 Post subject: ST2000LM007 - Compatible Donor
PostPosted: Yesterday, 10:57
Hello to all.
I´m looking for a compatible donor for head swap.
HDD with Serial Number: ZDZSVT6Q
Model: ST2000LM007
Part Number: 1R8174-570
Firmware: EB01
Date Code: 28 MAY 2024
Site Code: TK
Product of: Thailand
PCB Revision: 100835923 REV C
Heads Map: 0,1,2,3
Preamp: C2
Since this drive is kind of new, it´s hard to find a donor, most newer drives have Preamp 82.
There are some old (2017) C2 type, but different serial: WDZ... from China
From your experience, what does count the most?
Thanks a lot.
 Post subject: Re: ST2000LM007 - Compatible Donor
PostPosted: Yesterday, 11:20
There's no difference in compatibility between 82 and C2. Unless manufacturer is alternative. All the rest should work. If not, take another one.
It's good to match PCB number but it's not a must in my opinion.
odzyskiwanie danych
PostPosted: Today, 12:56
Thanks Melvin,
do you think this one could work, year woudn´t mind much?
I don´t have any in stock, researching first.
HDD with Serial Number: ZDZCFGTE
Model: ST2000LM007
Firmware: EB01
Date Code: 23 JUL 2020 -
Site Code: TK
Preamp: 82
PostPosted: Today, 13:38
Do you think Firmware is a must?
