 Post subject: Maxtor D540X
PostPosted: May 23rd, 2006, 0:12
Hy does anyone had a problem like this in maxtor D540X MX4K02H1
after starting,the hard disk heads make a loud click, then drive’s motor increase its speed and again another loud click and finished the disk its DRDY DSC but cant access SA
Thnanks for all u help
 Post subject:
PostPosted: May 23rd, 2006, 1:17
99% head related :(
 Post subject: HY
PostPosted: May 30th, 2006, 19:14
Im replaced head stack , and the problem still, even if the disk its working with platter and no heads in , motor increase its speed then return to his speed normal
 Post subject:
PostPosted: May 31st, 2006, 18:55
This is normal if there is no usable system head inside :)
When U replace the head stack, U must find a donor with the same figure in the first place ("DGPXX"), ie. the donor head must come from a HDA with this code starting with 'D'.
reagards,
 Post subject: Hy pepe
PostPosted: May 31st, 2006, 22:40
Hy pepe Its the same Head, same preamplifier circuit and same label Patient its TSZXX and donnor TSZXX so are the same
Users browsing this forum: WebClaw and 313 guests
