 Post subject: SEAGATE U5 20GB with few bad sector
PostPosted: February 24th, 2006, 4:33
hi all,
friends i have a U5 20G HDD OF SEAGATE WITH FEW BAD SECTOR......
MEANS A PARTICULAR LOCTATION MHDD SHOW TIME OUT AT 0.2% IN READ VERIFY COMMAND AND AFTER IT DRIVE IS IN OK CONDITION .NO BAD SECTOR AND NO SLOW SECTORS.
IF I CHECK WITH VICTORIA WITH READ VERIFY COMMAND , SAME IT SHOW S AS MHDD.AND IF I CHECK WITH READ COMMAND BOTH(MHDD,VICTORIA) DON,T SHOW ANY PROBLEM ON WHOLE DISK.
I TRIED ERASE WAIT , REMAP ,ERASE ,FASTERASE(THOUGH SECURITY COMMAND) OF MHDD.(AFTER THESE COMMAND CONDITION IS SAME).
THEN I TRIED ALL REMAP TECHNIQES OF VICTORIA .ALL THIS FAIL.
ALL SHOWS REMAPS EVERY TIME IT CHECKED.BUT NOTHING WORKS.
THEN I USE HDDL 2.0 FOR REMAP .THE STATUS THEM SAME AS ALL SHOWS.
WHAT IS PROBLEM, CAN ANYBODY TELL?
IT IS VERY SHORT AREA OF HDD WHICH CAUSING PROBLEM ON VERIFING BUT NOT ON READING.
THANKS
 Post subject:
PostPosted: February 24th, 2006, 9:34
Run Seagate diagnostic tool . It will fix the problem.
 Post subject:
PostPosted: February 25th, 2006, 1:24
hi BGman,
Thanks for reply. :)
Friend did you mean Seatools.I tried that. but Problem not solved.I tried many tool which i had for seagate but no response.
DO YOU TELL THAT SELFSCAN FOR U5 DO SOMETHING ON IT?
IF YES, WHAT IS THE SAFEST LEVEL TO RUN IT THAT HDD DO NOT LOSE DETECTION AND FINE TUNE IT PROPERLY(MEANS ADJUST ALL DEFECT TO DEFECT TABLES AND OTHER ADJUSTMENT). :roll:
THANKS
 Post subject:
PostPosted: February 26th, 2006, 0:26
ST HDD YOU MUST SEE COM Feedback information.
 Post subject:
PostPosted: February 27th, 2006, 1:49
hi yyqcn,
FRIEND ,DID YOU MEAN ?
WHEN I RUN MHDD OR ANY UTILITY AND IT SHOW TIMEOUT ON THAT AREA WHAT IS THE FEEDBACK INFO THRU COM ........
THIS SHOW NOTHING.....
IF YOU WANT TO SEE.IT IS HERE.....
Interface task reset
256k x 16 buffer detected
U5 - 1_Disk 3.57 12-12-00 10:03 coonend
ATReset Power Cycling
Ref 0267 - Head Mask 0001 - Switch to full int.
Ready
PMaster with Non-conforming Slave
ATReset
SMaster with Non-conforming Slave
ATReset
NOW TELL WHAT CAN I DO FOR IT?
THANKS
Users browsing this forum: Google [Bot] and 74 guests
