 Post subject: Seagate ST380020A U6 FW 3.39
PostPosted: April 14th, 2006, 11:47
Hello folks,
I'm getting the "clicking noisy", and just in case, I'd like to known if that's possible to fix that without opening the HD case. (Yep, I read the article "Head Stack Replacement: Questions and Answers")
Actually I'm doing that just for fun. I'm a newbie when the subject is about electronics.
I'd really apreciate any pointers about this ;)
Thanks in advance.
 Post subject:
PostPosted: April 14th, 2006, 16:59
It would help a bit if we knew the circumstances it got damaged in.
I mean power failure, physical shock, or anything else.
If there had been no special events, it just began clicking, I suppose it is most probably head related, but it can be that some parts on the PCB got damaged (-5V supply, reading channel...)
so first it is neccesary to exclude PCB, then U may think about how to replace the heads :)
regards,
 Post subject:
PostPosted: April 17th, 2006, 9:07
Hi pepe,
Thxs for the reply.
AFAIR the problem started after a power failure.
In this case it´s a good idea to test the HD after a PCB change huh ?
I´ll try to find another one.
regards,
Samurai
Users browsing this forum: Bing [Bot] and 85 guests
