 Post subject: SQL Database file
PostPosted: July 1st, 2026, 7:49
Hi guys,
got a drive with a formatted partition and recovered a sql file that is corrupt. Is any here that can give me clues on how to repair the file? or have at it?
 Post subject: Re: SQL Database file
PostPosted: July 1st, 2026, 12:19
I recall several cases where an encrypted volume (eg My Book) has been overwritten by partitioning or formatting. A file scan then turns up false positives such a SQL files.
Can you supply more details?
PostPosted: July 1st, 2026, 13:06
Thank you for the response. The drive is a healthy 500Gb seagate inter drive with originally 2 internal partitions. One is for OS (C) and a data partition. Both partitions were formatted by accident(according to the client). There was a recent backup on the data drive. Did a recovery and found an MDF file which fails to load.
PostPosted: July 2nd, 2026, 8:15
what information do you need?
PostPosted: July 2nd, 2026, 11:46
You have explained the situation. I thought that the client may have shucked an encrypted My Book from its enclosure, but that doesn't seem to be the case.
PostPosted: July 2nd, 2026, 12:30
Do you have any suggestions?
PostPosted: July 2nd, 2026, 14:16
I don't have any suggestions, but it might help if you tell us the model number (SMR or CMR or SSD) and the original and current file systems.
PostPosted: July 3rd, 2026, 8:59
Its a 500Gb DM series. Both original and current file systems are NTFS.
Users browsing this forum: Majestic-12 [Bot] and 62 guests
