 Post subject: seagate ST1000LM053 stop spinning
PostPosted: July 10th, 2026, 10:57
Hi i have st000lm053 stop spinning all of sudden is pcb swap and rom will work on this specfic model?
 Post subject: Re: seagate ST1000LM053 stop spinning
PostPosted: July 10th, 2026, 11:02
Do you mean the ST1000LM035 model?
Are you sure the drive is completely dead and not just a faint beeping sound coming from it?
PostPosted: July 10th, 2026, 11:04
Yes no vibration at all
PostPosted: July 10th, 2026, 11:13
I try another board it spin but not reconized
PostPosted: July 10th, 2026, 11:18
If the drive powers on on a different PCB, transferring the ROM should solve the problem.
How did the damage occur?
PostPosted: July 10th, 2026, 11:19
are you sure romswap work on this model
PostPosted: July 10th, 2026, 11:21
Yes, but to be sure, you can post photos of the disk from both sides.
PostPosted: July 10th, 2026, 11:28
PostPosted: July 10th, 2026, 11:30
You can swap ROM.
PostPosted: July 10th, 2026, 11:32
Lukas wrote:
You can swap ROM.
Thank you i already order mcc3 board is this should work
Users browsing this forum: No registered users and 60 guests
