 Post subject: Seagate ST31000520AS trying to recover data
PostPosted: July 20th, 2026, 4:56
This is my first post over here.
I have a Seagate ST31000520AS drive, the drive spins normal, no weird noises.
Windows asks to format the drive.
I tried with several data recovery programs, but all I get is read errors from start to end.
Is this some kind of firmware problem ?
Thanks in advance !
 Post subject: Re: Seagate ST31000520AS trying to recover data
PostPosted: July 20th, 2026, 5:54
This isn't a pure "firmware issue". The disk already has problems. It's best to contact a DR specialist for data recovery.
If the data isn't that valuable, research Seagate LED CC online... :)
PostPosted: July 20th, 2026, 7:30
Thank you, I have searched on the net, and found some articles and posts about seagate drives having a common issue with BSY state or 0 LBA error.
This disk I'm having is still recognized in the bios and appears with the right name and capacity.
I noticed when recovery software is 'reading' from the disk, the disk is just spinning, but you cannot hear activity as in heads moving.
PostPosted: July 20th, 2026, 7:59
https://forum.hddguru.com/viewtopic.php?p=271517#p271517
PostPosted: July 22nd, 2026, 7:32
Thanks a lot, I was able to clone the drive with HDDSuperclone and then use recovery software on the clone. I got the data I need.
PostPosted: July 22nd, 2026, 8:56
Miracle! :lol:
I misunderstood you. I thought the HDD really wasn't readable.
PostPosted: July 22nd, 2026, 15:14
If the disk does not write reliability then rather than flog a dead horse, an SSD is faster and SATA models are inexpensive.
PostPosted: July 23rd, 2026, 5:41
And yet you continue to flog a dead horse
Users browsing this forum: No registered users and 55 guests
