 Post subject: Maxtor 6Y080L0 mis-identified as 6Y084L2 in PC3K??????
PostPosted: March 7th, 2006, 7:41
Maxtor 6Y080L0 is mis-identified as 6Y084L2 YCR41VJ0 in PC3K
Does anyone know how to fix this problem?
 Post subject:
PostPosted: March 7th, 2006, 12:02
Online
Migt be cable or connector related.
 Post subject:
PostPosted: March 7th, 2006, 21:04
Calypso can do this.
Probably some data in SA is damaged or corrupted.
 Post subject:
PostPosted: March 8th, 2006, 4:48
For some reason ( problems with the SA) the drive cannot start in standard mode and therefore it starts in alternative mode. In such a mode you can start the Self-test to repair the drive including the SA. Otherwise you must start the drive in Safe mode, use a loader to run it in standard mode and repair SA manually.
 Post subject:
PostPosted: March 8th, 2006, 11:51
Online
Hi BGman,
The C in the FW revision can be a result of a single bit contact problem, since there is a '4' digit instead of a '0' elsewhere, in word-length distance.
 Post subject:
PostPosted: March 9th, 2006, 5:19
Hi Pepe,
I have seen a number of Calipso drives to identify themselves in such a way, but... feel free to trust what you want.
 Post subject:
PostPosted: March 9th, 2006, 16:10
Online
I only said this COULD be, not this IS the problem.
It is much easier to check or replace a cable in the beginning than sucking (sorry for the word) some hours with the FW and finally replace the cable.
BTW I also think it is more than 80% probably FW related.
 Post subject:
PostPosted: March 9th, 2006, 19:32
Hi pepe :)
No need to read anything -
the model no reported by gbulger == FW === 100% certain.
Users browsing this forum: No registered users and 219 guests
