 Post subject: CRUCIAL BX500 1TB - Wrong Capacity 1.07 GB
PostPosted: April 15th, 2026, 15:05
OK, so i have this drive, BX500 1000GB (CT1000BX500SSD1) not allways recognized but managed to "see" it with DMDE and Opensuperclone with wrong capacity 1.07GB and name "SM2259AB-10-10000000", in BIOS also the controller name. So most likely a controller fault, but i was just wondering if someone could check the voltage readings just to see if that part is ok, it seems ok.
*** Is the white smd near the 5V connector (5 and 0) a capacitor?
Thanks guys.
 Post subject: Re: CRUCIAL BX500 1TB - Wrong Capacity 1.07 GB
PostPosted: April 15th, 2026, 15:35
PostPosted: April 15th, 2026, 17:48
Although I don't have a reference for comparison, those voltages look OK to me. Those two small DBGA-4 ICs at the left of the crystal appear to be 3.3V and 1.8V LDO regulators. You might want to check that.
PostPosted: April 15th, 2026, 18:23
What do you think is that white component (5v and 0v)? Looks like a fuse, but i bet is a capacitor. Have two more right at the crystal.
PostPosted: April 15th, 2026, 18:45
It must be a capacitor.
I think the SOT23-5 component (R9xxx) might be this:
https://www.diodes.com/datasheet/download/AP331A.pdf
PostPosted: April 16th, 2026, 14:42
Those 3.3V and 1.8V LDO regulators are good.
Thank you for your attention.
PostPosted: July 13th, 2026, 13:50
Online
Given this is an intermittent problem it might be wise to find a new SSD before this BX500 croaks
Low cost USB boxes can host the BX500 for file recovery
Users browsing this forum: Hardcore Games and 54 guests
