 Post subject: Samsung sp0802n "DRIVE BROKEN"
PostPosted: May 20th, 2006, 7:29
I got this "DRIVE BROKEN" error while perform a ERASE on MHDD
Please, can anybody tell me if my driver is dead?
(sorry about my bad english, iam from Brazil)
 Post subject:
PostPosted: May 20th, 2006, 17:47
UP! PLEASE!!
 Post subject:
PostPosted: May 20th, 2006, 18:03
Please post full scan log and smart log.
 Post subject:
PostPosted: May 20th, 2006, 21:44
Smart here
Attribute Current Worst Raw Note
Att: 1 Read error rate 98 98 33204
Att: 3 Spin up time 77 43 4352
Att: 4 Number of spin-up times 99 99 1543
Att: 5 Reallocated sectors count 3 3 212
Att: 7 Seek error rate 253 253 0
Att: 8 Seek time performance 253 253 0
Att: 9 Power-on time 98 98 1238017
Att: 10 Spin-up retries 100 100 2
Att: 12 Start/stop count 100 100 940
Att: 194 HDA Temperature 109 94 43 (43 degrees)
Att: 195 Hardware ECC recovered 100 100 718208669
Att: 196 Reallocate event count 1 1 19705
Att: 197 Current pending sectors 253 253 0
Att: 198 Offline scan UNC sectors 1 1 19653
Att: 199 Ultra ATA CRC Errors 100 100 1
Att: 200 Write error rate 100 100 0
Att: 201 Unknown 100 100 51
 Post subject:
PostPosted: May 20th, 2006, 21:52
and i got various bad blocks on scan, putting just a little portion
Drive testing
Model : SAMSUNG SP0802N
Firmware : TK100-24
Serial : 0637J2FWA16432
LBA : 156368016
Start LBA : 0
End LBA : 156368016
Block size : 256
Bad block found, start LBA : 3357696
Bad block found, start LBA : 3357952
Bad block found, start LBA : 3358208
Bad block found, start LBA : 3358464
Bad block found, start LBA : 3358720
Bad block found, start LBA : 3358976
Bad block found, start LBA : 3359232
Bad block found, start LBA : 3359488
Bad block found, start LBA : 3359744
Bad block found, start LBA : 3360000
Bad block found, start LBA : 3360256
Bad block found, start LBA : 3360512
Bad block found, start LBA : 3360768
Bad block found, start LBA : 3361024
Bad block found, start LBA : 3361280
Bad block found, start LBA : 3361536
Bad block found, start LBA : 3361792
Bad block found, start LBA : 3362048
Bad block found, start LBA : 3362304
Bad block found, start LBA : 3362560
Bad block found, start LBA : 3362816
Bad block found, start LBA : 3363072
Bad block found, start LBA : 3363328
Bad block found, start LBA : 3363584
Bad block found, start LBA : 3363840
Bad block found, start LBA : 3364096
Bad block found, start LBA : 3364352
Bad block found, start LBA : 3364608
Bad block found, start LBA : 3364864
Bad block found, start LBA : 3365120
Bad block found, start LBA : 3365376
Bad block found, start LBA : 3365632
Bad block found, start LBA : 3365888
Bad block found, start LBA : 3366144
Bad block found, start LBA : 3366400
Bad block found, start LBA : 3366656
Bad block found, start LBA : 3366912
Bad block found, start LBA : 3367168
Bad block found, start LBA : 3367424
Bad block found, start LBA : 3367680
Bad block found, start LBA : 3367936
Bad block found, start LBA : 3368192
Bad block found, start LBA : 3368448
Bad block found, start LBA : 3368704
Bad block found, start LBA : 3368960
Bad block found, start LBA : 3369216
Bad block found, start LBA : 3369472
Bad block found, start LBA : 3369728
Bad block found, start LBA : 3369984
Bad block found, start LBA : 3370240
Bad block found, start LBA : 3370496
Bad block found, start LBA : 3370752
Bad block found, start LBA : 3371008
Bad block found, start LBA : 3371264
Bad block found, start LBA : 3371520
Bad block found, start LBA : 3371776
Bad block found, start LBA : 3372032
Bad block found, start LBA : 3372288
Bad block found, start LBA : 3372544
Bad block found, start LBA : 3372800
Bad block found, start LBA : 3373056
Bad block found, start LBA : 3373312
Bad block found, start LBA : 3373568
Bad block found, start LBA : 3373824
Bad block found, start LBA : 3374080
Bad block found, start LBA : 3374336
Bad block found, start LBA : 3374592
Bad block found, start LBA : 3374848
Bad block found, start LBA : 3375104
Bad block found, start LBA : 3375360
Bad block found, start LBA : 3375616
Bad block found, start LBA : 3375872
Bad block found, start LBA : 3376128
Bad block found, start LBA : 3376384
Bad block found, start LBA : 3376640
Bad block found, start LBA : 3376896
Bad block found, start LBA : 3377152
Bad block found, start LBA : 3377408
Bad block found, start LBA : 3377664
Bad block found, start LBA : 3377920
Bad block found, start LBA : 3378176
Bad block found, start LBA : 3378432
Bad block found, start LBA : 3378688
Bad block found, start LBA : 3378944
Bad block found, start LBA : 3379200
Bad block found, start LBA : 3379456
Bad block found, start LBA : 3379712
Bad block found, start LBA : 3379968
Test time : 00:02:07
 Post subject:
PostPosted: May 20th, 2006, 22:14
Yeah, this one is dead :cry: :rip:
Users browsing this forum: No registered users and 220 guests
