 Post subject: wd800bb zone table problem
PostPosted: March 24th, 2006, 18:36
TRACKS DIRECTORY
Version : 773TW
28/ 8/ 3
Copy number Location State
1 C:-1 H: 0 OK
2 C:-1 H: 1 OK
Modules amnount: 77
ZONE TABLE
Amount of zones: 21
# Start cylinder End cylinder Sectors amount
1 -32 -32 31
2 0 65504 7551
3 7520 65504 15103
4 15072 65504 21247
5 21216 65504 28095
6 28064 65504 31999
7 31968 65504 -26273
8 39232 65504 -22753
9 42752 65504 -18945
10 46560 65504 -13953
11 51552 65504 -8993
12 56512 65504 -6913
13 58592 65504 -2433
14 63072 65504 287
15 256 65505 3231
16 3200 65505 7135
17 7104 65505 10143
18 10112 65505 13023
19 12992 65505 17503
20 17472 65505 20127
21 20096 65505 22401
CONFIGURATION SECTOR
28/ 8/ 3
1 C:-2 H: 0 OK
2 C:-2 H: 1 OK
Description data :
Model : WDC WD800BB-00DKA0
Serial number : WD-WMAHL3550374
Logical parameters : Cyl : 155072 Head : 16 Sec : 63
No software isolated heads
Master-password : WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD (ESTABLISHED)
User-password : (NOT ESTABLISHED)
Security level : high
DCM Info
15/ 7/ 3
1 C:-1 H: 0 OK
2 C:-1 H: 1 OK
+ XEN codata L.08 ----- Drive Head DCM Codes -----+
| READ-RITE: F, 0, 7, Y ( zero offset head) |
| HEADWAY: D, 8, 9 ( zero-offset head) |
| ALPS: A ( zero-offset head) |
| ALPS: L, J, H, R (non-zero offset head) |
Ver. Info
7/ 8/ 3
1 C:-2 H: 0 OK
2 C:-2 H: 1 OK
ROM version :
Link table version :
Disk FW version :
PList
7/ 8/ 3
1 C:-2 H: 0 OK
2 C:-2 H: 1 OK
Defects amount: 855
GList
6/ 9/ 3
1 C:-2 H: 0 OK
2 C:-2 H: 1 OK
Defects amount: 1
Hi to all hdd men!
I have one wd800bb-00dka0 that have some problems in the ZONE TABLE as u can see, here seems to not be a problem of bad SPT value, seems to be a direct problem with the ZONE TABLE, i have tryed all, so if any one can help that would be great!!, i dont want that you tell me what to do, i only ask for help, a path to follow, a small orientation
cheers
Marlboroman
 Post subject:
PostPosted: March 24th, 2006, 23:24
I orientate you towards the authors of this program.
 Post subject:
PostPosted: March 25th, 2006, 3:25
The problem was solved
thx
 Post subject:
PostPosted: March 25th, 2006, 4:48
may we ask some details of solution?
thanx,
 Post subject:
PostPosted: March 25th, 2006, 17:44
Of course you can pepe
cheers
 Post subject:
PostPosted: March 27th, 2006, 1:45
Hello Marlboroman,
then I ask you to share the details with me should I run into the same situation I shall be able to solve it.
thx,
 Post subject:
PostPosted: March 28th, 2006, 2:13
PM was sent to u pepe
cheers
 Post subject:
PostPosted: March 28th, 2006, 3:28
cheers
Hi marboroman,
Can you share this solution with me also?
Users browsing this forum: Google [Bot], michael chiklis and 265 guests
