 Post subject: Seagate ST1000LM035 Translator FIX
PostPosted: May 14th, 2026, 17:09
I have a Seagate ST1000LM035
Rebuild the translator in MRT Utility
befor rebuild it, HDD didn´t read no one LBA
After the rebuild, Just read 3 GB, but all parametres are well, NS correct, capacity correct (931.51 GB) , Head map correct
But just can read 3 gb,
Any Tip ?
 Post subject: Re: Seagate ST1000LM035 Translator FIX
PostPosted: May 14th, 2026, 22:46
Rebuilding translator on SMR Seagates is best when you want to kill data. Now either rollback sa (if any) or send the drive to someone skilled. Recovering translation on these is pretty complicated.
PostPosted: May 15th, 2026, 8:33
:-? :shuffle:
My firmware database:
PostPosted: May 15th, 2026, 21:12
The disk at issue is 1TB SATA 7mm. I suggest a USB enclosure and try recovering files.
PostPosted: May 16th, 2026, 5:44
a very important problem with hddguru forum is the lack of :facepalm: smilie. It would come very handy in some cases. This one is one of them.
PostPosted: May 16th, 2026, 20:56
There are some things you just can't change ;-)
PostPosted: May 17th, 2026, 5:05
yeah, movin' on... :)
PostPosted: May 17th, 2026, 13:14
yep, i was searching exactly for :facepalm:. emoticon without success... instead i had to use :-? :shuffle:
:lol:
Users browsing this forum: Google [Bot] and 45 guests
