Forum rules
Post new topic Reply to topic  [ 125 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: WD MCU - No more...
PostPosted: September 1st, 2026, 5:21
20 Aug 2020
2024
2003
015
1220
There are several others that I can't read (your photo is unclear).
PostPosted: September 1st, 2026, 5:57
20 Aug 2020 from the HDD sticker
Now where is the other info from the pcb side? if the image is not clear, just point to the place where you wanted me to focus on and will make a better image 4u
FYI: relying on Dates is not a good idea since the hdd production line produces many on the same date right?
BUT
my findings is certain ...
PostPosted: September 1st, 2026, 8:54
On the component side.
Show me the ROM and MCU, without the thermal pad.
PostPosted: September 1st, 2026, 9:54
einstein9 wrote:
Quick for you guys:
Suppose someone replaced the "native usb3 pcb" with another and he wrote native rom to it
Anyone knows how to tell if this pcb is for that drive? (in case if both pcbs have the same native ROM)
It looks like nobody wants to play your game.
I'm guessing that simply trying each PCB to see which one starts the drive and decrypts the data is not an acceptable solution? Obviously I don't have any experience in this area, but I'll start by identifying security-related objects.
There are these 3 ROM resident ROYL adaptive modules:
1A2 : SED KEY
1B6 : Digital signature
1B0 : Digital Signature
The ROM boot block is digitally signed at the end of the block.
One of the ROM's PCMBlocks is a compressed 0xDDDD ROYL module. I have attached an example from a SpyGlass3. If I understand correctly, 0xDDDD is required for initialising the drive's crypto-engine.
I expect that the digital signatures may have no relationship to the MCU key. One way to find out would be to compare two drives that have identical firmware and check whether their identical boot blocks have the same signature.
Another test would be to install a donor PCB with identical firmware on a patient HDA, after transferring the ROM adaptives one by one.
Another test might be to execute an ATA 90h Execute Drive Diagnostic command and observe any error code.
DDDD.7z [2.76 KiB]
Downloaded 103 times
PostPosted: September 1st, 2026, 17:01
I remembered this old thread:
https://forum.hddguru.com/viewtopic.php?p=264106#p264106
It appears that 0xDDDD is not unique.
PostPosted: September 1st, 2026, 23:39
unknown wrote:
Nobody noticed, what if the MCU is physically damaged or the entire native PCB is missing.
Is there a solution ?
The code that creates the MCU keys (there are 2 keys involved in data encryption) calls for a random generator inside the MCU, so unless there is a security weakness inside the random generator (very unlikely) or the keys are also copied somewhere else on the drive (possible but not likely) it would not be possible to decrypt data without the original MCU
PostPosted: September 1st, 2026, 23:42
Yes, it's possible with about 99% certainty.
PostPosted: September 1st, 2026, 23:47
einstein9 wrote:
I have to disagree with you here Doomer:
1- Removing the MCU Key will result in encrypted data
2- Moving Key to another MCU PCB works (tested)
I'm not sure with what you are disagreeing.
I've never said removing the keys, I said extracting the keys and writing a software decryptor (would not be easy, because the keys are salted but possible)
PostPosted: September 1st, 2026, 23:56
0xDDDD is a security overlay (digitally signed) that, AFAIR, checks signature of module 0x11 (main code overlay).
It's not unique
PostPosted: September 2nd, 2026, 3:49
einstein9 wrote:
Quick for you guys:
1A2 : SED KEY
This is not a Game fzabkar,, A research and finding thing, you are not in DR (i wish if u were) but what you are telling about changing pcbs and figure out which is booting and so is a time wasting approach. many other easier ways to do the same work.
PostPosted: September 2nd, 2026, 3:51
Am 100% certain of my finding (PM OTW)
PostPosted: September 2nd, 2026, 3:55
Sure it is there somewhere (in another form)
Unique KEY which is located inside MCU is also located somewhere on the drive.
When drive powers ON drive reads & compares both if match will carry on booting IF NOT (even if same native ROM) data enc. (compare Enc. data with multiple donor PCBs and figure out the pattern).
PostPosted: September 2nd, 2026, 4:03
One of the easier ways is to observe the date codes, at least for some cases. I can do that from a photograph.
https://www.hddoracle.com/viewtopic.php?p=495#p495
And thank you for your well wishes. Actually, my first data recovery case was during the 1980s. It was intellectually satisfying, and I do wish that my trajectory had continued on that path in later years. In fact, Ontrack's first case was during that time. Also, Steve Gibson was writing Spinrite during those years (it actually had some relevance then).
PostPosted: September 2nd, 2026, 4:42
I did not know this Thnx for the info..
btw, you are doing very well, should think about investing in DR and give it as shot
all the best.
FYI, knowing if the pcb is native or not takes 20sec. only
:beer:
PostPosted: September 2nd, 2026, 8:40
even without ROM?
PostPosted: September 2nd, 2026, 10:45
There are a few drives when PCB is changed on the factory without recertifying the drive, so far I've see only two such drives, that's why I said 99% not 100%.
PostPosted: September 2nd, 2026, 13:17
Thanks for the info.
That means there's no constant keys located in the FW to compare with the one created randomly in MCU?. If I understand well.
pepe wrote:
even without ROM?
PostPosted: September 2nd, 2026, 13:43
If the keys would have been constant there would be no point using original MCU, any MCU would work.
PostPosted: September 2nd, 2026, 13:46
This is very doubtful.
At least I have never seen any comparison.
PostPosted: September 2nd, 2026, 13:58
Please excuse ignorant me for asking the obvious question, would @einstein9, or his researchers, not have tested this claim by modifying the copy of the key?
