 Post subject: Help With WD800BB-00CCB0
PostPosted: January 17th, 2006, 17:16
i have a WesternDigital WD800BB-00CCB0 that is playing up
orginally it would boot windows, but crash with errors
most of the data seemed to be in good condition
i ran a surface scan on the disk which picked up bad sectors
now after the scan the drive does not appear to have any data on it
i cannot restore mbr / partition table
Some of the diag s/w is reporting it cant read sector 0,
MHDD scan reports SSSS just lots of S's flooding the screen, not sure what that means
Any one have any clues as to what is wrong or if it can be repaired
Lance
 Post subject: ...
PostPosted: January 19th, 2006, 3:27
Some module in SA are not ok - corrupted...
Read modules and rewrite bad modules...
 Post subject:
PostPosted: January 19th, 2006, 5:07
The drive has a problem with the translator. You have to regenerate it.
 Post subject:
PostPosted: January 19th, 2006, 5:18
hi all
hope some one can explain how?
i have the same problem , but don't have pc3000 .. could this be done by any other peice of software?
regards
 Post subject:
PostPosted: January 19th, 2006, 9:07
sawwa7 wrote:
hi all
regards
without pc3000 u can repaier it, please send me email.
 Post subject:
PostPosted: January 19th, 2006, 10:06
without pc3000 u can repaier it, please send me email.I have litle software to wd problems, only 1 touch in 0,5 minute your hdd will good
hi yudi
thanks alot for ur response , i've send u pm with email and hope u can help solving this problem.
Kind Regards
 Post subject:
PostPosted: January 20th, 2006, 11:31
hi yudi
Kind Regards[/quote]
i was send u email,
-yudi-
 Post subject:
PostPosted: January 20th, 2006, 17:13
Hi, can you send the software to me and instructions on how to use it too
thanks
lance@vivid.net.nz
 Post subject:
PostPosted: January 20th, 2006, 17:57
yudi wrote:
hi yudi
Kind Regards
i was send u email,
-yudi-[/quote]
hi yudi
thank you very much for this great peice of software , i'll try it tomorrow and will feed back
thanks alot
Kind Regards
 Post subject:
PostPosted: January 22nd, 2006, 5:19
hi yudi
would u be more kind with littel explaintion for this progam please
if u have any documents explaining it , please forward to email
thanks in advance
Kind Regards
 Post subject: WesternDigital repair
PostPosted: January 24th, 2006, 5:11
yudi
my email:
gsimon@dziti.com
 Post subject: re
PostPosted: February 8th, 2006, 5:54
what to do when u do not have original modules of p-list?
 Post subject:
PostPosted: February 8th, 2006, 6:41
translator regeneration
Plist wil be created
 Post subject: re
PostPosted: February 8th, 2006, 7:11
recalculation with or withouth p-list?
 Post subject:
PostPosted: February 8th, 2006, 15:58
I would write a clean plist, regen translator, make an image of the drive, and restore the data recovering the shifts.
 Post subject: re
PostPosted: February 9th, 2006, 5:38
i do that but i can read then only few hundredes lba than i have all
how to shift that using Data Extractor?
And one more qusetion
i have noticed Mamuth problem on new wd when u change the pcb, I know how to solve it when i have the burned original pcb board but i would like to know how i can acces the rom and change what needs to ..........
any info is great
pm is ok to
thanks
 Post subject:
PostPosted: February 12th, 2006, 18:05
yudi wrote:
sawwa7 wrote:
hi all
regards
i don't believe , only hrt & pc3k can repair this problem. yudi, i wan't to test u program.
 Post subject:
PostPosted: February 13th, 2006, 1:47
without pc3000 u can repaier it, please send me email.[/quote]
xtrail wrote:
i don't believe , only hrt & pc3k can repair this problem. yudi, i wan't to test u program.[/quote]
ok, no problem for me if u didn't believe it, i would not sent u this program.Who are u Xtrail?u my competitor?i don't understand. I only help my friend was trobled in wd, no commercil and didin't perhaps money or anything.
Maybe u hrt & pc3k fanatic .But u can sucsesfully report for this program, from my friend Sanwwa, Subside and other , not from me.
-yudi-
 Post subject:
PostPosted: February 13th, 2006, 5:05
Hi, I'm a newbie and i like a lot your forum. Think that here is a lot of "knowledge power"!! For those who, like me, don't make this for living but for passion it's amazzing the wonderful "tricks" and knowledge hidding behind these little strange things like hard-disks!!
@yudi
Can you PM me the WD ware too? Thanks
You're great guys!!
 Post subject:
PostPosted: February 13th, 2006, 5:26
Hi Yudi,
Can you please share the WD software with me also.
Best regards.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 334 guests
