 Post subject: IsSamsung PM991a Embedded SSD recoverable ?
PostPosted: Yesterday, 4:15
I have got samsung nvme SSD model PM991a . It has lost detection & gets heated up after few seconds. Most of the electronics seems to be ok.
Is it possible to recover this embedded model & whether MCU is supported by PC3000 portable ?
Thanks.
 Post subject: Re: IsSamsung PM991a Embedded SSD recoverable ?
PostPosted: Yesterday, 10:26
Most of those have internal shortage of controller and there is no way at the moment to fix it.
793561753_1569486821641555_1542317637636071289_n.jpg [ 102.58 KiB | Viewed 396 times ]
odzyskiwanie danych
PostPosted: Yesterday, 10:34
What are the supply voltages?
PostPosted: Today, 10:45
Thanks fzabkar
Fortunately customer is electronic expert and he has tested components & corresponding voltages , I will get them from customer & will update.
PostPosted: Today, 10:56
Since you are taking data recovery jobs, you should learn how to do those trivial tests yourself. Or do you reject those jobs that require electronics knowledge?
PostPosted: Today, 11:11
Thanks melvin
only corner of the chip is getting hot , hope chip is not internally shorted. Is there any way to conclude by checking voltages .
PostPosted: Today, 11:19
terminator2 wrote:
Thanks melvin
You check for short circuits by measuring the resistance. You check the voltage to confirm that the overheating problem is/was not the result of an overvoltage from a faulty regulator/converter.
I have a question for you. Would you take your car to a mechanic who knows nothing about engines, but who still expects to fix them from behind a laptop?
Users browsing this forum: No registered users and 102 guests
