 Post subject: CAN U HELP ME UNLOCK MY HARD DRIVE
PostPosted: March 7th, 2006, 19:16
HI i have a 40gb hard drive it is lock to 20gb i try to use the MHDD then i go to NHPA it ased me do u want to set native LBA address? y/n i said yes then it tell me read NHPA fail can u tell me y it saying that
now if i used a drive that say 40gb then i cut it to 20gb and i used the NHPA on that drive it work fine when i set the LBA address then i put yes it work it dont tell me fail so can u tell me y the other drive is failing i have alot of drive that is 40gb and it is lock to 20gb and everytime i try to used the LBA address it is failing ca i tell me y please thank u
 Post subject:
PostPosted: March 8th, 2006, 4:35
It would help if you told us the type of drive.
Some other drives will limit capacity if a single head fails.
If you can post the model number we should be able to help!
 Post subject:
PostPosted: March 8th, 2006, 11:11
some is western digital model # is WD400BB-60JKA0 ALSO I HAVE MAXTOR MODEL # IS 6E040L0711233
 Post subject:
PostPosted: March 8th, 2006, 11:25
So, did you read the FAQ?
Dmitry
 Post subject:
PostPosted: March 8th, 2006, 12:39
yes i did but i dont know how to Execute CONFIG command
 Post subject:
PostPosted: March 8th, 2006, 15:29
exactly the same way you executed NHPA... type it!
Dmitry
 Post subject:
PostPosted: March 8th, 2006, 16:28
ok maysoft i try the Execute CONFIG command i put yes the enter all the way it gave me divice error
 Post subject:
PostPosted: March 8th, 2006, 16:37
hey maysoft i got it i have to put yes on everything thank alot thank uthank u
 Post subject:
PostPosted: April 18th, 2006, 9:31
hey can some one help me unlock a maxtor drive i try the CONFIG command it dident work i try the NHPA dident work so some please tell me now what to do
 Post subject:
PostPosted: April 18th, 2006, 10:10
i ve one 40gb segate baracuda hdd firmware 8.01 .its detect in bios but not shown after boot it shows primery master hdd fail.then i tried it on other board it detects and even shows afterboot . i ve tried mhdd it shows that harddisk is ata password protected. so is there really any password or firmware curruption.if yes than tell me how to update this firmware.
 Post subject:
PostPosted: April 20th, 2006, 2:02
try with mhdd to remove password....
Users browsing this forum: No registered users and 97 guests
