 Post subject: Western Digital WD200EB-00BHF0 Problem
PostPosted: February 17th, 2006, 18:34
hi all
i've this western digital with firmware 15.15M15 that crashed suddenly , i run MHDD 4.5 from hiren's cd and when i did erase test the answer was a broken drive , so i've started to scan with erase-wait , then remap and finally i got an error free drive , but the problem is i can't partition the drive or format it .
microsoft fdisk claim none drive integrity and format clain bad track zero :shock:
even when i tried to partition the drive using other non-dos utilities and try to format it within win-xp , the format reach 100% and then got an error message that can't writ file allocation table (fat) .. any idea?
thanks in advance
 Post subject:
PostPosted: February 20th, 2006, 4:23
hi all
is there any hope to solve the problem of this drive?
i can't format it .. the format starts ok , but terminate because it can't wirte the file allocation table to drive .. any idea ?
please help
thanks for any response
regards
 Post subject:
PostPosted: February 20th, 2006, 9:37
Try it in a different computer, w/ a different model of motherboard. You can also try a FASTERASE on it (read the MHDD online manual). If the problem persists on a different computer, replace it.
-cgallery
 Post subject:
PostPosted: February 20th, 2006, 14:07
hi,
- run program check_WD for test Sa modules.
- look at WWW for this file or http://nazyura.newmail.ru/
:cry:
 Post subject:
PostPosted: February 21st, 2006, 9:01
hi all
thanks alot for the answer and response ..
@cgallery
thanks for the suggestations, i've tried MHDD fastearse with no luck , MHDD reports a broken drive while using erase-wait and remap i could get an error free drive.
i'll try another mobo later
@bubu321
thanks for response and link , i've already had this file and used it to test my hdd and here's the test results :
ID:01h-Head0 --> File Is Good
ID:01h-Head1 --> File Is Good
IniOvl.bin (InitDrvParamOvl)
ID:02h-Head0 --> File Is Good
ID:02h-Head1 --> File Is Good
XltOvl.bin (TransltChsWedLba)
ID:10h-Head0 --> File Is Good
ID:10h-Head1 --> File Is Good
WedOvl.bin (WedgeControlOvl)
ID:11h-Head0 --> File Is Good
ID:11h-Head1 --> File Is Good
DvtOvl.bin (DriveValidatTest)
ID:12h-Head0 --> File Is Good
ID:12h-Head1 --> File Is Good
FmtOvl.bin (SuperFormatOvl)
ID:14h-Head0 --> File Is Good
ID:14h-Head1 --> File Is Good
MrdvtOvl.bin
ID:20h-Head0 --> File Is Good
ID:20h-Head1 --> <---------------------[!!! Error Reading File !!!]
PDList.bin (Push Down List)
ID:21h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:21h-Head1 --> <---------------------[!!! Error Reading File !!!]
EventLog.bin (Event Log)
ID:22h-Head0 --> File Is Good
ID:22h-Head1 --> File Is Good
HSDT.bin (HardSecDscrptTable)
ID:23h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:23h-Head1 --> File Is Good
SectMap.bin (SectorMapTable)
ID:25h-Head0 --> File Is Good
ID:25h-Head1 --> File Is Good
RBBList.bin (ReloBadBlckList)
ID:26h-Head0 --> File Is Good
ID:26h-Head1 --> File Is Good
Drmtrip.bin (SmartTripParam)
ID:29h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:29h-Head1 --> <---------------------[!!! Error Reading File !!!]
DrmLog.bin (Smart Log)
ID:2Ah-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:2Ah-Head1 --> File Is Good
HstLog.bin (Host Log)
ID:2Bh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:2Bh-Head1 --> File Is Good
VndLog.bin (Vendor Log (DLG))
ID:2Ch-Head0 --> File Is Good
ID:2Ch-Head1 --> File Is Good
EvtProto.bin (EventPrototype)
ID:2Dh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:2Dh-Head1 --> <---------------------[!!! Error Reading File !!!]
DrmAlter.bin (SmartAlernativ)
ID:2Eh-Head0 --> File Is Good
ID:2Eh-Head1 --> File Is Good
DrmProto.bin (SmartPrototype)
ID:2Fh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:2Fh-Head1 --> File Is Good
RWTest.bin (RdWrTestDlgMod)
ID:36h-Head0 --> File Is Good
ID:36h-Head1 --> File Is Good
CsRamOvl.bin (CacheSegRamOvl)
ID:40h-Head0 --> File Is Good
ID:40h-Head1 --> File Is Good
<UnknownName>
ID:41h-Head0 --> File Is Good
ID:41h-Head1 --> File Is Good
RoadMap (Directory Sector)
ID:42h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:42h-Head1 --> File Is Good
CfgSec.bin (Config Sector)
ID:43h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:43h-Head1 --> File Is Good
Plist.bin (PrimaryDefectList)
ID:44h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:44h-Head1 --> <---------------------[!!! Error Reading File !!!]
Glist.bin (Grown Defect List)
ID:46h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:46h-Head1 --> File Is Good
RcFile46.bin (ReadChannelVal)
ID:47h-Head0 --> File Is Good
ID:47h-Head1 --> File Is Good
<UnknownName>
ID:48h-Head0 --> File Is Good
ID:48h-Head1 --> File Is Good
File48.bin (Adaptives ??? )
ID:49h-Head0 --> File Is Good
ID:49h-Head1 --> File Is Good
File49.bin (Adaptives ??? )
ID:4Ah-Head0 --> File Is Good
ID:4Ah-Head1 --> File Is Good
File4A.bin (Adaptives ??? )
ID:4Ch-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:4Ch-Head1 --> File Is Good
SkProfRd.bin (SkewTableRead)
ID:4Dh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:4Dh-Head1 --> File Is Good
SkProfWr.bin (SkewTableWrite)
ID:4Eh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:4Eh-Head1 --> File Is Good
<UnknownName>
ID:59h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:59h-Head1 --> File Is Good
Tlist.bin (RelocateTrackList)
ID:61h-Head0 --> File Is Good
ID:61h-Head1 --> File Is Good
UCodeOvl.bin (UpdateCodeOvl)
ID:70h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:70h-Head1 --> File Is Good
SkProfR1.bin (SkewTableRead1)
ID:71h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:71h-Head1 --> File Is Good
SkProfW1.bin (SkewTbleWrite1)
ID:72h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:72h-Head1 --> File Is Good
SkProfR2.bin (SkewTableRead2)
ID:73h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:73h-Head1 --> File Is Good
SkProfW2.bin (SkewTbleWrite2)
ID:74h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:74h-Head1 --> File Is Good
SkProfR3.bin (SkewTableRead3)
ID:75h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:75h-Head1 --> File Is Good
SkProfW3.bin (SkewTbleWrite3)
ID:BFh-Head0 --> File Is Good
ID:BFh-Head1 --> File Is Good
SptDir.bin
ID:C4h-Head0 --> File Is Good
ID:C4h-Head1 --> File Is Good
<Unknown> Clbr:(DscrStartMod)
ID:C5h-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:C5h-Head1 --> File Is Good
<Unknown> Clbr:(DCM Variable)
ID:E2h-Head0 --> File Is Good
ID:E2h-Head1 --> File Is Good
<Unknown> SScan
ID:E3h-Head0 --> File Is Good
ID:E3h-Head1 --> File Is Good
<Unknown> SScan:(Fill P-List)
ID:E4h-Head0 --> File Is Good
ID:E4h-Head1 --> File Is Good
<Unknown> SScan
ID:E5h-Head0 --> File Is Good
ID:E5h-Head1 --> File Is Good
<Unknown> SScan
ID:E7h-Head0 --> File Is Good
ID:E7h-Head1 --> File Is Good
<Unknown> SScan
ID:E8h-Head0 --> File Is Good
ID:E8h-Head1 --> File Is Good
<Unknown> SScan
ID:E9h-Head0 --> File Is Good
ID:E9h-Head1 --> File Is Good
<Unknown> SScan
ID:ECh-Head0 --> File Is Good
ID:ECh-Head1 --> File Is Good
<Unknown> SScan
ID:EDh-Head0 --> File Is Good
ID:EDh-Head1 --> File Is Good
<Unknown> SScan
ID:EFh-Head0 --> File Is Good
ID:EFh-Head1 --> File Is Good
<Unknown> SScan
ID:F1h-Head0 --> File Is Good
ID:F1h-Head1 --> File Is Good
<Unknown> SScan
ID:F2h-Head0 --> File Is Good
ID:F2h-Head1 --> File Is Good
<Unknown> SScan
ID:F3h-Head0 --> File Is Good
ID:F3h-Head1 --> File Is Good
<Unknown> SScan
ID:F4h-Head0 --> File Is Good
ID:F4h-Head1 --> File Is Good
<Unknown> SScan
ID:F5h-Head0 --> File Is Good
ID:F5h-Head1 --> File Is Good
<Unknown> SScan
ID:FDh-Head0 --> <---------------------[!!! Error Reading File !!!]
ID:FDh-Head1 --> File Is Good
<Unknown> SScan:(CurStepVars)
ID:FFh-Head0 --> File Is Good
ID:FFh-Head1 --> File Is Good
<Unknown> SScan: (Script&Log)
the program itself claims that everything is ok
can this report help ?
 Post subject:
PostPosted: February 21st, 2006, 10:44
hi
if you have PC3000ISA
TRY THIS...
1.Backup all frimware data.
2.try rewrite with same.
3.clear all defect list & reset smart table.
4. try format drive or logical scanning to put defect in defect list..
try this, may be solve you problem
thanks
 Post subject:
PostPosted: February 21st, 2006, 19:34
I understand head0 and head1 only :D
IniOvl.bin (InitDrvParamOvl) - is it the name of the module ?
 Post subject:
PostPosted: February 24th, 2006, 9:46
Most likely SA (head 0) is phisically damaged since the skew tables are read-only. I think this drive is not repairable.
 Post subject:
PostPosted: February 24th, 2006, 10:06
Bullshit.
The drive needs repairing G-List and SMART modules. It can be done as friend told before. If it doesn't help will need to rewrite them from the working drive and clear afterwards.
 Post subject: To Starling
PostPosted: February 24th, 2006, 13:07
I wrote what I think, based on my own experience. I just tried to be helpfull... Sorry. No more bullshits :cry:
 Post subject:
PostPosted: February 24th, 2006, 13:29
hi all
thank u very much for trying to help .. to solve this drive problem i need to have pc3000 or something similar which i don't have .
all what i have is a small free utilities that can't help repair any of the hard drive firmware or SA information problems , so the drive will be trashed .
@BGman
u are welcome to post what u have , whatever it was been .. i know u are trying to help :)
don't stop my friend , we are all appreciate any response or reply to help solving problems .. and every one has his/her own experience and try to help according to this experience , so .. keep going on and post ur reply .. no problem if someone disagree with u , this shouldn't stop u :)
Kind Regards
Users browsing this forum: No registered users and 242 guests
