 Post subject: WD42PURZ error 4F10
PostPosted: July 28th, 2026, 8:36
Hello. I have two WD42PURZ drives with defects that need to be hidden; however, current software versions identify the family as "03C1 Unknown," so I assume the drive family is not supported by the programs I have. It fails to read the service area (error 4F10), including the defect lists. How can I resolve this issue? Thank you.
 Post subject: Re: WD42PURZ error 4F10
PostPosted: July 28th, 2026, 9:29
In windows 11 you can use CHKDSK
CHKDSK /R
will read every sector and map them out as errors are found
another more aggressive approach is to use Seatools 5 and use the erase disk function which will allow the disk to map out pending sector issues etc but be wary to clear off the disk first before using Seatools 5
PostPosted: July 28th, 2026, 10:26
Enter you serial number here:
https://support-en.wd.com/app/warrantystatusweb
If the S/N is recognised, you will see the drive's family.
Example:
    WX42D42ARZ35
    WD42PURZ-85B4YY0
    VENICERP
    5040 <-- should be 5400 RPM
    256M
    SATA3 6GB/S
    4.0T
    4HD
    SURVEILLANCE DISTRIBUTION
PostPosted: July 28th, 2026, 20:03
Thank you, fzabkar.
VENICERP 5040 256M SATA3 6GB/S 4.0T 4HD SURVEILLANCE DISTRIBUTION
VENICERP 5040 256M SATA3 6GB/S 4.0T 4HD SURVEILLANCE ROEM
PostPosted: July 29th, 2026, 10:50
To work with this drive, you need an unlocked ROM, or an unlocked PCB.
Mikippp
PostPosted: July 31st, 2026, 9:47
Mikippp
I understand, thank you
Users browsing this forum: Google [Bot] and 95 guests
