 Post subject: What does Low Level Format really do on a flash drive?
PostPosted: January 11th, 2026, 21:13
Other than zero out the data?
 Post subject: Re: What does Low Level Format really do on a flash drive?
PostPosted: January 12th, 2026, 12:28
I think that's all it does. A real "low level format" is done at the factory when the firmware is built using an MPTool.
PostPosted: January 15th, 2026, 8:52
What does low level format mean to you? What do you mean by it? If you mean Windows LLF on a simple USB flash drive then I agree with Franc. So then largest portion os NAND can't be recovered from, perhaps some tiny overprovisioned area will contain some data. If you run one more LLF then most likely that's gone too.
PostPosted: February 7th, 2026, 11:32
I suggest a zero wipe which can help the controller clean up the blocks in a favorable manor.
Orico DS500C3-US-BK 5-disk 3.5" SATA, iTGZ 4x M.2 2280 Thunderbolt enclosure NVMe/SATA, etc. etc.
PostPosted: February 7th, 2026, 12:36
Only if controller can distinguish between writing 00 00.. and FF FF.., or DE EF 3E (etc.) .. If you write zeros to each LBA on simple flash drive is has no way to tell it's empty.
PostPosted: February 7th, 2026, 13:04
I decided to go with an industrial micro SD card with a USB reader
