 Post subject: is possible to reset SMART data?
PostPosted: June 4th, 2006, 23:35
i have a WD800BB-00CJA1, want to know if its possible to reset smart data, it had a raw error once and from there it says that is bad, but now i dont have that error (that happend because a PSU problem).
sorry about my english
RH+
 Post subject:
PostPosted: June 5th, 2006, 3:27
It is possible if you know how.
Are you sure that it is WD800BB-00CJA1 and not WD800BB-00CAA1 ?
 Post subject:
PostPosted: June 5th, 2006, 7:06
Current date and time: 05/06/2006 08:07:30 a.m.
Hard Disk Low Level Format Tool 2.36 build 1181; http://hddguru.com
Device details for WDC WD800BB-00CJA1 17.07W17 [80,02 Gbytes]
Model: WDC WD800BB-00CJA1
Firmware Revision: 17.07W17
Serial Number: WD-WMAA91017415
Buffer size: 2097,15 Kbytes
 Post subject:
PostPosted: June 5th, 2006, 9:03
So can you post SMART here? AFAIK, LLF tool can view SMART.
 Post subject:
PostPosted: June 5th, 2006, 10:26
Attribute Current Worst Raw Note
Att: 1 Read error rate 191 1 103
Att: 3 Spin up time 119 81 4833
Att: 4 Number of spin-up times 100 100 513
Att: 5 Reallocated sectors count 199 199 3
Att: 7 Seek error rate 200 200 0
Att: 9 Power-on time 62 62 28315
Att: 10 Spin-up retries 100 100 0
Att: 11 Calibration retries 100 100 0
Att: 12 Start/stop count 100 100 420
Att: 196 Reallocate event count 197 197 3
Att: 197 Current pending sectors 134 134 867
Att: 198 Offline scan UNC sectors 1 200 4672
Att: 199 Ultra ATA CRC Errors 200 253 2
Att: 200 Write error rate 1 1 6670
Att: 200 Write error rate 1 1 6670 <<this is new :( it appear after i do a LOT of tests, after reboot that parameter was ok
more graphical way: http://www.hddstatus.com/hdrepshowrepor ... n=28A5FA9F
do you see any way to fix this drive? :?
thanks again
RH+
 Post subject:
PostPosted: June 5th, 2006, 11:26
Seems that the drive is pretty dead.
Try erasing the whole drive with MHDD, and then scan it. Then post here the first 50 lines of the scan log (or just the summary).
Users browsing this forum: No registered users and 238 guests
