 Post subject: Two new MR NAND adapters are available - MR SP12 and 13 !
PostPosted: December 22nd, 2025, 5:02
We want to presents two new NAND adapters - SD Monolithic MR SP13 NAND adapter and SD Monolithic MR SP12 NAND adapter.
Supported SD card:
Specification:
- made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability.
- printed circuit made with the highest precision of 4mils and gold plated pads to minimize interference
- specially developed PCB tracks routing technology to prevent interference during NAND reading
- special high quality pogo contact pins used which are used for specialized laboratory tests
- ready to work on standard pinout (pinout delivered with adapter) as well as alternative one by special sockets
- different cards size support by special inners
- built-in additional noise filters and VSP pins (where available) to prevent "noise" during NAND readings
- MR adapter can be connected to the SD card reader for faster XOR analysis and extraction (look move below)
- MR adapter can be connected to any LA (Logic Analyzer) to analyze signals and find custom pinouts without need of soldering
Compatible with devices of world leaders in data recovery:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Photos of the adapter:
Link https://multi-com.eu/shrt-w81GH7ymw
Supported SD card 2 channels:
Specification:
Link: https://multi-com.eu/shrt-eTpoKCRhY
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
