Forum rules
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: WD MCU - No more...
PostPosted: September 2nd, 2026, 15:40
Please excuse ignorant me for asking the obvious question, would @einstein9, or his researchers, not have tested this claim by modifying the copy of the key?
indeed it would be very interesting to know
PostPosted: September 2nd, 2026, 16:17
Doomer wrote:
unknown wrote:
That means there's no constant keys located in the FW to compare with the one created randomly in MCU?. If I understand well.
If the keys would have been constant there would be no point using original MCU, any MCU would work.
I see, thank you.
PostPosted: Yesterday, 3:58
pepe wrote:
even without ROM?
this is totally diff. scenario
PostPosted: Yesterday, 4:07
Doomer wrote:
einstein9 wrote:
When drive powers ON drive reads & compares both if match will carry on booting
This is very doubtful.
At least I have never seen any comparison.
Then do you have another opinion about this?
I said: When drive powers ON it compares both keys the one on drive SA with the MCU if both match then data will be decrypted if not matching data will be encrypted.
and i link this statement with the enc. pattern when we try diff. donor PCBs (means diff. keys) with the same drive. try it, compare it and then you will understand my point here.
PostPosted: Yesterday, 4:25
Online
I doubt it does any comparison.
Data is decrypted using the MCU key even if it is not native. Decryption will be wrong of course, so data is garbage in this case, but still decrypted.
and as you say, you get different decrypted data with different mcus, this lines up with my interpretation.
PostPosted: Yesterday, 6:11
@einstein9, if there is a copy of the key in the SA, then why do you need the patient MCU at all? Just install the donor PCB + donor MCU + patient adaptives on the patient HDA, recover the key from the SA, and then write the key to the donor MCU, or decrypt in software.
PostPosted: Yesterday, 6:36
I tested it myself, writing Native Key to donor MCU ----> drive worked normal as native mcu/pcb (procedure takes time)
@fzabkar
"if there is a copy of the key in the SA, then why do you need the patient MCU at all? Just install the donor PCB + donor MCU + patient adaptives on the patient HDA, recover the key from the SA, and then write the key to the donor MCU, or decrypt in software."
Just install the (donor PCB + donor MCU) which are ONE + patient adaptives which is ROM here
donor PCB/MCU has Diff. key here.
PostPosted: Yesterday, 7:17
Yes, of course, that's what I meant. But you didn't answer my question. If you can extract a copy of the patient's MCU key from the patient's SA, why do you need the patient's MCU?
PostPosted: Yesterday, 7:48
In another form, if you write native ROM to another SATA PCB data is encrypted why?
because PCB MCU KEY & HDD KEY are not the same.
PostPosted: Yesterday, 9:55
Online
"in another form"???
if it is there, what prevents you from decoding it and use it with the donor mcu?
or you don't want to talk about it, that's perfectly understandable as well, just say so.
