Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST1000LM014 SSHD - request spin / disc table recovery
PostPosted: November 21st, 2026, 17:29
Rendersmith wrote:
I'm not sure if the original dump was correct.
It was correct. F3RomExplorer validated every checksum and CRC.
PostPosted: November 22nd, 2026, 3:47
fzabkar, As far as I remember, for the correct calculation of the CRC, the CPRS modules must be unpacked. I never got around to it...
PostPosted: November 22nd, 2026, 8:56
@SWM, thanks, I just confirmed your observation. Strangely, I don't need to unpack the CPRS code in the SFW segment -- both CRCs are valid for the compressed code.
PostPosted: November 22nd, 2026, 11:17
The attached ROM has all the correct sums and CRCs. It only remains to be seen whether my two hacks are valid.
ST1000LM014_sshd_patient_rom_CRC_7.7z [675.32 KiB]
Downloaded 26 times
PostPosted: November 22nd, 2026, 15:10
Thank you!
I executed these Commands
Request spin / disc table recovery
ASCII Diag mode
F3 T>/O
F3 O>I
ALF Parametric Tables Preserved
Flash was erased and ALF Tables have successfully been initialized
F3 O>
After that do I need to flash the original Firmware back again?
PostPosted: November 22nd, 2026, 15:15
I'm not a data recovery pro, but that other thread would suggest that you do need to restore the original ROM contents.
Good luck, anyway.
PostPosted: November 22nd, 2026, 16:57
I've been assuming that your drive doesn't attempt to spin. I hope that is/was the case, otherwise I may have been wasting your time.
PostPosted: November 22nd, 2026, 17:32
Well, it did spin in the first place.
I flashed the original rom again. But no luck, I can't access the data.
It continues to display "Request spin / disc table recovery"
But a thing changed:
As written in my first post I had this Output.
Strt Cln1
ABORT!
OpCode = 00000000
SenseCode = 03310000
ReadyStatusFlags = 0002A1A1
this is gone
it makes this over time:
TCC: 001D
TCC: 001E
TCC: 001F
TCC: 0020
PostPosted: November 22nd, 2026, 20:00
Well, I did waste your time. Sorry.
In my defence, I did give you a chance to correct my misunderstanding:
Since your drive doesn't spin, I would patch the patient ROM (on the patient PCB) so that you can then initialise the NAND flash. That's unless I'm misunderstanding something.
I believe those TCC numbers are the IDs of several overlays in the reserved System Area (SA) on the platters. It suggests that the drive is unable to reach the SA.
PostPosted: Yesterday, 13:28
You haven’t wasted my time. I must have overlooked that. I suppose I’ve probably wasted your time instead.
I’ve learnt a lot. It’s been an exciting journey to get this far.
Thank you anyways!
PostPosted: Yesterday, 13:38
I learned a lot, too. I'll write up a tutorial at HDD Oracle. Hopefully, the gurus will be able to advise you what to do.
PostPosted: Yesterday, 15:21
TCC: 001D
TCC: 001E
TCC: 001F
TCC: 0020
This is the temperature. The working HDD shows the same output when idle. :)
PostPosted: Yesterday, 15:28
SWM wrote:
TCC: 001D
TCC: 001E
TCC: 001F
TCC: 0020
So, it's working?
PostPosted: Yesterday, 15:51
Oops, I see it's still not working.
PostPosted: Yesterday, 15:53
I don't have this drive. Connect the terminal and SATA and apply power. If (P) SATA Reset and (H) SATA Reset in terminal - HDD appear on the interface.
PostPosted: Today, 4:36
I'm afraid it doesn't appear. I have a kind of device? But it tells me it is 0 bytes even when I try to create an dd Image.
The Output on Terminal:
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
ASCII Diag
TCC:001A
mode
I guess "(H) SATA Reset" is missing?
PostPosted: Today, 8:16
ASCII Diag
Did you press Ctrl+Z?
In terminal mode, the SATA interface HDD is busy.
TCC:001A
To check, after HDD starts, press Ctrl Z and then Ctrl X.
To exit diag mode on the SATA, press Ctrl R. Or, turn off-on the HDD power.
This is a reset from the host (computer). Is your HDD connected to the SATA?
Or via an noname USB adapter?
PostPosted: Today, 9:09
Could a reported capacity of 0 via SATA point to corruption in SMART, G-list or translator?
Users browsing this forum: ccc, Google [Bot] and 282 guests
