 Post subject: command 98h
PostPosted: March 7th, 2006, 17:54
Browsing this forum, I found on many threads experts talking about so cooled “Safe mode”.
As a beginner I can’t truly understand what this mode real is, so let me ask this question:
If I write 98h to 1F7h,and device IS in "safe mode", what shall be the value of 1F2h?
1. 00h
2. FFh
3. Something else?
Thank you for your time.
 Post subject:
PostPosted: March 7th, 2006, 21:37
A drive does not enter "safe mode" by itself as I understand it.
A drive can enter other modes such as alternative mode.
To get a drive into "safe mode" as it is called, you must do something
to interrupt or skip some part of the normal start-up process.
Often after forcing a drive into safe mode the motor might not start up
or some other normal start-up process/es are skipped.
Once in safe mode you could then replace the normal process/es skipped
with one which might allow access to the drive (pcb and SA).
Maxtor loader file does this.
I suppose your work with the registers might be the same with a drive
in "standard mode" as in "safe mode".
 Post subject:
PostPosted: March 8th, 2006, 14:02
In ATA standards, there is no a single word about “safe mode” - (IMHO, if device CAN be putted in some kind of mode, possibility of that action have to be described there); of course, there are alternate modes: Idle, Stand by, Sleep.
So, do I have right to think about “safe” as just of word which basically mean the same as one of already documented?
Is the “safe” = “stand by”?
 Post subject:
PostPosted: March 19th, 2006, 3:10
Safe mode is not an ata command, and there is vendor specufy commands too.
idle is not an alternative mode, an alternative mode is when the hdd works in a speciall vendor mode like MX NCR
regards
 Post subject:
PostPosted: March 19th, 2006, 22:37
coffeebean wrote:
Once in safe mode you could then replace the normal process/es skipped with one which might allow access to the drive (pcb and SA). Maxtor loader file does this.
Safe mode is a possibility I have considered. I'm doing a lot of reading right now but most good articles on hard drives are in Russian and it takes time to translate.
What do you mean by a Maxtor loader file? Can you point me to a place I can read about this?
Users browsing this forum: Google [Bot] and 293 guests
