_0f80b17acb68cfd85a005ce40f90c0bc.jpg [ 679.69 KiB | Viewed 2995 times ]
Voltages
z7307168369897_f700c218903f601cbdaa228d8db929b0.jpg [ 568.58 KiB | Viewed 2995 times ]
Many thanks!
 Post subject: Re: PS3117-S17 help me find the shorted component
PostPosted: December 8th, 2025, 22:17
5V is present at the input, and 3.3V and 1.8V are present at the outputs. Where is the Vcore supply for the controller? That should be around 1V. Could that be the 0.9V I can see at the PS6117-40 PMIC?
PostPosted: December 8th, 2025, 22:22
Can you point out where can i measure Vcore??
PostPosted: December 8th, 2025, 22:26
Sorry, your reply crossed with my edit. The PS6117-40 PMIC has 1x buck converter and 1x LDO regulator. Perhaps 0.9V is the LDO output for the Vcore supply, in which case there do not appear to be any shorted supplies.
Is there anything on the other side of the PCB? I can't believe that Vcore can be supplied by a puny LDO.
PostPosted: December 8th, 2025, 22:36
There is nothing on the other side
PostPosted: December 8th, 2025, 22:44
Measure the voltages on the tiny bypass capacitors around the controller. You should find Vcore and Vio.
PostPosted: December 8th, 2025, 23:32
Here are the voltages around the controller
z7307600832287_737539726f07aa4a085270549adcd705.jpg [ 474.88 KiB | Viewed 2980 times ]
PostPosted: December 8th, 2025, 23:41
All looks good to me. It looks like this is the cheapest possible configuration.
PostPosted: December 9th, 2025, 3:36
Welp. still have no idea what is wrong with it :"(
PostPosted: December 9th, 2025, 3:41
Have you tried Safe/ROM mode?
PostPosted: December 9th, 2025, 3:43
Yeah safe ROM mode works on normal PC, and on PC3000 Express
but not in PC3000 Portable. So i'm questioning my device now :(
PostPosted: December 9th, 2025, 7:14
All the SATA registers on in PC3K in itself doesn't indicate a short - you can get the same if you just power a drive with no SATA data connected. If you suspect something like that check the power profile rather than the lights. No idea why you're getting differing results in express / portable though.
PostPosted: December 9th, 2025, 8:58
Try to check/replace Portable Sata/Power cable.
