 Post subject: EXOS seagate
PostPosted: December 30th, 2025, 6:57
i have couple of these hdds for repair. they are tested and working very well, how can i solve this problem with gas sensor?
 Post subject: Re: EXOS seagate
PostPosted: December 30th, 2025, 7:23
smart status
PostPosted: December 30th, 2025, 11:21
pump more gas in
PostPosted: December 31st, 2025, 2:38
pump more gas in
you are very very so so funny
PostPosted: January 2nd, 2026, 21:30
I have several helium server disks and so far none have run low but its not rocket science to pump more into such a disk. More realistically it is advisable to get a new disk which will likely be stable for a while versus clinging to an old dying disk.
PostPosted: January 5th, 2026, 2:55
After working with dozens of EXOS hard drives, it has been proven to me that some of them report this error unrealistically. This is a factory bug, and there is a problem in the sensor system and its related circuitry.
PostPosted: January 5th, 2026, 12:42
I’ve seen similar issues with some Seagate drives, seems like the gas sensor error is a known bug on certain models. It might be worth checking with Seagate support or trying a firmware update if you haven’t already :arrow: :lol:
PostPosted: January 5th, 2026, 13:06
How would you do this and maintain the seal?
PostPosted: January 5th, 2026, 13:13
ISTR that HDDSurgery is able to recover Seagate helium models in an air environment. If so, then the fact that a Seagate helium model continues working with a SMART sensor failure would be inconclusive evidence of a bug. I would compare the temperatures of a good and "bad" Seagate helium model under the same workload. The good drive should run significantly cooler.
PostPosted: January 10th, 2026, 20:42
Try Crystal Disk Info which does show helium levels in server class disks.
Helium allows for 8 or even 9 plates in the media spindle. Helium has far less friction vs air.
Users browsing this forum: Bing [Bot], Google [Bot] and 59 guests
