 Post subject: recover data from formatted partition
PostPosted: August 15th, 2005, 5:35
I found this forum was so comfortable.....
I got big case now....
Is it still possible to recover file from partition that have been two time formated.... this harddisk have two partition.....
Can anybody tell me ???????
 Post subject:
PostPosted: August 15th, 2005, 9:20
yes
it should be possible in most cases,
if you need the data be carefull while trying.... :evil:
regards
Aryes
 Post subject:
PostPosted: August 15th, 2005, 14:54
Get GET DATA BACK program. Install it on another PC and insert this "formated" HDD as secondary disk. RUN program and recover data from this to another HDD. It is MOST IMPORTANT that you DO NOT install program on this HDD if you don not wish to overwrite data!! Everithing is still there, yust dont write anithing on it until You restore what you need.
Sorry for my English but i think you will get the point :D If you need any help, just ask.
 Post subject:
PostPosted: August 16th, 2005, 0:36
i think this case we must be very lucky.
the problem is this HDD have installed wih windows.. :(
I've try using Getdataback. but nothing found....
also try using R-Studio. the result still the same.....
Maybe No Hope....
Hi Dusan72 and aryes... are you doing data recovery too...
If you dont mind may be we can be friend and share knowledge or can chat more using msn or others.......
that if you want.... :)
Thanks again........
 Post subject:
PostPosted: August 16th, 2005, 2:02
what do you need from the hdd?
r-studio is a good program
you can also try active undelete
regards
A>S :idea:
 Post subject:
PostPosted: August 16th, 2005, 2:57
maybe you can try magic recovery professional. its a good software for recovery.
but sometime, word document and xls files become corrupted. you must use another software to do that...
 Post subject:
PostPosted: August 16th, 2005, 6:24
tonyht, You say :
actually I found some.. but the file corrupt.. can not be opened. if can it display STRANGE CHARACTER.. Do you mean it can be repaired using another software.....
If so.. can you tell me HOW ?????
thanks
 Post subject:
PostPosted: August 16th, 2005, 7:00
there are some choices:
1. officerepair premium ( look for it in the net )
2. docrepair , excelrepair ( look in the net )
this soft can rebuild the files , but some of the contetnts
can be lost... i mean in some cases you wont get the whole file
only part of it.
3. try using finaldata software they have office files repair options
built in the recovery software.
PM me if you need more help
regards
A>S
 Post subject:
PostPosted: August 16th, 2005, 11:38
I'm also using finaldata to do that, but I don't know there is a office file repair options.. can you show where ???? thankssss
 Post subject:
PostPosted: August 16th, 2005, 16:40
Hmm, i done some data recovery only for myself few times. I am not proffesional, but when i decide to do something...i can spend a lot of time to do that :D. It is not good if you install windows on the sam disk, but i dont belive that you really can not get any old data ? Are you sure that you done everything right with GDB program? Or maybe you can realy send me PM with your MSN account. We can go step by step "live" :D
 Post subject:
PostPosted: August 17th, 2005, 1:08
to tony
look in the file menu , its there
dont remember the excat place , but there isnt much to check..
A>S
 Post subject:
PostPosted: August 17th, 2005, 5:02
To sutiono668:
There are in fact a lot of data recovery programs around, but speaking for myself I'm very conservative in what concerns to applications. 13 years of intensive work with computers proved that most applications are just crap, specially freeware (that's why I was so amazed with this wonderful piece of software named MHDD). So don't waste much time jumping from one program to another just to find that they do exactly the same.
I've been using Easy Recovery Professional for many years, and I can assure you it's an excellent file recover program. Try it, but don't expect too much in your specific case. At this time, the file related information necessary to "unformat" your partition by iterative methods is probably gone. You must use an hexadecimal editor to join pieces. Winhex (another great program) will be of great help, because it recognizes a lot of different file formats.
About Office documets repair, Easy Recovery is shit. I've used successfuly the repair feature in Office 2003 for 2 or 3 times for Word documents. About Excel worksheets, I've done more times manual recovery than automatic one, so I really can't advise you.
Hope this helps.
Daniel
 Post subject:
PostPosted: August 18th, 2005, 2:40
hi daniel
i think that is true, most recover soft is a crap :-)
easy recovery isnt a choice for a professional DR ...:-))
regards
A>S
 Post subject:
PostPosted: August 18th, 2005, 5:42
Aryes,
I used EasyRecovery dozens of times with excellent results in pretty bad situations. However, I'm not sure if we are talking about the same. I consider EasyRecovery a excelent tool in its field, which is file system structure, not damaged media.
But since most of you have more experience than me, it would be great if you could tell me about other tools you consider better. I'm conservative with applications, but I'm not stupid :-)
Daniel
 Post subject:
PostPosted: August 18th, 2005, 9:56
hey Daniel
easy recovery doesnt recover folder and file names
it just creates folder for each fyle type.. not handy if you have a few thousand or hundred files... :D
you can use several programs wich are unicode also :
1. final data
2. r-studio
3. active undelete
regards
A>S
 Post subject:
PostPosted: August 18th, 2005, 10:44
hi aryes, please don't forget. just to added to your recommended software 8)
mHDD is also a powerfull software... :lol:
thanks to dmitry.... :)
 Post subject:
PostPosted: August 20th, 2005, 11:58
yes of course mhdd is a great program
i use it a lot and like it very much
Users browsing this forum: fareedhan, Google [Bot] and 270 guests
